Old 11-01-2003, 11:27 PM   #4171
Fire's Avatar
Originally posted by MattSSG
No I live up in Alberta Canada. You mean flip the servo saver to the other side right? I also have to use the other mount that comes with the kit but is in another position than the normal one?
Would the turnbuckle then go over the drive shaft?
you can check out the album on yokomo usa's web site
they have pics of masami's car there and they shows how the servo rotation is done
is there any nice permanent tracks in alberta??
Fire is offline   Reply With Quote
Old 11-02-2003, 12:31 AM   #4172
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Default Re: Servo Config
Originally posted by Vr6vroom
Matt,
your servo will vary in position due to its size. My futaba 9402 was butted right against the center brace, and had to cut the backbone approxiametly 1/4" where the servo ears lined up, or else the other side of the servo would have hung over the edge of the chassis.
The servo saver/ steering assembly has to be flipped over and the turnbuckle was approx, 40mm. Your kit has the other part to mount the ballcup to from the servo.
The alloy servo mounts are made by Yokomo, but I have seen others use the associated one too.
I also heard that you are local to the Tri state area, I race at Southshorehobby.com. Maybe I will see ya there.
Any chance of you sending me pic of this servo conversion. Please send me a PM if possible
danjoy25 is offline   Reply With Quote
Old 11-02-2003, 07:53 AM   #4173
Send a message via ICQ to Cobra81li200
Originally posted by Rick Draper
To fit a TC3 carbon center shaft to a SD. Rick
Ooooh ok. Actually I'm using the Tobee lightweight one and it handles my 12T motors quite well, and the difference in polar moment of inertia must not be that noticeable.
Cobra81li200 is offline   Reply With Quote
Old 11-02-2003, 08:09 AM   #4174
vtl1180ny's Avatar
I'm really curious about the Tobee shaft, my track is strictly stock and lowering the rotating mass would be a plus. How is the weight difference?
Any idea when the Carbon composite parts are going to be available in the US?
vtl1180ny is offline   Reply With Quote
Old 11-02-2003, 08:38 AM   #4175
To make things easy, the set with front and rear aluminium shafts and center shaft weights the same as the stock center shaft.
Old 11-02-2003, 08:38 AM   #4176
Trader Rating: 74 (100%+)
Default Tobee SHaft
I use the tobee shaft, and it is a great weight difference. You can see the specs from Speedtechrc.com or Tobee direct versus the Yok shaft. Plus it looks really COOL.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 11-02-2003, 11:39 AM   #4177
jarkkom's Avatar
Send a message via MSN to jarkkom
Originally posted by Tsubasa Sakai
Any idea?
YS-1360 Shock Spring, Black (Soft) 2 $5.25
YS-1465 Shock Spring, White 2 $5.25
YS-1355 Shock Spring, Blue 2 $5.25
YS-1460 Shock Spring, Yellow 2 $5.25
YS-14575 Shock Spring, Pink 2 $5.25
YS-14525 Shock Spring, Stainless 2 $5.25 l
YS-1455 Shock Spring, Green 2 $5.25
YS-1450 Shock Spring, Orange (Hard) 2 $5.25
this is from the SD part list. I'd trust these.
jarkkom is offline   Reply With Quote
Old 11-02-2003, 11:42 AM   #4178
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Hi i think Johnbull somehow removed the TC3 bone bit at the end of the drive shaft, cut the shaft down to a suitable length and as the shaft is hollow he was able to slide the bone back inside and CA'd them back together. Rick
Thats how I remember it as well, I'd just like to know how he removed the end piece.
Old 11-02-2003, 11:43 AM   #4179
Originally posted by 2Tenths
That's probably a good decision. I have the RS conversion too, and its very complete, well developed (not just a different deck). The new steering on it is awesome, though the chassis is a little too flexible for the carpet I run on. I've messed around with battery/wheel base adjustments, before I had the RS, and the battery forward idea really helped (with rubber tires and a one-way) Even a 1mm change in battery placement (using the wheel base) is noticable.
Well I'm glad that I seem to have picked the right chassis. I thought the main chassis was 3mm, am I wrong?
Old 11-02-2003, 11:45 AM   #4180
Any idea how the Suzuki drive cups affect it? I picked up a pair of those as well, I heard it was a good idea for mod.
Old 11-02-2003, 12:03 PM   #4181
Don't know, but to me the plastic ones works great. And if I have any problem with them, I have some in spares and they're cheap.
Old 11-02-2003, 03:16 PM   #4182
Matt Howard's Avatar
get the aluminum ones if your going to run mod, I only put the aluminum one in the rear since that was the only one I ever broke.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-02-2003, 03:20 PM   #4183
Registered User
2Tenths's Avatar
About the Tobee stuff: Tobee Craft claims that with their centershaft and both aluminum input shafts, that part of the drive train is half the weight (I think ). I'm not sure about the centershaft on its own, but I use it, and it is much lighter. Be careful with the aluminum input shafts though, if you get them. I think I tweaked one, so I'm switching to the Square Ti rear input shaft when it gets here.
As to the Carbon stuff: Rainbow Ten has some of it: I ordered the arms and transmission cases (For less flex). Steve (from SpeedTech) said he'd have the carbon parts soon, but I don't know when. On the "What's new at SpeedTech" thread I believe he said he was working on the spools as well .
Later in November, more carbon stuff is coming, like the battery strap, 4 degree hub carrier etc etc....
2Tenths is offline   Reply With Quote
Old 11-02-2003, 03:37 PM   #4184
Yeah, I've bended (not tweaked) my rear one also, so as I'm out of money, I kept the stock one.
Anyway, the shafts should be about 1/3 of the steel ones (according to volumetric mass) and the central one about 2/3 (according to its volume). I'm too lazy to check all their weight, sorry...
Old 11-02-2003, 04:05 PM   #4185
vtl1180ny's Avatar
I'm already using the Aquare titanium input shafts and axels... I clipped a board and broke a c-hub yesterday, only have 1 spare and since no one around here carries Yok parts I need to order more. I was hoping to be able to get the carbon ones from the states and not have to go look in rainbow ten, their site is a pain in the butt...
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
