Old 10-19-2003, 08:42 AM   #3856
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Matt and racers with Carpet Experence...When you talk about cutting down the foam tires to fit I take it you are cutting the rim to clear the front steering area. What technique are you using to do this? I may be doing some carpet racing this winter and could use some hints.
The talk of a tub is an interesting one. Does yokomo have plans to release one soon?
Thanks for the help.
Jeff
Jeff Werner is offline   Reply With Quote
Old 10-19-2003, 09:09 AM   #3857
Matt Howard's Avatar
Jeff- while the tire is on the truer I just took an Xacto knife to the inside of the tire and cut both the tire and rim off by 1-2 mm. Mo went a different direction and just took a little material off of his aluminum steering knuckles so the full size rim will fit. That way will work with the aluminum knuckles but I wouldn't recommend it with the plastic ones.
Kilruf- I got the shooters mounts from precisionrc.com, I don't know of anywhere in the states that sells them but precisionrc was pretty fast shipping them to me. I went with the "regular" shipping and still got them in 4-5 days.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-19-2003, 10:29 AM   #3858
Send a message via ICQ to Cobra81li200
Jeff, read my precedent post...
Cobra81li200 is offline   Reply With Quote
Old 10-19-2003, 01:32 PM   #3859
Can anyone help would the Rayspeed chassis work well on a polished wooded floor?
mark turner is offline   Reply With Quote
Old 10-19-2003, 01:59 PM   #3860
Registered User
2Tenths's Avatar
I am almost positive that the tub to be released in November will be a plastic (not graphite) version. Looking at the pics from the Japanese Hobby show, the material on the tub car there is definently not graphite. Our only hope is that they release both versions of the tub at once, or release the graphite one soon after !
2Tenths is offline   Reply With Quote
Old 10-19-2003, 06:02 PM   #3861
JimmyMac's Avatar
I think someone else asked where to get the Shooter deck mounts. I already had some from Precision. But they got bent when someone T-boned my car. So I'm back to my Team Suzuki mounts.
Well I was running the car today for practice. I noticed the inside wheel flopping during a turn. I could manually turn it by hand and noticed no binding. But then I nail it with wheels turned, it would flop. Wondering if anyone else has experienced this. I might go over the axles and rebuild them again. I can turn the dual rates down. But it still happens. I might try some universals to see how they work. I figure I'm scrubbing some good speed in the turns as well as loosing some steering that I've been looking for.
Hmmmmmm
JimmyMac is offline   Reply With Quote
Old 10-19-2003, 09:47 PM   #3862
THeGame's Avatar
Send a message via AIM to THeGame
Default Sd Carpet/Foam Set
This is a good starting point for the Sd on carpet with foams..
THeGame is offline   Reply With Quote
Old 10-19-2003, 11:08 PM   #3863
Fire's Avatar
I just ran my SD for the first time today
with the stock shimming the drive train was tight but it loosen up a lot after 5 min or so with a 19T
the car feels like an old friend even with crappy tires from a few years ago before i switched to nitro
good job yokomo
Fire is offline   Reply With Quote
Old 10-20-2003, 12:00 AM   #3864
JusBox's Avatar
Question about removing the main drive shart... in the directions it says for easy removal you can slide the drive cup back (after removing the pin) and then remove the shaft. Mine fits so tight that even after sliding the cup back, I have to force the [email protected] thing out. Anyone else experience this? Any fix ideas?
JusBox is offline   Reply With Quote
Old 10-20-2003, 05:57 AM   #3865
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Make sure you are sliding the rear drive cup back. Then push your drive shaft forward and it slide out pretty easy. Just had mine out last night and I don't really need to force it in and out.
ST Racing Concepts (STRC)
Old 10-20-2003, 06:14 AM   #3866
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default CHECK OUT THE YOKOMO SD ON EBAY!!
Item number: 3149766749
LIKE NEW YOKOMO SD BLACK EDITION WITH TONS OF SPARE AND HOP UPS ON EBAY...AUCTION ENDS TODAY AND THE PRICE IS STILL LOW....GO CHECK IT OUT...HAPPY BIDDING.
J.Gonzalez is offline   Reply With Quote
Old 10-20-2003, 07:11 AM   #3867
TheGame- that setup is pretty close to what I ran this weekend, I had my arms spaced in the middle front and rear with AE copper springs though. I'll try yours next time as both me and Mo were looking for just a little more steering. Not bad for the first time out for us though, Mo won and I took third
RCTech #361
Old 10-20-2003, 07:58 AM   #3868
Wish the courior would hurry up and deliver my black SD and rayspeed kit, its on the van for todays deliverys but they aint shown up yet The wait is doing me in! Rick
Rick Draper is offline   Reply With Quote
Old 10-20-2003, 08:09 AM   #3869
JusBox's Avatar
Yah I slid it all the way back... i'll check again though. Maybe mine just fits a bit tight.
Old 10-20-2003, 08:48 AM   #3870
peter_robinson's Avatar
Trader Rating: 21 (100%+)
you will still be able to run a top deck with this chassis, i don't know why people are so worried about it being to flexible
the tub chassis wil solove alot of problems for running on carpet with foams. in high grip applications such as this, the car is very easily tweaked, and having the tub will help to stop this.
For orders or inquiries, email [email protected] Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
