Old 10-20-2003, 10:08 AM   #3871
THeGame's Avatar
Send a message via AIM to THeGame
Default Matt Howard
I could of used a tad more steering as well. What Body were you guys running ? I was running the Alfa Protoform Mounted alittle bit frwd. Going to Try the Stratus 2.0 see if I can get the steering from the Body...
Are you running Jaco Tires ?
-B
THeGame is offline   Reply With Quote
Old 10-20-2003, 10:10 AM   #3872
THeGame's Avatar
Oh yea on my setup I removed the Lower Deck ..
Old 10-20-2003, 10:52 AM   #3873
Wow, so you have your batteries and electronics floating in the air?
elnitro is offline   Reply With Quote
Old 10-20-2003, 11:19 AM   #3874
Send a message via ICQ to Cobra81li200
I had my answer about the tub chassis.
Actually, M. Hirosaka is having difficulties about the mixing ration between plastic and carbon, that's why no graphite parts have been released for the SD yet. So when the problem will be solved, we'll have loads of graphite parts, including the tub chassis, even if the one showed at the hobby show was indeed a plastic one.
Cobra81li200 is offline   Reply With Quote
Old 10-20-2003, 11:39 AM   #3875
THeGame's Avatar
Sorry about that.. I removed the Middle deck...
Old 10-20-2003, 12:59 PM   #3876
Roger's Avatar
Default 19T gearing
anybody know what gear ratio I need to start off for 19T spec motor ?? Thx guys.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 10-20-2003, 04:11 PM   #3877
mo
mo's Avatar
Finally ran the SD on carpet for the first time this weekend. It ran pretty good, just need to get a little more steering for next time but that is easily done. I have the setup posted on my website if anyone is interested. www.mo-net.ws
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 10-20-2003, 04:20 PM   #3878
Fire's Avatar
Default Re: 19T gearing
i tried 26/70 with a chameleon 2 and it undergears a bit. i gonna try maybe 27 or 28
Fire is offline   Reply With Quote
Old 10-20-2003, 08:17 PM   #3879
Joel Lagace's Avatar
I run 19T on a 80ft carpet track we run rollouts of between 24-26
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 10-20-2003, 08:57 PM   #3880
Matt Howard's Avatar
TheGame- I was running the Yokomo stratus type A and I believe Mo was running the stratus 2.0. I have a protoform alfa that I was going to try but I forgot it I was pretty happy with the cars first outing on carpet, we were on pace with the cars right away and the cars will only get better with more track time
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-20-2003, 09:12 PM   #3881
GeorgePravata's Avatar
Trader Rating: 108 (100%+)
Hey matt do you run TRC foams on your sd and do they hit the front shocks
GeorgePravata is offline   Reply With Quote
Old 10-20-2003, 09:19 PM   #3882
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Well, I finally got a glimpse of the track for the winter season... No straight away at all... Going to need a heck of a lot of steering and a loose rear end... Very technical track....
vtl1180ny is offline   Reply With Quote
Old 10-20-2003, 09:20 PM   #3883
MattSSG's Avatar
I run TRC's on the front with no extra offset and they don't rub on the front shocks at full throw. But the rear shocks on the outer hole will rub unless you have 2mm worth of spacers.
MattSSG is offline   Reply With Quote
Old 10-20-2003, 09:21 PM   #3884
where do you race in NY we race at this track in LI Southshorehobbies
Old 10-20-2003, 09:22 PM   #3885
where do you have the front shocks what hole on the arm
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
