Old 10-23-2003, 08:44 AM   #3931
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Roll tide if your stock pins can be pushed out you should be able to then replace the pin with the IRS ones. I talked with Dave Irrgang at IRS a few months ago at a race and asked about making Yoke parts. Dave said that Yoke changes their stuff too much so he won't be having anything made specifically for the Yoke cars. I would have liked them to make a locked diff but no such luck. I guess someone else will have to make an aluminum one for the Yoke.
ST Racing Concepts (STRC)
Old 10-23-2003, 09:18 AM   #3932
What is the part number for the longer ss shocks for use with the rayspeed conversion? Is it YS1SS-6? Rick
Rick Draper is offline   Reply With Quote
Old 10-23-2003, 10:20 AM   #3933
SpeedTech's Avatar
Rick,
Yes, those are the ones with longer shock bodies, thus the shock shaft will extend further making the shock's overall length longer.
If anyone is interested in lock diff (aka Spools) for the MR-4TCSD, let me know, since I'm inquirying around for spools for other cars, I can look into making them for the SD as well.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 10-23-2003, 10:23 AM   #3934
forty6's Avatar
YS-4SS-6 (SS shock body only, 1 per pack)
YS-1SS-6 (Complete SS shock assembly, 1 pair)
forty6 is offline   Reply With Quote
Old 10-23-2003, 11:18 AM   #3935
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Steve, I would be very interested in a spool for the Yok SD. My guess would be if Speedtech put those on the market they would sell a huge amount of them!!! Keep us informed on that endevor.
Jeff
Jeff Werner is offline   Reply With Quote
Old 10-23-2003, 03:43 PM   #3936
Can anyone help thinking about getting a rayspeed conversion .Iwould like to no does it take the freeplay out of the N/S front steering
mark turner is offline   Reply With Quote
Old 10-23-2003, 04:18 PM   #3937
JimmyMac's Avatar
Steve, me want spool too!!!
Keith, carpet will be here next week. Track will be done a week or 2 after that. So I'd say in about a month. I'll let you know when for sure!
Mark, the RaySpeed helps take out some of the slop/freeplay. But not all. Alot of the freeplay comes from the yok ball cups. I switched to the opened ball cups from Yok and that helped out some.
Jimmy Mac
JimmyMac is offline   Reply With Quote
Old 10-23-2003, 04:30 PM   #3938
mo
mo's Avatar
KilRuf, is there a package that comes with just the opened ball cups? Do you have a part #? Thanks
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 10-23-2003, 04:59 PM   #3939
JimmyMac's Avatar
Sorry MO, there is not. I had to do it the hard way. ZC-207A comes with 1 pair ball cups and 1 pair openended (swaybar) ball cups. All for the price of 100. It would be nice though if they did.
Old 10-23-2003, 10:08 PM   #3940
NightKidZ's Avatar
Send a message via ICQ to NightKidZ
The open ball cups are a lot less sloppy
I guess its coz they grab the metal ball more securely.
Too bad they packaged them this way.
Cheers
NightKidZ is offline   Reply With Quote
Old 10-23-2003, 11:42 PM   #3941
SpeedTech's Avatar
Hi Guys,
Thanks for the response, I have a company coming in tomorrow to look at the possibility of making the spools...plus other parts as well.
Steve Wang
Old 10-23-2003, 11:44 PM   #3942
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by SpeedTech
Hi Guys,
Steve Wang
C-hubs Steve...think C-hubs
and you might have a bunch of customers in Japan
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 10-24-2003, 01:28 AM   #3943
Matt Howard's Avatar
aluminum gear box halves! The front cover piece could still be plastic but the other half made of aluminum would stiffen the car up a whole lot and more than likely reduce the tweek problems people sometimes get with the car.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-24-2003, 06:53 AM   #3944
asimo's Avatar
I've seen the word 'tweaked' being used to describe something about the chassis.
What do you guys mean by this? not balanced?
I don't know if this was a good idea but today @ Yatabe...
I thought i tried something with my 'black special'. I removed the outer screw for the motor mount and the T-bone plate that sits on the lower chassis, to give it alittle flex.
I'm no expert driver but it seem to be okay.
Should i put them all back into the car?
thanks
asimo is offline   Reply With Quote
Old 10-24-2003, 07:43 AM   #3945
Joel Lagace's Avatar
Smile MY MONTLHY SPRING RATE QUESTION
Ok some time has passed and there are more springs fitting this car than needed. I have some comparison charts but i dont have everything i need.
Again i only need this info so i can use the setup sheets i find with my AE spring set. So far i have all the yokomo spring rates compared to AE from CML DISTRIBUTION.
My current quest is for the spring rates in lb hopefully of the RAYSPEED line of springs. I am not even sure there order form stiff to soft. As there part numbers bounce all over the place.
Here is what i have on the RAYSPEEDS could someone sort them if they are out of order and add there spring rates to this.
RAYSPEED Springs:
RS-10 Shock Spring, Green
RS-09 Shock Spring, Blue
RS-05 Shock Spring, Yellow
RS-06 Shock Spring, White
RS-07 Shock Spring, Red
RS-08 Shock Spring, Gray
Softest down to hardest according to RAYSPEED
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
