Old 10-16-2003, 07:29 PM   #3826
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Speedtech has great setup for us racers. He really does hlep to keep us imformed of the new stuff that is coming in.
ST Racing Concepts (STRC)
Old 10-16-2003, 08:15 PM   #3827
Wyd RCO or not this weekend ?
Kash is offline   Reply With Quote
Old 10-16-2003, 10:24 PM   #3828
wyd
Tech Legend
wyd's Avatar
Next weekend I will be ready. Riding the 4 wheeler this weekend plus my car is getting a face lift as well as new paint job, speedo, servo, shack towers, and chassis. Not everything will be done in time.
Old 10-17-2003, 10:51 AM   #3829
Matt Howard's Avatar
who let Kash on a computer? LOL, he probably doesn't even remember me
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-17-2003, 01:05 PM   #3830
Barry White's Avatar
Does anyone know the exact diameter and height of the Rayspeed shockpistons? Would the fit in HPI shocks?
Thanks,
Barry White is offline   Reply With Quote
Old 10-17-2003, 01:08 PM   #3831
rc-zombies's Avatar
Thanks,
They should fit fine... I use HPI pistons when I had my SD...
Old 10-17-2003, 01:25 PM   #3832
forty6's Avatar
Stock SD pistons work just fine.
forty6 is offline   Reply With Quote
Old 10-17-2003, 02:53 PM   #3833
Default Alum. knuckles?
Are the aluminum steering blocks (knuckles) worth it? For $35 I can buy at least 8 regular ones. I seriously doubt I'll break that many. Is it mainly for the bling, or are they really that much better?
Rampant is offline   Reply With Quote
Old 10-17-2003, 03:00 PM   #3834
wyd
Tech Legend
wyd's Avatar
Hey Matt I'm sure Kash remembers as he would have always been behind you.
Ok my Rayspeed Conversion is about done. Just need to add my speedo (new one will be in next week). Servo is in and soe is the receiver. I used the stock SSS shocks with the long ball ends and RS alum. spring retainers. I had no problem getting the ride height I needed with foams so I'm pretty happy. My shocks are at 64mm for the front and rear. Car looks great.
Old 10-17-2003, 03:16 PM   #3835
rc-zombies's Avatar
Default Re: Alum. knuckles?
The Suzuki aluminum knuckles have a different offset than stock.
Gives you slightly better steering response.
Old 10-17-2003, 07:10 PM   #3836
MattSSG's Avatar
Does anybody know a setup that works well on a carpet track with high traction and a slightly bumpy surface. Im using a stock motor and the SSS shock bodies. Currently I have 60wt oil in the front with green springs, mounted middle on top and outside on bottom, and a stock swaybar. On the rear I have 40wt oil and Stainless springs, mounted the lower outside hole on the tower and outside on the bottom. For tires im running 26mm Cyan fronts and 26mm Tan rears of Trinity TRCs. Ride hieght is at 5mm all round. The problem im having is that it has too much steering when im under braking or neutral throtle, and when I apply power it understeers. It used to be very unsettled or very difficult to drive coming into a corner until i put greens on the front then it was easier to enter the coner. But this made the understeer a little worse. Any suggestions? Thanks for the help.
MattSSG is offline   Reply With Quote
Old 10-17-2003, 09:18 PM   #3837
wyd
Tech Legend
wyd's Avatar
MattSSG I would run a bigger front sway than the stock one. The stock one don't do much of anything.
I normally run Plaid fronts and purple rears. Purples have always hooked up great for me in the rear. If you run Yoke springs I would run Orange fronts and either orange rears or green rears.
Old 10-18-2003, 03:32 PM   #3838
forty6's Avatar
Any feedbacks on the RS Chassis on carpet? Anybody? Thanks.
Old 10-18-2003, 04:55 PM   #3839
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Anyone know what size screw the diffs take??? I snapped the front one...
vtl1180ny is offline   Reply With Quote
Old 10-18-2003, 07:46 PM   #3840
JimmyMac's Avatar
What screw, the long thin one to hold the diff? Oh yeah, the diffs only have one screw... oneways have more, duhhh what was I thinking!! haha. Hmmmmm. I dunno, head is 2mm wrench. Part number is ZS-508. That's all I know.
Forty6, it flexs too much for carpet. I tried already and the chassis tweaks easy.
JimmyMac is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
