Yokomo MR-4TC SD
Old 03-31-2003, 11:44 AM
  #421
utieh's Avatar
thanks Mo
actually I ordered with my kit pinions more like 29-30t
need to place another order
thanks again
Gilles .
utieh is offline
Old 03-31-2003, 11:45 AM
  #422
rc-zombies's Avatar
Originally posted by mo
utieh, If you run the stock 70 tooth spur, I would start with a 23 tooth pinion.
I'm assuming that's 48 pitch...what's the 64p equivalent? similar to the TC3's? 98-100T?
What kind of bearing are included? metal, teflon, rubber shielded?
rc-zombies is offline
Old 03-31-2003, 11:58 AM
  #423
mo
mo's Avatar
rc-zombies, yes, that is 48 pitch. I run 64 pitch myself. A 94 tooth spur is just a tiny bit smaller than the 70 and a 95 is just a tiny bit bigger than the 70. I have a 95 tooth Xenon Perfect spur on my car. Most of the bearing are metal shielded but I think the large diff outdrive bearings were rubber sealed. I'll have to double check when I go through the car later this week.
mo is offline
Old 03-31-2003, 12:03 PM
  #424
rc-zombies's Avatar
Thanks MO
Next time I'm at SWR...gotta get me some of those new Xenon spur gears...
Old 03-31-2003, 12:07 PM
  #425
OVA
OVA's Avatar
Trader Rating: 80 (100%+)
Thanks for the input MO..Sound like a great car to have..Tell me about the EVO3 and the Yokomo SD, compare.those two do have the same turnabilty? and ajustable.or they are very close? Thank
OVA is offline
Old 03-31-2003, 12:19 PM
  #426
rc-zombies's Avatar
Mo..
Sound like the car is very durable after your hard crashes...
no problem with the diff gears stripping like they encountered with the EVO3?
Can't wait to get mine..
Old 03-31-2003, 12:24 PM
  #427
mo
mo's Avatar
OVA, I have never seen an EVO 3 up close, but from what I've seen in the magazine, it looks like they have all the same adjustments.
rc-zombies, yeah, the Xenon spurs are great. As for stripping diff gears, I didn't have any problems there. The only time this car was pulled off the track was when the battery was dead.
mo is offline
Old 03-31-2003, 12:36 PM
  #428
OVA
OVA's Avatar
How come I never hear about masami driving the new yokomo SD in Japan? or any of top yokomo driver in japan..What ever did happen to the top dogs( yokomo ) in yama yama RC in Japan?
OVA is offline
Old 03-31-2003, 03:36 PM
  #429
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
The EVOIII Cleaned up at Yama Yama this year... Only one Yoke there this year in the top 10 and I think that it was 7th or 8th and that was the MR-4...
I belive that Masami Still is Driving the MR-4....or at least thats what the sorce at Home in Japan is Telling me .... also The SD has had a few problems with the front diff gear like the EVOIII but it's not as bad as the EVO's problem...also a couple of front diff cases have cracked where the Shock tower mounts ..
I hope that this isn't as bad as I think...I don't want mine to with these problems..??
-Dave
JDM_DOHC_SiR is offline
Old 03-31-2003, 03:48 PM
  #430
Oh no not stripped diff gears damn better shoot the car like the EVO. Panic panic(j/k)
The car looks good it will be interesting to see it when a few of our local sponsored get theirs.
It has a few of the updates coming for the EVO.
Difuser is offline
Old 03-31-2003, 04:03 PM
  #431
mo
mo's Avatar
I wouldn't worry too much about stripped gears. Like I said below, I ran 30 packs through mine this weekend and not 1 problem and no signs of wear on the gears.
mo is offline
Old 03-31-2003, 05:00 PM
  #432
rc-zombies's Avatar
Mo/Matt
Did you have to add extra ballast on the electronic side to equal the weight of the batteries?
I did when I had my TC3...
Old 03-31-2003, 05:13 PM
  #433
mo
mo's Avatar
Haven't checked out the weight balance yet. If it is, it doesn't seem to affect the handling on the track. The handling was very balanced on the track.
mo is offline
Old 03-31-2003, 05:23 PM
  #434
racer's Avatar
would you have to prep the SSG chassis (sanding, glueing) just as you would with a normal graphite chassis?
racer is offline
Old 03-31-2003, 05:45 PM
  #435
mo
mo's Avatar
racer, yes, I recommend that you sand and glue all the edges.
mo is offline
