Old 10-04-2003, 11:35 AM   #3631
racer's Avatar
a rear bumper perhaps?
racer is offline   Reply With Quote
Old 10-04-2003, 12:39 PM   #3632
IH
IH's Avatar
Thanks Joel
I will try to get that Buds bumper. Post pics asap.
IH is offline   Reply With Quote
Old 10-04-2003, 01:37 PM   #3633
forty6's Avatar
2tenths, hopefully it is good on carpet as it is on asphalt. You guys run on carpet right?
forty6 is offline   Reply With Quote
Old 10-04-2003, 01:44 PM   #3634
Registered User
2Tenths's Avatar
forty6 - Thats right. We are now running the indoor winter season 19T class on carpet with foam tires. I was a little concerned that this chassis might be too flexible for carpet, but I haven't run it yet to see.
I do know, however, that moving the battery forward (using the wheelbase adjustment) did help my old SD chassis handle much better on carpet, and I hope that this chassis (which moves the batt even farther forward) will help that much more.
2Tenths is offline   Reply With Quote
Old 10-04-2003, 01:50 PM   #3635
forty6's Avatar
Yeah, do let us know how it compares to the stock chassis with double upper deck on carpet.
Old 10-04-2003, 02:01 PM   #3636
forty6's Avatar
Default Re: TWO QUESTIONS??????
Originally posted by CustomfibreR/C
Hello All,
I was considering retiring my Evo III Surikarn and trying a SD for a change but I have a few questions regarding the kit.
Firstly what is the better version to get, the SSG or the Standard Carbon Fibre. What I want to know really is Besides just looks Is there a difference in weight, stiffness etc.
Finally will a Novak SS System fit in the car without a struggle???
Thanks for your help.
I have the SSG myself and it is pretty stiff. I heard that the black one is stiffer, but I haven't driven one myself to know. As for the Novak SS, I have seen one on an SD although the guy did the 90 deg servo mod, and mounted his receiver on the upper deck. Just a note, he was also using a Futaba 9550 servo.
Old 10-04-2003, 02:52 PM   #3637
CustomfibreR/C :
MarNaDaKi is offline   Reply With Quote
Old 10-04-2003, 03:32 PM   #3638
forty6's Avatar
Originally posted by MarNaDaKi
CustomfibreR/C :
MarNaDaki, what ball link you are using, Trinity? (flourescent yellow)
Old 10-04-2003, 03:58 PM   #3639
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Yok racers- what is your take on the SD with a one way? Going to run on a very large sweeping track in two weeks for a regional race and have not ran a oneway in the yok. Going to be running mod sedan. Thanks for any thoughts.
Jeff
Jeff Werner is offline   Reply With Quote
Old 10-04-2003, 04:03 PM   #3640
AllPimpRacing's Avatar
Send a message via ICQ to AllPimpRacing Send a message via AIM to AllPimpRacing
Default One Way
Jeff, Just installed a oneway yesterday and ran just a few howers ago. I know that it helped me carry more speed throughout the corners. The track seamed to be set perfectly for the oneway, very open with sweeping corners. I'm glad i went to using it, it seams to have made a BIG diffrence
AllPimpRacing is offline   Reply With Quote
Old 10-04-2003, 06:31 PM   #3641
forty6:
No. Those are Kyosho 5.8mm ball ends. I had to dremel them a tad on their far edge to clear the diff case if I wanted to use the inner camber link holes.
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXT484
Old 10-04-2003, 07:28 PM   #3642
Default sweet ride MarNaDaki
nice........
rclab1 is offline   Reply With Quote
Old 10-04-2003, 08:45 PM   #3643
Are those ball ends pretty slop free?
elnitro is offline   Reply With Quote
Old 10-04-2003, 09:27 PM   #3644
Hi,
Sorry for the long post, but would I need anymore parts other than these below to build a SD?
RS-19 - Conversion Set for MRTC-SD
RS-15 - Spring Cups (Long Spring Type, 2 Ea)
TS-2103 - Aluminum Center Drive Cups (MR-4TC SD)
TS-2102 (x2) - Aluminum Upper Deck Mount (MR-4TC SD)
TS-2101 - Aluminum Rear Hub Carriers (MR-4TC SD)
TS-2100 - Aluminum Steering Blocks (MR-4TC SD)
SD-118 - Battery Plate and Mount Set
SD-118M - Aluminum Battery Posts
SD-300FF0 - Aluminum Front Suspension Mount
SD-300FR - Aluminum Front Suspension Mount (Rear-Side)
SD-300RF - Aluminum Rear Suspension Mount (Front-Side)
SD-300RR2 - Aluminum Rear Suspension Mount
SD-640T - HD Front One-way Assembly
SD-BBP - Precision Bearing Kit 23pcs/set
SD-TSS - Yokomo MR-4TCSD Titanium Screw Set
SD-001 - Yokomo MR-4TCSD Front Plastic Bumper
SD-001FS - Yokomo MR-4TCSD Urethane Foam Bumper
SD-302 (x2) - Yokomo MR-4TCSD Transmission Case
SD-007T - Yokomo MR-4TCSD Upper I-Arm Set
ZC-206S - Yokomo MR-4TCSD Titanium Ball Studs
SD-401HC - Yokomo MR-4TCSD Carrier Balls
SD-008 (x2) - Yokomo MR-4TCSD Suspension Arms Set
SD-009 - Yokomo MR-4TCSD Suspension Hinge Pin Set
SD-4134 - Yokomo MR-4TCSD Front Steering Hub Carrier
ZC-207A - Yokomo MR-4TCSD Anti-Roll Bar Plastic Parts
SD-644 - Yokomo MR-4TCSD Aluminum Main Drive Shaft
SD-501 - Diff Joints / Drive Cups (Front and Rear)
SD-501R - Yokomo MR-4TCSD Aluminum Diff Joint Rings
SD-503 - Yokomo MR-4TCSD Ring Gear/Drive Gear Set (Diff)
ZS-506 - Yokomo MR-4TC Diff Rings
ZS-412FSP - Front Sway Bar kit for MR-4TC
ZC-N4AFB - Yokomo 4mm Flanged Aluminum Lock Nuts
ZD-505T - Yokomo 3/32 Tungsten Carbide Diff Balls
ZC-507T - Yokomo 1/16 Tungsten Carbide Thrust Balls
SD-010FS - Low-Friction Universal Driveshafts, Front (Steel)
ZS-010RS - Low-Friction Universal Driveshafts, Rear (Steel)
ZS-011C (x2) - Aluminum Clamp Wheel Hubs (Blue Anodized)
ZC-S50S - 5mm Shim Set, Stainless Thin Type
ZC-S80S - 8mm Shim Set, Stainless Thin Type
ZC-S100S - 10mm Shim Set, Stainless Thin Type
SG-64104 - Precision 64 Pitch Spur Gear, 104T
ZS-508 - Diff Adjusting Screw Kit
YS-1SS-6 (x2) - Low-Friction Aluminum Shock Set, Long Shock
Body
SD-200B - Yokomo MR-4TCSD Servo Saver Mounts (Blue)
SD-204 - Yokomo MR-4TCSD Servo Horn Set
ZM-202G - Yokomo MR-4TCSD Graphite Servo Saver Parts
TC42370 - Tobee Craft Aluminum Front and Rear input Shaft
TC42390 - Tobee Craft Super Spur gear holder
TC42460 - Tobee Craft light weight aluminum king pins
TC42570 - Tobee Craft aluminum front body mount
TC42580 - Tobee Craft aluminum rear body posts
TC42600 - Tobee Craft hardened steel front universal axles
TC42610 - Tobee Craft hardened steel rear universal axles
The reason I ask this is because I want to build up a SD like the Rayspeed one pictured on the Yokomo USA site. I think I've got all the parts there, plus some others, just asking you guys for any opinions or to point out anything I have left out, as I don't have a SD (yet) . The only thing I have not listed are the turnbuckles and ball cups, as I could not find any part numbers for them, so could you guys please post them?
Thanks a lot, and again, sorry for the long post.
Trevor
Trevor is offline   Reply With Quote
Old 10-04-2003, 09:33 PM   #3645
forty6's Avatar
Trevor, wouldn't it be cheaper to buy an SD kit and the RS conversion kit? Sell the SSG chassis to recoup some of your expenses. SD kits in you part of the world comes with the one-way already. Have you investigated this option?
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
