Old 10-14-2003, 05:10 PM   #3781
JimmyMac's Avatar
Yes you do, I think it's about 8mm wider on each side. Something like that.
JimmyMac is offline   Reply With Quote
Old 10-14-2003, 05:26 PM   #3782
forty6's Avatar
Will the RS steering rack work with the stock chassis?
forty6 is offline   Reply With Quote
Old 10-14-2003, 05:26 PM   #3783
Fire's Avatar
I have a question
what modifications i need to do to make the MR4TC's hardened universal works on the SD??
there are plenty of those in the LHS
Fire is offline   Reply With Quote
Old 10-14-2003, 06:52 PM   #3784
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Ok, somehow my diff is now warped... Figures... Opening day for my carpet season is sunday...
vtl1180ny is offline   Reply With Quote
Old 10-14-2003, 07:34 PM   #3785
Matt Howard's Avatar
forty6- no it will not work, the rayspeed setup is spaced back a bit.
fire- the rears will work with no modifications but the fronts you need to grind down the end of the drive shaft or it will be too long, grind it down until it's even with the drive pins
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-14-2003, 07:37 PM   #3786
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Matt what length shocks do you run with your Rayspeed Conversion?
ST Racing Concepts (STRC)
Old 10-14-2003, 09:14 PM   #3787
rookie80's Avatar
Default RS steering rack on SSG
i cant seem to display the pics here..seems my website got some hotlinking problem..
anyway.. managed to install the RS steering on the SD.. the centre stiffner post had to be taken out and the part where it made contact with the steering nut had to be sanded down..
alternatively u can just take out the whole centre stiffener...
Oh and you need to get one pair of servo set ( the one with the spring and the collar.. can use the ones used for mr4tc custom or SP as well) and a pair of arms thingy
Pic1
Pic2
Pic3
Pic4
Pic5
Last one!
rookie80 is offline   Reply With Quote
Old 10-14-2003, 09:14 PM   #3788
THeGame's Avatar
Send a message via AIM to THeGame
Default forty6
I'm using the Rayspeed steering rack on the stock Chassis. You just cant use the Rayspeed upper deck then.
THeGame is offline   Reply With Quote
Old 10-14-2003, 09:20 PM   #3789
forty6's Avatar
Thanks rookie and the game. I am planning on keeping the my stock chassis. Was the mod worth it? I mean, did the car seem to be more responsive with it installed?
Old 10-14-2003, 10:16 PM   #3790
SpeedTech's Avatar
Originally posted by wyd
Hey Steve I ordered my Rayspeed setup today.
Wyd,
I saw that, and it was shipped out today, thank you very much
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 10-14-2003, 10:19 PM   #3791
SpeedTech's Avatar
Kilruf, vtl1180ny,
The tobee stuff are on their way. Tobee Craft Japan is very fast on shipping out our order
The Rayspeed stuff we're just waiting on Yokomo USA
Steve Wang
Old 10-15-2003, 02:13 AM   #3792
IH
IH's Avatar
Thanks KilRuf!
Another question regarding the universals: Do you guys "grease" your universals(like shown in the manual)? When running outdoors I do not grease mine because I find that it attracts to much dirt. But what about indoors?
Do you use Loctite when assemling the little set screw?
Regards,
ingo
IH is offline   Reply With Quote
Old 10-15-2003, 05:06 AM   #3793
Guys,
I have just ordered a Rayspeed conv kit adn would like to know if I can use the standard Shocks or I should buy the GT4 longer shocks ?
Thanks for your reply.
Ralf is offline   Reply With Quote
Old 10-15-2003, 06:53 AM   #3794
Ralf- when I built my shocks I took the spacer thingy that's in the shock body and cut it so only the triangle part is there, giving me a longer shock. Since I did that I was able to use the regular shocks on my rayspeed conversion but you still need to use the longer shock ends
IH- I don't grease my universals either because like you said, it attracts dirt. I recommend using locktite on the little setscrew as well, they always loosen at the worst time
RCTech #361
Old 10-15-2003, 07:04 AM   #3795
Matt,
Thank you for your reply,
I will buy the longer shocks, that will make my life easier...
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
