Old 11-09-2003, 08:30 PM   #4426
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by pops
Masami and Hara speek a lot better English than most any American can speak Japanese.
I met Masami maybe 6 years ago, and his english wasn't great, but I've heard he has gotten a ton better... He is still a very nice person though, but that's propably more of the culture, us Americans have short fuses
Old 11-09-2003, 10:54 PM   #4427
Matt Howard's Avatar
WHAT DO YOU MEAN WE HAVE SHORT FUSES!
LOLOLOL
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-09-2003, 11:06 PM   #4428
LOLOLOL
lol... Really though, have you noticed that whenever you meet a driver that comes from J-Land, they are all really nice?
Old 11-09-2003, 11:17 PM   #4429
Suspended
Trader Rating: 28 (100%+)
Hey Matt...Did you get you Tobee craft shaft from Billy?Where?
racenut123 is offline   Reply With Quote
Old 11-10-2003, 12:05 AM   #4430
I think he got it from Steve at Speedtech. You can also get it from the various shops in HK and Japan.
James Nguyen is offline   Reply With Quote
Old 11-10-2003, 12:17 AM   #4431
Hey guys, what parts are the most likely to break on the SD?
Old 11-10-2003, 12:18 AM   #4432
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Yea but wait till you see the locals and not the Pro's they are just the same as the guys in the States
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 11-10-2003, 12:38 AM   #4433
racenutt123- I got all my tobee stuff from speedtech
randman- just make sure you have the usuals, like castor blocks and steering blocks and maybe some arms. An extra set of gears for the oneway is nice just in case as well.
RCTech #361
Old 11-10-2003, 12:49 AM   #4434
Suspended
How much lighter is the Tobee caraft shaft?Worth getting?
Thanks Matt for the setup.Will be out next saturday on carpet to run it.By the way,how different was your setup from your alsphault setup?
Old 11-10-2003, 05:08 AM   #4435
Send a message via ICQ to Cobra81li200
Originally posted by rcfiend
Hey guys just ran my car for the second week in a row, the car is absolutely great with one exception - the tweek. The car works great but is extremely loose on power exiting a turn (right side). I have the SD Black Chassis, what are you guys doing to rid the car of the tweek problem? I removed the middle chassis stiffner and it hasn't helped.
Those of you that have switched to the rayspeed conversion, have you experienced any tweek problems with the new chassis? Also can you run the rayspeed motor mount on the SD Black chassis?
What is up with the weak arms on this car, I have broken two in one days and they were extremly light hits.
Yup with the standard setup / Layout the car has an on power push, especially on the left handed corners. It's not tweak, it's the balance of the car that's in cause. To get rid of it, I've switched my servo 90. Info and pictures about the mod you can find them on the yokomo USA forum.
Also, the arms, C-Hubs are the weak parts. It seems like each car has it's weak part, ofr example some people always breaks the C-Hubs (always the same side), I've never. But I've broken several left rear arms... Anyway, the graphite parts are out now and should be available in US soon. I have them (arms and rear hub carrier) and the material is very strong.
Cobra81li200 is offline   Reply With Quote
Old 11-10-2003, 05:52 AM   #4436
asimo's Avatar
With the balancing issue, you could also run a bigger spur gear. This will make the motor sit further (right) of the chassis to help tweak the car.
asimo is offline   Reply With Quote
Old 11-10-2003, 07:21 AM   #4437
racenut123- Yes I'll be at stockton this saturday, there should be a really big crowd this weekend. The only thing I changed from my asphalt setup was one rate stiffer front spring and of course the tires. The tobee center shaft is alot lighter than the stock one, I never weighed them so I don't know the difference.
RCTech #361
Old 11-10-2003, 07:22 AM   #4438
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
Default Rayspeed Chassis Kit
What properties does the Rayspeed chassis give to the car? I'm going to be running mainly on carpet.
Blake
dr_hfuhuhurr is offline   Reply With Quote
Old 11-10-2003, 07:31 AM   #4439
rcfiend's Avatar
Trader Rating: 30 (100%+)
Thanks guys, i'll try the servo mod and a larger spur gear. Do you know if the rayspeed motor mount will help as well?? Also where on the Yokomo site can you find the pictures for the servo mod? Lastly, are you refering to the Yokomo USA site?
Keith
rcfiend is offline   Reply With Quote
Old 11-10-2003, 08:29 AM   #4440
Registered User
Originally posted by rc-zombies
the AE spring cups will only work if you have the AE ball ends as well. will not fit the YOK stock ball ends... wheras the Rayspeed cups will fit the stock ones without any modifications.
just installed the rayspeed cups with AE springs on the rear. I did notice the cups rests/touches on top of the arms (Springs are screwed on the outer hole of the arms). Is this fine?
beowulf is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
