Old 10-25-2003, 09:52 AM   #3976
forty6's Avatar
Originally posted by STLNLST
I tried to throw it in the trash but it was full of broken SD parts...LOL
Guys, enough trash talk, those are not broken SD parts, they are Evo III one way gears!
forty6 is offline   Reply With Quote
Old 10-25-2003, 09:54 AM   #3977
JusBox's Avatar
Ha ha, too funny. I have an actual question though... what size drill bit would i need to ream out the a-arms on my SD? I'm just doing some detail work on the car and I kinda jacked up one of my a-arms with my dremel/hinge pin method. Not ideal to say the least. The instructions don't tell the diameter of the hinge pins. Thx in advance.
JusBox is offline   Reply With Quote
Old 10-25-2003, 09:56 AM   #3978
no!they must be sd parts.
theres nothing wrong with my gears
them sd they eighther go wrong or go crap
trf racer is offline   Reply With Quote
Old 10-25-2003, 12:59 PM   #3979
Send a message via ICQ to JesseT
The inner pins are 2.50 mm and the outer ones 2.00 mm.
JesseT is offline   Reply With Quote
Old 10-25-2003, 04:23 PM   #3980
Registered User
2Tenths's Avatar
Steve: I don't know what you're planning on making, or what you can make, but I think titanium hinge pins would be cool. I haven't broken a hinge pin (yet anyway ) but a ti one would at least be lighter than the steel ones. Also, I've heard the Yokomo graphite battery strap fits on the SD (like on Masami's car), but a narrower one just for the SD would be useful in lightening the car on the battery side. Lastly, since Yokomo doesn't have a 6 degree hub carrier yet, you might be able to develop and sell those as another tuning option.
2Tenths is offline   Reply With Quote
Old 10-25-2003, 06:16 PM   #3981
No broken hinge pins yet, but quite a few bent ones. Ti hinge pins should not bend as much, I would hope. The graphite SSG battery strap from the Special will fit with the older battery strap mounts.
pops is offline   Reply With Quote
Old 10-25-2003, 06:57 PM   #3982
MattSSG's Avatar
Is their a reason why there are no graphite parts for the SD (such as arms, hub carriers, etc). Or if they will be coming out with those parts soon.
MattSSG is offline   Reply With Quote
Old 10-25-2003, 07:18 PM   #3983
Fire's Avatar
maybe there are graphite parts in progress
just can't pass masami's testings
Fire is offline   Reply With Quote
Old 10-25-2003, 09:35 PM   #3984
Roger's Avatar
Im sure they are in the works. You know, gotta get into everybodies pockets before they release the good stuff. Thats what happened to the MR4-TC.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 10-25-2003, 10:27 PM   #3985
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Well I ran the Rayspeed conversion today for the first time. Car was pretty good. Only probelm was the steering link going to the steering rackrubs on my servo and then makes the car not go straight all the time. Makes it kinda inconsistant The other problem is I was glitching at the same spot on the track all night long. All in all as far as the car it worked great but now I need to get rid of the damn glitch as it is pissing me off. I will try another receiver for next weekend.
ST Racing Concepts (STRC)
Old 10-25-2003, 11:29 PM   #3986
NightKidZ's Avatar
Send a message via ICQ to NightKidZ
Hi there
Last I checked the Yok Japan website www.yokomo.co.jp, the front page (updated 23 Oct) states that graphite suspension parts are being shipped to retail shops on that day.
A friend of mine had a short holiday in Japan and got me the harden 4 degree castor blocks, dun seem like a carbon-resin composite (too shiny), but much stiffer than the old one. Looks to me like its a high fiberglass mix.
Cheers
Cheers
NightKidZ is offline   Reply With Quote
Old 10-25-2003, 11:41 PM   #3987
Roger's Avatar
Thats funny. You're like the 5th person to say that you got glitching problems running this chassis.
Old 10-25-2003, 11:46 PM   #3988
GeorgePravata's Avatar
Trader Rating: 108 (100%+)
I have the RaySpeed chassis and i don't have any radio hits
GeorgePravata is offline   Reply With Quote
Old 10-26-2003, 12:32 AM   #3989
SpeedTech's Avatar
Hi Guys,
A note on the radio hits. Try different crystals, receivers, speedos...etc. Certain chassis will have more conductive material than other (for example, double deck graphite chassis compare to composite tub) however, a clean radio signal will have no problem operating on either one. Also, you might want to consider a different module for your radio if it's been more than 1 1/2 year of use. Lastly, if you're running stock motor with capacitors that are built it (for example Monster stock, P2K2...etc.) and you had the motor for some time, the built in capacitor might have burnt out and the lack of cap. is what's causing the glitch. You can remove them and install standard cap on them.
Also, try 27mhz if you're glitching on 75mhz. Sometimes certain things around the racetrack (power lines, flourcent lighting) can severely cause radio hits on 75mhz, but doesn't hit 27mhz. My personal experience was with flourcent lighting at local track SoCal Raceway. During practice when only half the lights are on, my car is perfectly fine. Without changing anything, when they turn on all the lights for racing, my car is literally undriveable. Changed to 27mhz, the car was fine
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 10-26-2003, 05:02 AM   #3990
Send a message via ICQ to Cobra81li200
Yeah NightKidz, I've been told by R10 that M. Hirosaka was having troubles finding the correct graphite/plastic ratio. Seems like they've been developing a new plastic, but also that the problems have been fixed now...
Pops : Ti is not stronger than Steel. I mean, the strongest steel will always be stronger than any Ti alloy. The question is : which is the alloy used on the SD ? And which Ti would perform better (if possible) ?
Cobra81li200 is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
