Old 11-11-2003, 12:38 AM   #4471
Matt Howard's Avatar
There's a couple setups on www.yokomousa.com for the SD
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-11-2003, 07:00 AM   #4472
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Are the C hubs available anywhere in graphite or aluminum yet? Both my friend and I have broken the right one, go figure...
vtl1180ny is offline   Reply With Quote
Old 11-11-2003, 07:55 AM   #4473
Send a message via ICQ to Cobra81li200
No graphite part yet for the C-Hubs. But there are some hardened ones (that are not graphite) available since some month ago.
Cobra81li200 is offline   Reply With Quote
Old 11-11-2003, 08:51 AM   #4474
vtl1180ny's Avatar
Hardened ones? Plastic? Where?
Old 11-11-2003, 09:07 AM   #4475
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I'm interested in those as well, who makes em?
Old 11-11-2003, 09:26 AM   #4476
Smile
Since installing Team Suzuki steering hubs over two months ago, not one broken caster block, and only one broken arm at many races. IMO best investment you can make, saves your money for other goodies.
pops is offline   Reply With Quote
Old 11-11-2003, 09:31 AM   #4477
That's a good thing, but how does the knuckle affect the caster block's strength?
Old 11-11-2003, 09:49 AM   #4478
DickemDown's Avatar
i picked up the suzuki hubs after reading a few pages back about the trailing arm - not sure who posted it. anyway, they had wrote that gives better steering response, and he was right. it feels a little twitchy, but i'm starting to get used to it. i actually got 'em because i kept stripping the hole where the kingpin goes.
DickemDown is offline   Reply With Quote
Old 11-11-2003, 09:53 AM   #4479
DickemDown's Avatar
Old 11-11-2003, 09:57 AM   #4480
DickemDown's Avatar
Originally posted by mo
All my setups are on my website, including my latest carpet setup. My latest carpet setup is at the top of the list. www.mo-net.ws
thanks, mo for the setups. i really liked the interactive sheet. a friend of mine that used to race up north had told me about david goss - he said he was real fast with his previous car (tc3 i think). i was having trouble viewing his 5-11-03 setup. can you help me out?
thanks,
herb
Old 11-11-2003, 10:08 AM   #4481
I'm not really sure, but I believe the knuckle is weaker than the caster block.
Old 11-11-2003, 10:14 AM   #4482
vtl1180ny's Avatar
I broke both the Knuckle and the C Hub... I'm seriously considering taking the C Hubs to a machine shop and seeing if they can duplicate a set of aluminum one's for me... In the srping I have a CNC mill coming to me, but I really don't want to wait... One good thing I am getting for the mill is a probe which will allow me to make exact copies of parts. I've already got a delrin and nylon supplier setup...
Old 11-11-2003, 10:16 AM   #4483
sosidge's Avatar
The hardened C-hubs are a Yokomo part - they have an H as a suffix compared to the standard part - it's something like SD-413H (check before you order though).
Old 11-11-2003, 10:18 AM   #4484
Joel Lagace's Avatar
I think the reason why the aluminum knuckles prevent C-hub breakage is the fact that you can locktight your king pin screws into the knuckle. I would guess that most of the cars that break c-hubs had a lower king pin fall out first or at least been very loose.
I have had trouble with the lower kingpin screws coming loose. If they are loose your C-hub is at risk. Then a brush on a wall is all it takes to break the c-hub.
I noticed the last 2 c-hubs i broke that the lower kingpin screw was missin for both( and both had been loosening off after a while) I tried some silver kinpins(from the belt car) but i think they are .5mm too long so you have to becarefull not to over tighten them.
Pit tip: Double check kingpins before each run
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 11-11-2003, 10:33 AM   #4485
Yup, sausage, oops sosidge is right, they're made by Yokomo and part number is SD-4134H.
Anyway, I must say I've never broken any C-Hubs, but when I built the car at first I noticed the steering blocks were weak, lost some kingpins and got the Suzuki... Never lost any kingpin again nor broke any C-Hubs...
If you don't want the alloy ones, go for the new graphite ones (the 0 trail are also available in graphite version...).
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
