Yokomo MR-4TC SD
Old 10-30-2003, 04:55 PM
  #4096
rc-zombies's Avatar
Originally posted by OSherman
maybe i missed this small detail...but...where can i get one of these AEast v1.3??
on the Fibre-lyte website it says to contact Andrew direct at:
[email protected]
rc-zombies is offline
Old 10-30-2003, 08:50 PM
  #4097
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
I have been looking at that chassis and it does look like it would cure the tweak problem that some have had. I have not had this problem though. Pretty wild with the receiver in front of the steering servo. Never seen anything quite like that tub. I guess the closest tub like the one Fibre Lyte is making is the one a I thin HPI made for the Pro 3.
I might want to order one but I wonder how long it would take to have it made and then shipped here to the US.
wyd is offline
Old 10-30-2003, 08:54 PM
  #4098
Randy Caster's Avatar
Trader Rating: 47 (100%+)
I'd think with having the RX under the servo turnbuckle, you'd have to be pretty selective, and make sure it is low enough to where the turnbuckle doesnt hit.
Randy Caster is offline
Old 10-30-2003, 09:02 PM
  #4099
wyd
Tech Legend
wyd's Avatar
That is true. I think that could be a possible problem.
It is also a close fit on the Rayspeed conversion as my steering turnbucle hits my servo. It is especially close if you don't use the stock Yokomo servo horn. That is my only real complaint with the Rayspeed conversion.
wyd is offline
Old 10-30-2003, 09:10 PM
  #4100
Hmm, hopefully I wont have any problems with my Rayspeed SD, it should arrive Monday, I'm propably going to get a S9550 servo to have a little more chassis space.
Old 10-30-2003, 09:22 PM
  #4101
wyd
Tech Legend
wyd's Avatar
The 9550 will hlep. I have one but not in my Rayspeed conversion. I have the Hitec 5925 digital. I has .08 transit and 132 oz torque. It is the same sizse as a standard servo. I did use the 9550 in my Yoke when I had the SSG chassis on.
wyd is offline
Old 10-30-2003, 09:27 PM
  #4102
I have been using S9451 servos in all of my cars, but the S9550 seems better for the shaft drive cars.
Old 10-30-2003, 09:35 PM
  #4103
Also guys, I'm going to have brand new Yokomo SD carbon (black) chassis, upper deck, and f/r shock towers for sale. $80 shipped for everything, they will arrive at my house Monday, and be shipped the same day.
Old 10-30-2003, 10:03 PM
  #4104
I've got a 9550 coming for my SSG chassis.
For those who have used it, did you install it in the standard configuration or at 90°?
I thought I saw a post somewhere for doing the 90° mod but haven't been able to find it. Do you just drill an extra hole and change the position of the servo saver?
snemi00 is offline
Old 10-30-2003, 10:10 PM
  #4105
wyd
Tech Legend
wyd's Avatar
I had the 9550 in my car. I did do the servo mod. I drilled a new hole for the moutn. If you leave the bottom brace on your car you will have to do a little trimming of the servo mount and cut the top ear off the servo. If you take the lower brace off then it is a direct fit. Just drill your new mounting hole.
wyd is offline
Old 10-30-2003, 10:24 PM
  #4106
lonestar1127's Avatar
i tink u can tape the servo wif thick servo tape
lonestar1127 is offline
Old 10-30-2003, 10:25 PM
  #4107
I used shoegoo
Old 10-30-2003, 10:32 PM
  #4108
whoa!!.... guys any idea the spool is suitable for wat track??
Old 10-30-2003, 10:36 PM
  #4109
THeGame's Avatar
Default ĆAST
If I order today how long before I get the chassis Also do you take paypal ?....
THeGame is offline
Old 10-30-2003, 10:37 PM
  #4110
Not sure if I really got that, but a spool would be best suited for a tight technical track where you need to use the brakes to get the best laptimes.
