Old 10-03-2003, 07:14 AM   #3616
NightKidZ's Avatar
Send a message via ICQ to NightKidZ
Default Re: One way gear?!
Originally posted by IH
Hi,
I am wondering if you could use the ball diff ring gear (SD-503, the white one) with the one way?? Or do I need part nr. SD-643.
The bevel gears are the same except the different color and material, aren“t they?!
Thanks,
IH
The ring gear for ball diff use and the ring gear for one way use are different. The ring gear for one-way use has a larger hole than the diff one.
Cheers
NightKidZ is offline   Reply With Quote
Old 10-03-2003, 01:40 PM   #3617
SpeedTech's Avatar
Hi Guys,
we have a few new MR-4TCSD Hop-ups in stock:
Tobee Craft hop-ups for the SD are back in stock
Yokomo MR-4TCSD Aluminum suspension blocks and different toe-in rear hub carriers
For those of you that owns the Yokomo Mini Sedan, we also have these great looking Mini sedan bodies in stock
Thanks for reading!
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 10-03-2003, 03:00 PM   #3618
Joel Lagace's Avatar
Another question
Some time ago we were talnking about using the GT-4 bumper for the SD. What of the following parts do I need:
YOKOMO,ZE-001P GT-4 FRONT PLASTIC BUMPER
YOKOMO,GT-0001FS GT-4 URETHANE BUMPER,
YOKOMO,E-001L GT-4 WIDE Bumper.,
Does the wide one fit the SD without cutting or is the other one wide enough?
Thanks,
IH
Not sure about those parts but this maybe cheaper and possibly faster since its normally in stock at LHS.
TC3 Buds bumper and about 5 minutes to cut it out to fit over top of the stock kit yokomo stubby bumper. I used a really used old one in the picture below. My latest one is cut out of a blank KYDEX sheet. Use the foam bumper as a template in that case.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 10-03-2003, 03:48 PM   #3619
Default Carpet set-up - Rubber Tires
Hello,
I am looking for a carpet set-up using rubber tires.
Please post it.
Thanks,
Ralf is offline   Reply With Quote
Old 10-03-2003, 04:05 PM   #3620
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Oh yea I just ordered my new alum. pivot blocks from SpeedTech. They are cool looking and will add strength. They look great. Can't wait to add these to my car.
ST Racing Concepts (STRC)
Old 10-03-2003, 05:23 PM   #3621
Trader Rating: 7 (89%+)
That bumper det up looks really good I might try something like that too
Bubbasteponit is offline   Reply With Quote
Old 10-03-2003, 06:09 PM   #3622
forty6's Avatar
Can you use the center stiffener with the RS chassis?
forty6 is offline   Reply With Quote
Old 10-03-2003, 06:14 PM   #3623
forty6's Avatar
Default Re: Carpet set-up - Rubber Tires
Originally posted by Ralf
Hello,
Please post it.
Thanks,
Here is Jonas Andersson's carpet/rubber tires setup when he took 2nd place at the Touring Car Masters.
Old 10-03-2003, 07:40 PM   #3624
JimmyMac's Avatar
You can not use a center stiffener with the RaySpeed Chassis. The new Steering rack and motor mount would be in the way. Tomorrow I get to test my new chassis! Yipee! We'll see how it does....
JimmyMac is offline   Reply With Quote
Old 10-03-2003, 09:49 PM   #3625
forty6's Avatar
Thanks Kilruf. Can't wait for your feedback regarding the RS chassis. Hopefully, it is as good as it's hyped up to be.
Old 10-03-2003, 10:27 PM   #3626
Thanks for posting the rug set up I'll give it a try
Old 10-03-2003, 10:32 PM   #3627
Originally posted by Bubbasteponit
ongbenghui
Very nice, interesting idea with the top decks did you remove the center brace?
Nope, I didn't I want to make the chassis stiff.
however, I just drilled two holes on the Rayspeed top deck
and remove the SGG already.
ongbenghui is offline   Reply With Quote
Old 10-03-2003, 11:21 PM   #3628
Default TWO QUESTIONS??????
Hello All,
I was considering retiring my Evo III Surikarn and trying a SD for a change but I have a few questions regarding the kit.
Firstly what is the better version to get, the SSG or the Standard Carbon Fibre. What I want to know really is Besides just looks Is there a difference in weight, stiffness etc.
Finally will a Novak SS System fit in the car without a struggle???
Thanks for your help.
CustomfibreR/C is offline   Reply With Quote
Old 10-04-2003, 04:25 AM   #3629
Default Shooter Parts
Would anyone happen to know where to buy the Shooter parts for the SD? I know Precision RC has it but never got a reply back from them. Does anyone know what their contact number is?
Thanks.
gerrych is offline   Reply With Quote
Old 10-04-2003, 11:29 AM   #3630
Registered User
2Tenths's Avatar
I finally received my RS conversion kit yesterday, and naturally I nearly completed it by this morning. Here are some first impressions:
„The bottom deck is more flexible, however it is much lighter.
„The steering system is much, much better than the original; it has almost no play, is smoother and has a low CG (looks like it anyway )
„I believe the motor mount is shifted further back, but I'm not certain.
„With the new shock towers you can run very stood up positions.
„The top deck is stiffer than the original.
It is true that you cannot run the center stiffener with the RS chassis, however if you were to modify it, it would fit. Specifically, shorten it some.
I noticed one other weird thing: if you look at the RS bottom deck, you'll notice it has 2 extra holes at the rear end of the chassis, and it is longer. I wonder if Rayspeed is developing something to fit there Later I can post a picture of what I'm talking about if you like.
2Tenths is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
