Old 11-11-2003, 10:48 AM   #4486
mo
mo's Avatar
Originally posted by DickemDown
thanks, mo for the setups. i really liked the interactive sheet. a friend of mine that used to race up north had told me about david goss - he said he was real fast with his previous car (tc3 i think). i was having trouble viewing his 5-11-03 setup. can you help me out?
thanks,
herb
See if this works. The quality is pretty crappy because of the file size limitiations for attaching to messages. Gime me you e-mail and I'll send you a copy in full quality in either pdf or jpg.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 11-11-2003, 12:43 PM   #4487
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Where the heck is everyone getting their parts from??? No one by me carries the parts, Speedtech is out of stock on the Team Suzuki stuff and doesn't yet have the graphite parts listed... This is frustrating... Rainbow10's site is the biggest pain in the butt...
vtl1180ny is offline   Reply With Quote
Old 11-11-2003, 12:46 PM   #4488
rc-zombies's Avatar
R10... hmmm never had any problems with them..
most reliable source to get parts.
try Precision RC in HK
http://www.precisionrc.com/
I always shop at RcModel in HK too.
http://shopping.rcmodel.com.hk/
Old 11-11-2003, 01:01 PM   #4489
Trader Rating: 28 (100%+)
Ok guys...I am running the rayspeed conversion and the Rayspeed springs.What shock ends do I have to use in order to get the proper droop and the springs not sagging when the shock rebounds.When the shock rebounds it is too long in apperance that the spring becomes loose Between the spring perch and the threaded shock collar.What are the lengths require for front and rear shocks?
thanks!
racenut123 is offline   Reply With Quote
Old 11-11-2003, 01:05 PM   #4490
I'm running my shocks at 64 and 66mm as per the setup sheet. Im using the short shock ends as I have the SS shock bodies but Matt uses the long shock ends with his SSS shock bodies.
James Nguyen is offline   Reply With Quote
Old 11-11-2003, 01:35 PM   #4491
Registered User
2Tenths's Avatar
racenut: I believe you also need to run the Rayspeed spring retainers. Are you using them?
Matt: Before I got the RS chassis, I tried that idea of a fully adjustable rear toe, because, I figured, it would be easy to do as the arms are the same all around the car. I bought the extra front suspension parts (knuckles, hub carriers and turnbuckles) and mounted the turnbuckles to a longer screw through the rear arm mount (the one up front imbetween the motor mount and gearbox). Anyways, the handling was horrible The hubcarrier, mounted backwards on the rear suspension gave the knuckle 4 degrees of downward angle (pro squat?) and the rear end was sliding everywhere.
Don't try this at home!!!!
2Tenths is offline   Reply With Quote
Old 11-11-2003, 03:39 PM   #4492
I am using the rayspeed perches.Where is everyone check the droop from.The actual arm?Carrier?or in the front the kingpin screw?In the rear....Arm or carrier?
James,I will have to pic matts heads because the stock shocks with the the settings he has on the setup sheet is not working.I know I am missing something!
Old 11-11-2003, 03:42 PM   #4493
Are you using the long ends on both ends of the car?
Old 11-11-2003, 03:48 PM   #4494
Yup....the problem I am running into is with 5.5 droop in the front{this is measured under the actual end on the arm}the shock is so long at 64mm that the spring is not even close to being compressed between the perch and the threaded collar for ride height adjustment.And 2 I cant get the ride height under 6.5 mm.
I am doing something wrong.I am measuring something the wrong way.Is it droop?From manufacturer to manufacturer its measured differntly.That irritating.
Old 11-11-2003, 03:59 PM   #4495
hmm...i know on my car the spring floats a little bit also when the suspension is not compressed. As for the ride height, which hole are you using on the caster block? If that's in the right hole, try backing off the droop screws all the way and then set ride height. Then set droop after that. I know its gotta be something small that we are missing. If you can't figure it out then I'll probably be at Stockton this wed and sat.
Old 11-11-2003, 04:34 PM   #4496
JimmyMac's Avatar
Here's my RaySpeed setup with a diff if anyone wants to bash it..
JimmyMac is offline   Reply With Quote
Old 11-11-2003, 04:51 PM   #4497
Matt Howard's Avatar
I don't know what exactly is in stock but have you tried www.speedworldraceway.com ? You'll probably have to call them to see exactly what's in, but they carry all the spares and suzuki stuff
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-11-2003, 04:53 PM   #4498
Which hole for mounting the castor block to the arm are you using? Use the lower one on the castor block if you aren't already. If it's still messed up bring it to me at stockton and I'll figure it out
RCTech #361
Old 11-11-2003, 05:47 PM   #4499
Matt...got it.It was mounted in the top hole.I knew it was something small but important.
Old 11-11-2003, 06:03 PM   #4500
DickemDown's Avatar
jimmymac,
i'm gonna try the rayspeed again w/ your setup. have you tried a one way with it, yet?
hopefully, this time it won't suck for me.
herb
DickemDown is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
