Old 10-20-2003, 09:45 PM   #3886
Registered User
2Tenths's Avatar
19 turn gearing:
Indoors on carpet with rubber tires, I run a rollout anywhere from 6.7 (open track) to 7.0 (technical track). This rollout is based on the setup sheet equation: (Spur/pinion) x 2.353
2Tenths is offline   Reply With Quote
Old 10-20-2003, 09:50 PM   #3887
JusBox's Avatar
JusBox is offline   Reply With Quote
Old 10-20-2003, 09:52 PM   #3888
forty6's Avatar
Originally posted by Matt Howard
TheGame- I was running the Yokomo stratus type A and I believe Mo was running the stratus 2.0. I have a protoform alfa that I was going to try but I forgot it I was pretty happy with the cars first outing on carpet, we were on pace with the cars right away and the cars will only get better with more track time
Looking at mo's setup, were you guys running the RS chassis? Any tweak problems? Did you have to double up the upper deck?
Thanks.
forty6 is offline   Reply With Quote
Old 10-20-2003, 11:22 PM   #3889
STLNLST's Avatar
Trader Rating: 21 (100%+)
good run last weekend. See you on Saturday if you're running this weekend.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 10-21-2003, 04:45 AM   #3890
Joel Lagace's Avatar
Originally posted by 2Tenths
19 turn gearing:
But if some one is running foams you need to caclute proper roll out and the takes into consideration tire diameter. IF everyone is running rubber then this is fine since most are 62-63mm in diameter but what if your running 60mm foams and im running 54mm? How do we compare ratios then? We need rollout. Your calculation is a final ratio calculation.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 10-21-2003, 07:04 AM   #3891
Matt Howard's Avatar
forty6- We were both running the RS chassis. I did try two upper decks and it did stiffen the car considerably but I didn't feel any tweek problems before that with just one
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-21-2003, 09:38 AM   #3892
PitCrew's Avatar
Does Yokomo pay to advertise here?
PitCrew is offline   Reply With Quote
Old 10-21-2003, 09:41 AM   #3893
PitCrew, let it go already, geez. futureal already addressed your issue with the team birdy thread being shutdown. Pay the advertiser's fee and talk to futureal. This is not the place.
elnitro is offline   Reply With Quote
Old 10-21-2003, 10:27 AM   #3894
Hi all I love The how Chris T. Car spins so Freeeeeeeeeeeeee. man its to amazing. O yeah for you guys that run mod run with Team Suzuki Aluminum Main Shaft Drive cups , The Stock ones will start to crack. chris T uses it.
Yokomo_King is offline   Reply With Quote
Old 10-21-2003, 10:49 AM   #3895
vtl1180ny's Avatar
R/C Tech Charter Subscriber
I hit every LHS withing 25 miles of me and not one carries Yok parts... Can't even match the diff screw, no one carries those metric sizes either.... I have to keep at least 1 spare of any part I can brake, may as well buy a 2nd kit just for parts...
vtl1180ny is offline   Reply With Quote
Old 10-21-2003, 11:09 AM   #3896
forty6's Avatar
Man, how did you manage to break that diff screw? Anyways, it is part # ZS-508. Speedtech should have some.
Old 10-21-2003, 12:07 PM   #3897
Default Rayspeed shock towers
Help, i brought a rayspeed ultimate conversion kit from speedtechrc and the shocktowers that are in the kit are identical in all but one aspect, one is made of 3mm thick carbon and one is 3.5mm carbon. The way i read the instructions is they are both meant to be the same?
Rick
Rick Draper is offline   Reply With Quote
Old 10-21-2003, 12:14 PM   #3898
Rick- they are supposed to the be the same, maybe the graphite was from different batches?
forty6- I've seen the diff screws break before but it was usually running carpet with foam tires. We crank down on the front diff to make it really tight and it stresses the screw pretty good.
Yokomo king- I've gone through a handful of the plastic drive cups already running mod. I put an aluminum one on the rear of my car since that's the only one that's broken so far.
RCTech #361
Old 10-21-2003, 12:29 PM   #3899
Thanks Matt, what thickness are they supposed to be? Rick
Old 10-21-2003, 04:50 PM   #3900
MattSSG's Avatar
where do you have the front shocks what hole on the arm
They are mounted on the second hole from the center of the car.
MattSSG is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
