Old 10-21-2003, 06:53 PM   #3901
Matt Howard's Avatar
Rick- I honestly don't know what they are "supposed" to be but I'll measure mine later tonight and let you know what mine are.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-21-2003, 07:23 PM   #3902
Registered User
2Tenths's Avatar
Originally posted by Joel Lagace
But if some one is running foams you need to caclute proper roll out and the takes into consideration tire diameter. IF everyone is running rubber then this is fine since most are 62-63mm in diameter but what if your running 60mm foams and im running 54mm? How do we compare ratios then? We need rollout. Your calculation is a final ratio calculation.
You're exactly right. I guess just multiply the rollout number (example: 7.0) times the tire diameter (54mm) and get a final rollout. I'm also running foams, now at about 59mm or so. So for me the rollout is 7 x 59 (413 mm), and you it would be 7 x 54 (378mm). Yes, I know my tires are too big .
2Tenths is offline   Reply With Quote
Old 10-21-2003, 09:33 PM   #3903
THeGame's Avatar
Send a message via AIM to THeGame
Default Matt Howard
Can you email me.
[email protected]
THeGame is offline   Reply With Quote
Old 10-22-2003, 12:19 AM   #3904
Rick- all my rayspeed shocktowers measure 3mm in thickness, I guess you got one that's extra thick there
TheGame- check your mail
RCTech #361
Old 10-22-2003, 04:11 AM   #3905
Guys If you are using foams this is the way to work out the rollout
Tyre diam x 3.1416 divided by spur x pinion divided by 2.35(internal ratio SD
ie: 62 x3.1416 divided by70 x 26 divided by 2.35 = 30.78 rollout
Barger is offline   Reply With Quote
Old 10-22-2003, 04:16 AM   #3906
Also the ideal tyre size.....to get the car going the fastest with any given motor seems to be between 57/58ml. You might have to go bigger on carpet to get ride height.
Old 10-22-2003, 04:50 AM   #3907
Joel Lagace's Avatar
i try to get max life from my tires. I start at 60-61mm and run down as low as 53mm.
The good thing about doing a proper roll out calculation is that u can quickly compare ratios to guys running other cars. Since internal ratios and tire diameters will be different.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 10-22-2003, 06:31 AM   #3908
Built my black SD as kit and shimmed up the diffs as stated in the instructions. I take it the gears will bed in as the transmission is very tight and notchy. Rick
Rick Draper is offline   Reply With Quote
Old 10-22-2003, 08:54 AM   #3909
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Rick they might be just a tad notchy a first. Mine were pretty smooth from the start but they got better and better after each run til they are smooth. The only thing I did was spray out my bearings and re oiled with lighter oil like WD40. That freed the drivetrain up good amount and then I put some Paragon liquid graphite on my gears (it dries in like 30 seconds) and leaves a black thin coating of graphite on my gears. My car is very smooth and the Paragon stuff does not make a mess in the gear case. I check my gears every week or two to check the wear and after about 12 weeks of running 6 to 8 packs a weekend in stock they still look like new. Now my car also has the stock whitish looking gears but I think the new ones are black. I know all my new gears I bought for spares are black.
Run the car once or twice on the track and check it and I'm sure you trans will not have a notchy feeling.
ST Racing Concepts (STRC)
Old 10-22-2003, 10:17 AM   #3910
SpeedTech's Avatar
Hi Rick,
The suggestion from the local Yokomo racers is that run the car with the shims suggest from the instruction, once the gears broken in, then start playing with the amount of shims. Some of the tech calls they get at Yokomo about gear problems usually involves a racer starting to shim the transmission before the gear even breaks in.
On my shaft drive cars, I use a Yokomo MMS and hook it up to a Mabuchi motor, let it run at about 2.5v for 9-12 hours. It makes a huge difference
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 10-22-2003, 11:28 AM   #3911
Registered User
2Tenths's Avatar
Wow Steve, that sounds like a long time! Do you just run the car over night or actually watch it, wait to make sure you don't chip a gear? Is there too much wear on the bearings or gears after running the car so long?
Old 10-22-2003, 12:48 PM   #3912
lonestar1127's Avatar
any guys using Tobee screws for sd?
lonestar1127 is offline   Reply With Quote
Old 10-22-2003, 01:22 PM   #3913
asimo's Avatar
I wasn't aware that there were 2 types of SD's going around the time I picked up mine. Didn't have a good look at the box.
I picked up the "Black Special". I would have grabbed the SSG over the black if I was aware.
I've now learnt that the difference in the chassis is that the Black Special is more rigid compared to the SSG. (correct me if i'm wrong).
Would the black special be suited for tarmac tracks? or would the SSG be the better chassis?
The Rayspeed upgrade kit is Black so I guess the black is better? confusing!!
Just getting back into R/C's... still learning!
Here is a pic of my SD
Oh, i just got the tyre warmers. All the guys who race @ Yatabe seem to get their car sticking so much better around the course I finially knew why! tyre warmers!!! Going to run the car again this friday! can't wait to see the difference they make!
asimo is offline   Reply With Quote
Old 10-22-2003, 01:52 PM   #3914
utieh's Avatar
I bought one set but the screws have a flat head (not hex), i would suggest you to buy the Ti Take Off set.
utieh is offline   Reply With Quote
Old 10-22-2003, 02:11 PM   #3915
the tobee screws doen't come with screw for the shocks??
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
