Yokomo MR-4TC SD
#4397
Only thing is you also have to analyse how the chassis is stressed. Will a material that's better in torsion really change a lot ? Not really, because the structure implies that the chassis / upper deck works mainly in traction / compression and shear stresses. Torsion and flexion are minor stresses and in many cases the engineer will neglect them (or that kind of struts I mean).
I'm not saying that it won't change anything, but will it be worth the effort and money spent ?
By the way, I used the new graphite arms yesterday and they gave me extra grip, too much grip because now the car has a little bounce in some corners (everywhere else in's on rails). Now I have to go 1 grade down on the springs to loose a little grip and have a more fluid car.
If you want an extra stiff car, get the graphite gear cases at first, they won't be as expensive as buying new chassis and top deck and I'm pretty sure they are indeed the weak point of the car in terms of stiffness.
#4398
Originally posted by Randman
I think in this car, a stiffer chassis is part of the solution though. The stock SD chassis' flexes too much to be good, because it allows everything to shift under the screws, and that causes tweak in the car. I run on high traction asphault, so in my case, a stiffer car is the better way to go, for those on low traction surfaces, a car that flexes may be the way to go. Maybe a turnbuckle upper deck is a good idea, because there would be nothing to hold the tweak in the chassis. The team drivers are running a stiffer chassis than you'd think, Masami does have the GSG, but who knows what material is underneath the gold, I'd highly doubt it's the same stuff you get in the SSG...
according to Masami, his GSG chassis is almost SAME stiffness as SSG though. it is just added color,besides his laptimes are same!! using both SSG and GSG(it's YMP version) . big difference is just upper deck, he uses MR-4TC's upper deck for GSG chassis, it has rear body post holder on the its rear section for allowing to use softer rear shock.
anyways,,,,can you beat Jason E??
his chassis is SSG !! and super fast !!
in my opinion , SSG chassis is good enough for asphalt eventhough it's hi traction.
but,,,,RaySpeed Chassis is much better than stock, I think it's the best chassis now!! most serious racer use the chassis in Japan.
#4399
Originally posted by Hi-LowBrow
hey,Randman,
hey,Randman,
#4400
Hello Guys...
To save yu all some grief and make myself alot more educated i have dedicated the past day and a half to reading this whole friggin thread. A TON of good info from alot of people. I took good notes and hopefully will not ask repeated questions...
This is what I would like to get for my Yokomo. FYI I will run stock on a small tight asphalt track. I will run MOD here and there so I want to get the good stuff right away. Let me know if I missed anything...
Tobee Lightweight Driveshaft -
Ti Screw set from Yokomo -
Tobee Rear Alum Bones -
Square Ti Front Input Shaft -
Square Ti Rear Input Shaft -
Square Front Axles -
Square Rear Axles -
Square Ti Front Bones -
Thats pretty much everything for the drivetrain. I have spares for about everything else. I plan on running Yok springs as much as I can as I have all of them. I will get some of the Rayspeed but not right away...
Thanks for the entertaining reading !!!
Square Rear Axles -
#4401
Almost forgot....
Fike - Whats up man? I have ran at CH before but only ran offroad. Who is running the SD there? I know Trimmings got rid of his.... What is Richard Lake running? I plan on coming down in Dec - Jan....
BTW Kinetix RC has just put there cells on sale again. I have been running them since day 1. Have had great luck with them....
#4402
Hey,
Nothing else to add...
Hope you'll have more fun reading the next posts, ha ha ha...
#4403
Originally posted by ultragraffics
Hello Guys...
Square Rear Axles -
Hello Guys...
Square Rear Axles -
#4404
I don't know if it was mentioned here or not. But Masami's Gold chassis used at the Japanese Nationals does not have any cut outs at all on the lower chassis. But the battery slots, motor slot, servo slot, and receiver/esc slots are milled out lower into the chassis.
Anyways, ran the RaySpeed Chassis today in stock. Had a decent setup. I'll post it later. Diff setup since I don't have a spool (or didn't want to make one... waiting for SpeedTech to make them... hint hint... )
Ultra, I'd hold off on the Square Axles and bones and get the Yokomo Harden ones instead. Just my opinion. But I had some square ones and the bones wore out already.... They aquired some slop.
The Square Ti input shafts are nice though.
#4405
R/C Tech Elite Member
#4406
Re: Re: Atheena Projects Carpet Chassis and Upper Deck
Do you know what the weight of that car is as compared to stock?
Main chassis: 92 gr. (standard 100 gr.)
Upper deck: 22 gr. (standard 14 gr.)
The material itself is lighter compared to the SSG but the upper deck is obviously heavier due to being 0.4 mm thicker and no cut outs.
#4407
[QUOTE]Originally posted by Hi-LowBrow
hey,Randman,
Did he really speak to you about this, in Japanese?
hey,Randman,
#4408
Hello Guys...
Square Rear Axles -
Hello Guys...
Square Rear Axles -
#4409
Re: Re: Re: Atheena Projects Carpet Chassis and Upper Deck
Originally posted by kentech
The overall weight will be about the same as with the standard SSG parts. Here are the weights:
#4410
Thanks for the input guys....
Randman - I will be running stock primarily. I believe Matt Howard is using the same shaft in MOD and has had no problems yet. Appreciate the warning....and will see if i run it in mod or not...
