Old 10-26-2003, 06:46 AM   #3991
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I'm going to try a stock DCX receiver instead of the Novak synthesized one I have in now. Also going to change my wiring some. I run my wiring very neat and sometimes when they are bunched together glitching can happen. I will change some stuff for next week. Sometimes my neatness causes problems.
ST Racing Concepts (STRC)
Old 10-26-2003, 03:24 PM   #3992
Registered User
2Tenths's Avatar
Steve: the idea about the radio module is interesting. I've had glitching for a while now (not just with the Rayspeed chassis) and my radio has its original module from 5 years ago . Maybe I should replace the module, I didn't know they wore out.
Matt: I've also heard that Yok is having trouble coming up with a proper mix of graphite and composite materials for their parts. I don't really understand what the problem is, though, because there are soooooo many graphite parts for the original MR4 TC . Maybe the new material coming is going to be better than Yok's old graphite/composite formula.
I ran the Rayspeed chassis last night for the first race ever on carpet with foam tires. The car, after some adjusting on the Hudy board, seemed very neutral, but the chassis had too much roll and not enough off-throttle steering. Next time I will work on fixing these problems, as well as try running an Alfa 2 rather than the Stratus 2. I think the setup issues were my problem, not the chassis's, because I had too much droop dialed in and improper diff adjustments (the front diff was too loose).
The chassis is quite flexible (bad for carpet) but Peter had a good idea. He pointed out that the Rayspeed motor plate lets the chassis flex because it only mounts in the middle. So, today I put the original motor plate back on, and I think the chassis is a little bit stiffer. I'll try this new setup (less droop, tighter front diff and original motor mount) on Friday probably.
2Tenths is offline   Reply With Quote
Old 10-26-2003, 05:48 PM   #3993
Send a message via ICQ to Cobra81li200
2Tenths : modules don't wear out, you are just supposed to send your radio (i.e. radio, module and receivers) back to the manufacturer (or importer) once a year for checkup and adjustments.
Cobra81li200 is offline   Reply With Quote
Old 10-27-2003, 12:43 AM   #3994
Yeaaaah, I've just ordered my graphite parts !!!
Available parts are the following :
SD-415G05 MR-4TC SD GRAPHITE REAR HUB CARIER TOE IN 0.5,
SD-415G10 MR-4TC SD GRAPHITE REAR HUB CARRIER TOE IN 1.0,
SD-008G MR-4TC SD GRAPHITE LOWER SUSPENSION ARM,
SD-302G MR-4TC SD GRAPHITE TRANSMISSION CASE,
SD-415G MR-4TC SD GRAPHITE STEERING BLOCK 6 REAR HUB CARRIER,
I believe we will not need any aluminium transmisison case now ha ha ha...
Old 10-27-2003, 03:10 AM   #3995
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
sd gear ratio
Can anyone give me a good starting gear ratio for a Matrix V10 stock motor? I will be running foam tires (63 mm) and car comes with one-way diff. speedo is a GM V8 and using GP3300.
danjoy25 is offline   Reply With Quote
Old 10-27-2003, 09:30 AM   #3996
JusBox's Avatar
Where'd you get these parts from?
JusBox is offline   Reply With Quote
Old 10-27-2003, 09:49 AM   #3997
Hi, I am interested to get a SD. I have a XRAY T1R now and I am very happy with its performance. On club track, I've seen many people playing SD and they always need to adjust the car's setting and tweak the car after every few packs of batteries. Does SD need lots of time to do maintainence? To me, my T1R is so simple and I can describe it as a "build and go" type. Any comment for me?
discus18 is offline   Reply With Quote
Old 10-27-2003, 09:49 AM   #3998
utieh's Avatar
I saw them this morning on Rainbowten product list.
www.rainbowten.co.jp
utieh is offline   Reply With Quote
Old 10-27-2003, 09:51 AM   #3999
SpeedTech's Avatar
2Tenths,
I didn't know about that until recently too, and upon confirming with quite a few pro-drivers, yes, they do go out. Don't go out and buy one just yet, check with a racing buddy to see if he can let you borrow one (maybe even try on on a different Mhz) and see if that solves your glitching problem.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 10-27-2003, 09:59 AM   #4000
SpeedTech's Avatar
We'll have these parts available soon from Yokomo USA along with more hard material parts.
Steve Wang
Old 10-27-2003, 10:05 AM   #4001
JusBox's Avatar
Steve, what's your opinion of the SD compared to the barracuda r2? I'm thinking of picking up an R2 or R3 soon and would like to know your opinion.
Old 10-27-2003, 10:15 AM   #4002
rc-zombies's Avatar
R3
Old 10-27-2003, 11:22 AM   #4003
kentech's Avatar
Default MR-4TC SD CGM Special
Found this picture of the moulded SD
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 10-27-2003, 11:34 AM   #4004
forty6's Avatar
CGM Special? Can the tub be made of Carbon Graphite Material?
forty6 is offline   Reply With Quote
Old 10-27-2003, 11:38 AM   #4005
Default Re: MR-4TC SD CGM Special
i fought this was the tc3 thread for a momont
trf racer is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
