Yokomo MR-4TC SD
#3691
Originally posted by KilRuf
So to use front harden axles/bones, you just need to order the Front set for a MR4TC (belted) car and flaten the ends at the pins right? Sounds easy enough. I may have to switch to them eventually.
Sounds like the Tobee Craft shaft is the one to have then. I wonder if superglueing the Yokomo Graphite Shaft will help it's strength some? I dunno, I'll play around with it some.
#3692
Then the front MIP Shiny cvds for the MR4TC belt car will have the same fit. Right?
#3693
Gear Ration for SD
Hi, I'm confused of the Gear Ratio as I need u guys to help mi out.
I using a 10turn, 11turn, 15turn and a 23 turn Stock Motor.
Can everyone advise me what the best Final gear ration for the above 4 motors.
#3694
Re: Gear Ration for SD
there's no hard and fast final gear ratio for the motors, each different track requires a different ratio for each of the motors. you need to go down to the track to test and find out for yourself which ratio is the best. another thing is that for the same turn of motor but by different manufacturer also requires different gearing. just my s$0.002 worth......
#3695
thanks alan,
The manaul that i have for my SD is Japanese. Catch no balls and juz look at the picture only. Are u racing this end of the month at Nacos.
I heard the all the mains are rewarded with $.
U shall be no problem lah, lao qiao already. Me still long way to go and match u leh. me just go there to hope for lucky draw and get some experience lah. hee.eee.eee
#3696
Basically, don't spend the $20 on the MIP axles and instead, if you want to have a stronger axle, spend $16 and get the Tobee Craft hardened stub axles from Rainbow Ten or SpeedTech. The $16 is for the front and rear stub axles. (8 dollars a pair)
These don't replace the dogbone, but they are much thicker than the brittle kit axle.
#3697
I think the Rayspeed shock towers are sold out at rainbowten
#3698
The body Masami ran to win the Japan Nats is going to be sold by Yokomo, as a Yokomo part. I looked on Yokomo's main site and it is listed under new products as the "G350GT Sports Sedan" body. I thought Chevron made this body, but I guess Yok bought the rights to it or they are going to make it themselves. Anyways, this should make it easier to get, I hope, and when someone buys one, they should post on how it handles compared to a Protoform Stratus or Alfa.
#3699
The body still has a Chevron Models part number on it on the Yokomo website.
#3700
#3701
Howdy folks,
I finally ran the car with its final setup yesterday night... this thing's a total dream! Going to the rear shock tower up front was a major improvement over steering quality overall, without making the car too twitchy... The SD is close to the best I've driven till now, although it's only run a dozen packs so far. I love it!
Later,
Paul
Later,
Paul
#3703
Just got my paws on the new Yokomo/Chervon G350GT shell.
Must say, I was surprised at how slammed it was. Plus there were two very interesting points about that shell.
1) It comes with two strips of lexan cross bracing for the shell to prevent it from caving in at high speeds.
2) Dajiro Kato (late MotoGP star) personalize number "74" is on the rear wheel flashing of the shell.
Cheers
Cheers
#3705
Originally posted by ongbenghui
Hi lonestar,
Mind if you can share your setup ?
Hi lonestar,
Front:
stock springs
35wt piston #2 (Stock)
no foam, short shock end
A-arm hole 2nd from inside
rear shock tower upfront, shocks layed down to max
camber link: C-hub most outside hole, shock tower lowet row, second from inside hole
ride height 4mm
0 deg tow out 1deg camber
A-arms position: 1mm shim in back
rear:
stock springs
no foam, lonf shock end
A-arm hole 2nd from outside
shock tower highest hole,
camber link: hub 2nd hole from outside, shock tower lowest row second from inside hole
ride height 4.5mm
3 deg tow in 1 deg camber
A-arms position: 2mm shim in back
Orion B-type tires (spec), on carpet, tire suace TC2 30 min rear 10mn front 100% , 2 diffs (can't drive a one way on carpet to save my life). No swaybars.
if I forgot anything, it's because it's stock (for instance droop settings), as per the instructions
Car is VERY easy and super smooth in sweepers and chicanes. beautiful motricity.
Enjoy, and don't blame me if you don't like it! I do
Later
Paul
