Old 10-05-2003, 10:17 PM   #3676
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default RE: SD for sale
I run with a couple of full factory drivers for losi. I am getting tired of trying to reinvent the wheel with setups. Basically I am the only person driving a yokomo in my area. I primarly run on carpet in the winter with foam tires and I have been struggling with setup with the car. I have only used the car for about 3 weeks but Cleveland is getting closer every day.
It is tough to concentrate of driving and setup.
I drove Mike Dumas Losi and was very happy with overall grip and balance.
If you cant beat them join them!
I always liked the way the car worked on rubber tires.
J.Gonzalez is offline   Reply With Quote
Old 10-05-2003, 10:47 PM   #3677
NightKidZ's Avatar
Send a message via ICQ to NightKidZ
Originally posted by Kenneth Tan
I have used the exact same Yok carbon shaft without any problems for 4-5 consecutive mod races with 9-10 turn motors WITHOUT any problems... YET.
Kenneth,
If thats the case, good for you.
Will advise you these two things
1) Check the two cross pins on the end of the graphite shaft, they should line up. Mine dun anymore.
2) Take the graphite shaft out of the car. Hold the two cross pins in your hands and twist the shaft like how you squeeze dry a wet towel. A faulty shaft will twist about 20-30 degrees when sujected to that test, and feels 'rubbery'.
Cheers
NightKidZ is offline   Reply With Quote
Old 10-06-2003, 01:39 PM   #3678
Send a message via AIM to munrath
Senna555,
Check your PM.
Mark
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 10-07-2003, 02:08 AM   #3679
Lonestar's Avatar
Did you say "torque-control device"? Maybe we're up to something here...
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 10-07-2003, 02:15 AM   #3680
Kenneth Tan's Avatar
Kenneth,
Cheers
Thank goodness. No problems like you mentioned in points 1 and 2 yet...
Kenneth Tan is offline   Reply With Quote
Old 10-07-2003, 01:45 PM   #3681
Registered User
2Tenths's Avatar
Personally, I'd recommend the Tobee Craft aluminum center shaft if you are having problems with breaking the graphite one. It is very light and I've been running it for monthes in 19T class with no problems. I do not know exactly how it compares weight wise, but it is definently lighter than the heavy Yokomo center shaft that comes in the kit.
2Tenths is offline   Reply With Quote
Old 10-07-2003, 04:38 PM   #3682
peter_robinson's Avatar
Trader Rating: 21 (100%+)
i think that going lighter and lighter in the drivetrain is just a gimmick. yes there are some advantages such as increased acceleration, but is it really so much of an advantage that you can say you lost a race because your center shaft was 7 grams heavier than the guy that beat you... i think not.
the important part it a drivetrain that is smooth and not binding, something that the yokomo already has.
For orders or inquiries, email [email protected] Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 10-07-2003, 04:41 PM   #3683
AllPimpRacing's Avatar
Send a message via ICQ to AllPimpRacing Send a message via AIM to AllPimpRacing
Hey All, Just ran my SD for the first time in a race and i have to say, its the best handeling car i've ever driven. Man, all i did was point it in the direction i wanted to go and it went. However, for the first time ever, i had my CVD pins back out and eventually melted the plastic untill it broke. The righ one in the first qualifier and then the left on the 2nd qualifier. Guess i sould have put that heat shrink over then... Anyway, going to order the aluminum ones right now, so that atleast wont happen again!
AllPimpRacing is offline   Reply With Quote
Old 10-07-2003, 05:12 PM   #3684
JimmyMac's Avatar
Anyone try the Shooters Graphite main shaft? I'm wondering if it's hollow like the original TC3 shaft or strandy like the Yokomo Graphite shaft. I think I'll stray away from anything that reminds me of a thick pencil lead.......
JimmyMac is offline   Reply With Quote
Old 10-07-2003, 06:18 PM   #3685
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Johnbull weighed the Yokomo lightweight shaft at 6 grams and the Tobee lightweight alum. one at 7 grams. The stock shaft was like 14 grams.
ST Racing Concepts (STRC)
Old 10-07-2003, 07:25 PM   #3686
GO TOBEE GO!
Old 10-07-2003, 08:42 PM   #3687
Roger's Avatar
hummm. I wouldn't get the aluminum units if I were you. The axle is one of the weak points of the car cause they're brittle. Do yourself a favor and buy the harderned front and rear universals for the MR4-TC. They're a direct bolt-on. If you use the front one-way with the universals, just remove the rubber o-rings that sits in the drive cups. I've broke 2 axles at the point where that pin sits. I went into the hobbyshop and found out that they were complete out cause everybody kept braking them.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 10-07-2003, 09:18 PM   #3688
vtl1180ny's Avatar
R/C Tech Charter Subscriber
I'm put the titanium axels on mine with the stock shafts, my track still isn't open so I have yet to see how they hold up...
vtl1180ny is offline   Reply With Quote
Old 10-07-2003, 10:12 PM   #3689
mo
mo's Avatar
I think the best solution to the front axles is to run the hardened front universals from the MR4-TC. You have to modify them a little but they are much stronger than the cvd's. All you have to do is gind the ball by the inner pins down flat and they fit right in. As for the main shaft, I have been running the tobee shaft for a few months, modified only, and it is still perfectly straight. I think it is the best option.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 10-07-2003, 10:39 PM   #3690
JimmyMac's Avatar
So to use front harden axles/bones, you just need to order the Front set for a MR4TC (belted) car and flaten the ends at the pins right? Sounds easy enough. I may have to switch to them eventually.
Sounds like the Tobee Craft shaft is the one to have then. I wonder if superglueing the Yokomo Graphite Shaft will help it's strength some? I dunno, I'll play around with it some.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
