Old 03-30-2003, 03:21 PM   #406
STLNLST's Avatar
Trader Rating: 21 (100%+)
Default Re: Look back in the thread.....
Originally posted by racenut123
Just messin with you and mo, matt.I drive an Evo3 and talking smack like Clinton R. would about his P.o.s. losi
The car,I expect will be one not to be overlooked,thats for sure.Good luck with it.
Difference is that I myself could do well with the car....can you say the same.
Jimmy's 7x2 was slightly faster than my 10x2. My 9 will have him covered.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 03-30-2003, 03:23 PM   #407
STLNLST's Avatar
Mo- Testing was great today with both the Losi and your Yok. Next weekend should be great for both cars.
GO PISTONS!!!!!
Old 03-30-2003, 09:05 PM   #408
JimmyMac's Avatar
My SD is on the way. Maybe you guys can post some setups on here I can start testing. Local tracks are smooth asphalt and technical. More than likely will be running CS27s. So far I have my EVO3 hooked up for Stock Class. But will more than likely run the SD in Mod. I can't wait!
JimmyMac is offline   Reply With Quote
Old 03-30-2003, 09:48 PM   #409
mo
mo's Avatar
KilRuf, I am just running the stock setup with the changes I posted below.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 03-30-2003, 09:52 PM   #410
JimmyMac's Avatar
Thanks, I'll be looking for more changes and post some of my own setups as I try them. Can't wait!
Jimmy Mac
Team Mindblown
Old 03-31-2003, 12:18 AM   #411
Send a message via AIM to ZER01
Originally posted by mo
Went out and ran a few more packs today and got the car a little better. Thickened up the oil a little, 60wt in front and 55 in rear with stock springs. Also went to 2 deg rear toe and moved the front arms forward a little. The car is very consistant and is getting faster.
What was the rear toe? I'm assuming 3?
ZER01 is offline   Reply With Quote
Old 03-31-2003, 05:20 AM   #412
Turn Marshal's Avatar
Turn Marshal is offline   Reply With Quote
Old 03-31-2003, 08:35 AM   #413
mo
mo's Avatar
Yes, the base setup is 3 degrees rear toe-in. The kit comes with 1, 2 and 3 degree rear toe-in blocks.
Old 03-31-2003, 08:40 AM   #414
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Any feed back about the yokomo SD.
OVA is offline   Reply With Quote
Old 03-31-2003, 09:11 AM   #415
Regional Moderator
Darkseid's Avatar
They posted some performance feed back further down on the thread.
But.....Hows about a little feedback on the price? I thought late last week was the time we were told we'd get it.
Its darned near April now, Yokomo can't possibly still be pressuring Speedtech not to post a price. If that is the case, when (in Yokomo's mind ) will it be okay to tell people a price.
The day before the release?
What we have heard so far about the car is very encouraging. I like cars that handle well with their kit setups right out of the box!
TLR 22...Tamiya F104...
Old 03-31-2003, 10:07 AM   #416
OVA
OVA's Avatar
hey MO, Tell us ,Really the yokomo SD it the much better than belt drive?:
Old 03-31-2003, 11:08 AM   #417
mo
mo's Avatar
OVA, yes, I think it is a lot better. Not in the sense that it will drop you lap times by a full second though, if thats what everyone is hoping for. It is faster, but the main reasons it is better is because it is much more consistant, tuneable and easy to maintain and work on. I was only probably .01 or .02 faster than my previous fast laps with the special this weekend, but it was much easier to do and did it more often and that was just after 1 day of running. Things should just get better from there. The car seems to hold up well to abuse too...LOL My home track, Speedworld Raceway, is all solid wood barriers and corner dots. Needless to say, if you make a mistake, you pay for it. The car was slammed pretty hard into the boards a couple times and even flew off the track once. None of the instances resulted in any breakage or even tweaked the car. This should be a vey reliable and consistant car for everyone. I think Matt and I putt about 30 packs total on this car over the weekend, man is my neck sunburned....lol
Old 03-31-2003, 11:15 AM   #418
utieh's Avatar
it is really cool to hear that ,iwill receive mine probably thos friday...can't wait
i will run a corrally 13x3 on a large asphalt track, which pinion do you recommend to start with ?
utieh is offline   Reply With Quote
Old 03-31-2003, 11:23 AM   #419
TheBarber's Avatar
Send a message via AIM to TheBarber
mo - thank you for all the input, and any setup tips you and matt may have in the near future would be appreciated. i know there is a lot of emphasis on having a "free drive train", and i apologize for bringing it up again, but can you honestly say that the SD's drivetrain is as free out of the box as some of the better TC3s out there. I know we have spent many hours "freein'" up our TC3s and i look forward to seeing how this car measures up. Also, is this car "stiffer" than the previous "pan syle" chassis that yok offered (i.e. tosolini's special that he ran at the carpet nats). the reason i ask is i'm curious how the 3mm chassis and top brace will be able to handle the high traction situations in foam carpet racing. Again thanx for your input.
TheBarber is offline   Reply With Quote
Old 03-31-2003, 11:30 AM   #420
mo
mo's Avatar
utieh, If you run the stock 70 tooth spur, I would start with a 23 tooth pinion.
TheBarber, I know I have seen some super free drivetrains on the TC3 too. But I know they have put a lot of time and effort into them. When I build the car, I did not spray out any bearing or shave any plastic or even mess with the gear spacing in the gearboxes. Immediatly after assembly, with flick of the wheels, the would spinn 3 or 4 revolutions. After I ran it twice, allowing everything to break-in, it was probably double that. I know with a little bit of effort (way less than the TC3), it could be just at good as anything out there.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
