Old 11-02-2003, 10:13 PM   #4201
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by cHckbOY5
u have a pic of ur sd randman?
It should be here tomorrow, and the square stuff later this week. Now I just gotta hit up Speedtech about the graphite parts
Old 11-02-2003, 10:18 PM   #4202
Racenut-He posted it on rcracing on the stockton thread.
James Nguyen is offline   Reply With Quote
Old 11-02-2003, 10:20 PM   #4203
Suspended
Trader Rating: 28 (100%+)
James...I couldnt read all the info on the sheet.It was too small.Could you spell it out for me?
racenut123 is offline   Reply With Quote
Old 11-02-2003, 10:29 PM   #4204
yeah no problem.
one way
front:
gold lower sway bar
-1.5 deg camber
one degree of kickup (stock)
RS white bladders
sss shock bodies
long shock ends
rs yellow springs
40 wt oil
RS #2 pistons
5.5 droop
bottom lower camber link position, middle hole on caster block
upper shock position 4th hole in from outside
lower shock position 2nd hole in from outside
arms swept all the way back (4mm shims in front)
Rear:
silver lower sway bar
-1.5 deg camber
3 deg of toe-in
RS white bladders
sss shock bodies
long shock ends
RS Blue springs
30 wt shock oil
RS #2 pistons
4.5 droop
bottom lower camber link position, 3rd hole from outside on hub with 1mm shim under ball stud
upper shock position 3rd hole from outside
lower shock position outside hole
sorex 28/24 with hpi red inserts
5.5mm ride height front and rear
Old 11-02-2003, 10:33 PM   #4205
Suspended
Default Again
You rock James...By the way.What are the diffrence between thew sss and ss shock bodies and are they important to run them with the rayspeed conversion?I am gonna order up the cnversion and need to find out what else I may need.Also are ther 2 differnet types of swaybars for the front?
Old 11-02-2003, 10:45 PM   #4206
The SS shock bodies are longer than the SSS shock bodies. There is a picture of a comparison a few pages back on the thread. I don't think you need them to run the conversion. Just run the long shock ends with them. Yes, there are two different types of sway bars for the front. You can use the old Special sway bar on the car on the top. Not sure what the difference is, I have a set but never put it on. Masami uses the upper one instead of the lower one.
Old 11-02-2003, 10:58 PM   #4207
Suspended
Does it mount on the upper deck like how tamiya mounted them on th 414 wcr car?Or something similar?Man you should have seen Matts car.Hes an awsome driver but Noones car except for maybe Clints car carried its speed so well.
you running the conversion too?
Old 11-02-2003, 11:01 PM   #4208
Yeah it mounts on the car the same way. I'll be out there on the 12th again. Been running the conversion since the first carpet race. Been messing with shock setups though. I've got the same setup as Matt except I'm running the RS #1 pistons.
Old 11-02-2003, 11:05 PM   #4209
Suspended
Default One last question.
Can you use the middle brace/spine on the rayspeed conversion?
Old 11-02-2003, 11:07 PM   #4210
No, It eliminates the center backbone piece. I'm in the process of making top decks right now that are solid to get rid of the flex that will help with the small flex issue for carpet.
Old 11-02-2003, 11:08 PM   #4211
I didn't see any mounting holes for the center brace on the RS chassis...
Old 11-02-2003, 11:30 PM   #4212
Maj. Teeth's Avatar
Originally posted by RCBuddha
Thank you for the responses Matt and Lee, I have decided to go ahead and get the SD, in Black version. I just saw Chris Tosolini run his SD @ SoCal and I was impressed in how well it seemed to go through the turns, it had no tire "screeching" at all. Can't wait to try it out. Now, where's my credit card.....
Buddha
Buddha,
I'm back online. Do get the SD but don't waste money on any hop ups or conversions just yet. Something is up in the air but I'm not in the positon to speak. I'll let you know the next time I see you. It would make the SD bullet proof from what I was told.
Dan
Maj. Teeth is offline   Reply With Quote
Old 11-03-2003, 03:04 AM   #4213
IH
IH's Avatar
Default Antenna mounting?
To all the RS kit owners: Where do you mount your antenna?
Obviously Mr.Adachi forgot to drill a hole in the upper deck...
Thanks,
ingo
IH is offline   Reply With Quote
Old 11-03-2003, 03:14 AM   #4214
utieh's Avatar
Default Re: Antenna mounting?
Thanks,
ingo
that's strange because there is a hole next to the RX but it's half under the upper plate, now, i put my antenna mount here but the antenna tube is a little bit bended...
utieh is offline   Reply With Quote
Old 11-03-2003, 03:43 AM   #4215
IH
IH's Avatar
utieh: I am a little bit afraid of drilling a hole in the upper deck. That will make it flex even more. Let see if there is hole in the lower deck thatīll fit.
MattH: Did you use the lower or the upper hole of the C-hub resp. the rear hub. And where did you place the shim( between steering block and c-hub)?
What springs are the most common using the RS on carpet. What springs do you recommend for asphalt?
Thanks,
ingo
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
