Old 10-02-2003, 09:56 AM   #3601
forty6's Avatar
ongbenghui,
I did pretty much what you did but I asked Kilruf about the steering rack and he said that the holes do not line up on the RS and SSG chassis so I held off. I like my SSG lower deck, so I got shock towers for now.
forty6 is offline   Reply With Quote
Old 10-02-2003, 10:22 AM   #3602
NightKidZ's Avatar
Send a message via ICQ to NightKidZ
Default Re: Show off my SD
Originally posted by ongbenghui
Excited with my new rayspeed parts.
Show off my SD.
I am using a Rayspeed top deck on top of the SSG top deck.
There is offset on the steering post hole from Rayspeed and SSG. I need to make countersunk hole on the SSG to secure the steering post.
However, with Rayspeed top deck, center stiffer. I still find the
chassis is flexy.
Dude, where did you order your Rayspeed conversion from man?
I know for a fact the Singapore Yokomo distributor had been sleeping on the job so you couldn't have gotten that from the LHS
If you don't know yet, I'm Charles... yah the guy who was discussing Ackerman with you trackside at Nacos remember?
Cheers
NightKidZ is offline   Reply With Quote
Old 10-02-2003, 11:35 AM   #3603
lonestar1127's Avatar
Default Re: Re: Show off my SD
Cheers
wah....ongbenghui u got go for race?? wanna see the rs chassis . btw charles wat springs u use 4 carpet?
lonestar1127 is offline   Reply With Quote
Old 10-02-2003, 12:30 PM   #3604
ottoman's Avatar
R/C Tech Charter Subscriber
If anyone is looking... Yok Sd with custom made 3mm chassis and upper deck is on Ebay #3148167621
ottoman is offline   Reply With Quote
Old 10-02-2003, 12:48 PM   #3605
NightKidZ's Avatar
Default Re: Re: Re: Show off my SD
For that furry $h*t they are trying to pass off as "carpet" in CCK, I was using green springs all ard with Xpress radial tires
Trust me, the "carpet" we are using in Singapore is way less grippy than the stuff they use abroad, hence the need to compensate for it. For example, Jerry's track has a much better quality carpet than the blue CCK stuff
Cheers
Old 10-02-2003, 01:09 PM   #3606
Rayspeed setup sheet that comes with instructions and chassis instructions have been translated by Yokomo USA on their website.
James Nguyen is offline   Reply With Quote
Old 10-02-2003, 03:50 PM   #3607
Trader Rating: 7 (89%+)
ongbenghui
Very nice, interesting idea with the top decks did you remove the center brace?
Bubbasteponit is offline   Reply With Quote
Old 10-02-2003, 03:52 PM   #3608
James Nguyen
Bing, thanks got it whew I was in deep poo poo working to translate that stuff>>>>>>>>>>>>>>>>
Old 10-03-2003, 12:50 AM   #3609
Lonestar's Avatar
chattering UJ's problem solved... The rim's (JB racing) inside spokes rub on the lower part of the castor block and A-arm... solution: trim a little bit of the A-arm and move the castor block hinge pin to the lower hole... I could dial-in some steering throw, and the car does turns on-power now... Silly me for not seeing it earlier...
Car is still a little loose off-power... Will work on it. Received my Suzuki hubs, Square Ti bones (front), and rear Tobee Al. bones (rear), and my rear shock tower to put up front...
carpet racing, here I come!!!
Later,
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 10-03-2003, 01:14 AM   #3610
johnbull's Avatar
Hi friends. Greetings from Malta.
WYD. Have no fear. I'm still here!
Still running the SD and loving it. Have moved to the mod class this season and am experimenting with motors etc, but having big trouble blowing motors apart with these strong 3300 cells.
Did a couple of meetings in England in August. Good fun.
I got a phonecall from a friend in Sicily yesterday, telling me that guys on RCech had been asking about me, so this is just to tell you all I'm still around.
Hope to be able to contribute a bit more in the near future.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 10-03-2003, 04:20 AM   #3611
forty6's Avatar
JB, we're glad to see that you are still with us and also having a good time with the SD. Goodluck with your move to mod.
Old 10-03-2003, 05:59 AM   #3612
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Johnbull nice to see you here. I was worried as I didn't even see you on other threads. Glad your ok.
Blowing up mods? Man I thought these new breed of motors took a little more. You must be just going tooooo damn fast!!!!
ST Racing Concepts (STRC)
Old 10-03-2003, 06:30 AM   #3613
IH
IH's Avatar
Default One way gear?!
Hi,
I am wondering if you could use the ball diff ring gear (SD-503, the white one) with the one way?? Or do I need part nr. SD-643.
The bevel gears are the same except the different color and material, arenīt they?!
Thanks,
IH
IH is offline   Reply With Quote
Old 10-03-2003, 06:48 AM   #3614
IH
IH's Avatar
Another question
Some time ago we were talnking about using the GT-4 bumper for the SD. What of the following parts do I need:
YOKOMO,ZE-001P GT-4 FRONT PLASTIC BUMPER
YOKOMO,GT-0001FS GT-4 URETHANE BUMPER,
YOKOMO,E-001L GT-4 WIDE Bumper.,
Does the wide one fit the SD without cutting or is the other one wide enough?
Thanks,
IH
Old 10-03-2003, 06:56 AM   #3615
THeGame's Avatar
Send a message via AIM to THeGame
Default Re: One way gear?!
Originally posted by IH
Hi,
Thanks,
IH
They are the same gear ones just made from different material.
THeGame is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
