Old 10-05-2003, 05:14 PM   #3661
R/C Tech Founder
R/C Tech Charter Subscriber
Dang it. I usually prefer to run Jaco and I have a ton of them.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 10-05-2003, 06:06 PM   #3662
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
When I run the Jacos I just take an exacto blade and cut off 2mm off of them on my tire machine. It is a little bit of a pain but you can still use up your Jacos then. I think CRC makes some 26mm and Speedmind to. Jaco also makes some 24mm but they seem a tad bit narrow and the wear a tad bit more.
ST Racing Concepts (STRC)
Old 10-05-2003, 06:08 PM   #3663
vtl1180ny's Avatar
I have a set of HPI 30mm's that'll fit front and rear without rubbing... My Team Orion 26mm, the webbing on the inside of the weel tends to run very slightly, haven't tried the Arrows on the front...
vtl1180ny is offline   Reply With Quote
Old 10-05-2003, 06:12 PM   #3664
JimmyMac's Avatar
Actually my rubber tires rub on the front shock spring cups with the 2nd from outter position. As for Foam tires, if you use Yokomo inchup 32mm wheels they fit in the rear with 2nd from outter hole on arm. For front, Yokomo inchup 26mm with 2nd from inside hole on arm.
Jeff, I didn't have a good setup at all at the Durham/Nationals Track. I have only raced at that track once since the Nationals. They aren't getting enough people to show up to race. I race here at my local track. I like it better. Smaller and nicely laid out. And blah blah blah. Track surface is similar. And it's both sweeping and technical. I'll try and get a pic of my setup. Just gotta find certain things first. Maybe I'll just take a pic of it.. haha. Do you use RaySpeed Springs or Yok? Stock SSG chassis? I'll go looking and post one up later on for ya.
Anyways, let me go back and change my setup to carpet....
JMac
JimmyMac is offline   Reply With Quote
Old 10-05-2003, 06:37 PM   #3665
Registered User
2Tenths's Avatar
I just found this picture/article on a Japanese RC magazine's website, it is an SD (of course) with a ride air intake (to the motor) and, maybe a tub chassis ??? Whatever it is, it looks coooooool!!!!
2Tenths is offline   Reply With Quote
Old 10-05-2003, 07:10 PM   #3666
Hi Guys I run out doors on a medium grip tarmac track and have used FAST tyres(same as elligi).I use 26 mill 42 front 40 rear,They come already mounted and only cost about $25 Australian.They last well and just clear the rear rim(I do not use the outside hole on the front)
Barger is offline   Reply With Quote
Old 10-05-2003, 07:48 PM   #3667
Registered User
2Tenths's Avatar
I finally got around to taking pictures of my SD, so here it is. It is equipped with Rayspeed, Tobee Craft, Shooters, and Suzuki parts. I've cut material out of the battery brace, used a top-mounted sway bar on the rear (lower position), and use 2 Rayspeed top decks. This car is driven on carpet with foam tires. I hope this gives people some ideas for their cars.
Old 10-05-2003, 08:05 PM   #3668
Kenneth Tan's Avatar
Originally posted by NightKidZ
Stand by for broadcast, stand by for broadcast :P
Graphite shaft NOT recommended even for stock 23 turn use.
I say again, Graphite shaft NOT recomended even for stock 23 turn use.
End of broadcast :P
I have used the exact same Yok carbon shaft without any problems for 4-5 consecutive mod races with 9-10 turn motors WITHOUT any problems... YET.
Kenneth Tan is offline   Reply With Quote
Old 10-05-2003, 08:43 PM   #3669
Originally posted by Isaac
Ok am I correct? The rear shock tower gives more steering and if so is it more on power steering?
Is this right?
Isaac is offline   Reply With Quote
Old 10-05-2003, 09:02 PM   #3670
wyd
Tech Legend
wyd's Avatar
When I put the rear tower on the front I gained a ton of steering going into the corner off power.
Old 10-05-2003, 09:08 PM   #3671
and on power coming out?
wilsonproperties1.com
Old 10-05-2003, 09:12 PM   #3672
wyd
Tech Legend
wyd's Avatar
It seemed to have a ton all around. I nornally have alot of steering coming out since I have a spool in. I really noticed the extra steering going in. If you switch you won't loose any steering coming out. If anything you would gain a little more.
Old 10-05-2003, 09:18 PM   #3673
Well I'm trying to gain some coming out.
Old 10-05-2003, 10:03 PM   #3674
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default Selling my Black Sd Special
I am selling my yokomo. I figured I would give the guys at rctech a chance before I post it on ebay.
Yokomo Black SD
-super nice custom painted protoform
alfa 2.0
-one way
-all springs avaible
-tobee craft lightweight drivetrain
-tobee battery holder
-2 sway bar kits
-atheena project shock towers
for front and rear..super nice
-spare arms, hub carriers, spindle, diffs,3 axles and lots
of misc parts.
-F/R set of takeoff tires cs 27
Email me for details,pics, and price is your are interested.
Jamie
J.Gonzalez is offline   Reply With Quote
Old 10-05-2003, 10:04 PM   #3675
Trader Rating: 7 (89%+)
Sounds like a nice ride why are you selling?
Bubbasteponit is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
