Old 09-12-2003, 08:16 AM   #3331
sosidge's Avatar
Originally posted by magerz24
Hi everyone, I have a major problem with droop. No mater what I do, I have at least 8 or more mm of droop. I tried using the long shock ends but then I get alot of ride hight. Right now I am running associated springs and shock ends. How do I lower my droop without affection ride hight. Thanks
Droop as a measurement is affected only by the shock length and the position of your droop screws. If 8 is the reading you're getting on the Yoke guage, it means you either have the shocks far too short, or you have the droop screws in the wishbones screwed in a very long way (they need to be backed off).
Ride height is affected by the spring setup, not by shock length or droop screws (PS for any noobs reading this never use droop screws to adjust ride height). The Associated springs are longer than the Yoke's, so when you use Yoke bottoms you get much more ride height. Solution is to fit the new Rayspeed spring cups to the Yoke ends, or fit Associated shock ends and spring cups.
Old 09-12-2003, 08:33 AM   #3332
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Do you guys find a benefit to using the longer Rayspeed or even AE springs over the shorter Yok springs? I'm going to need to get a spring assortment and I'm trying to weight the benefits of staying with the stock length or going with the longer and new ball cups...
vtl1180ny is offline   Reply With Quote
Old 09-12-2003, 08:57 AM   #3333
Lonestar's Avatar
coucou utieh
Thanks kentech and utieh for your input.
Later
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 09-12-2003, 09:37 AM   #3334
kt racing's Avatar
Send a message via AIM to kt racing
has anyone heard of someone making a steel or aluminum spool for the sd
kt racing is offline   Reply With Quote
Old 09-12-2003, 12:11 PM   #3335
Registered User
Masami's SD at Reedy 03.
Aku-Man is offline   Reply With Quote
Old 09-12-2003, 02:05 PM   #3336
Aku-Man, Where do you race in Salt Lake City?
pops is offline   Reply With Quote
Old 09-12-2003, 02:26 PM   #3337
The only reason (to my knowledge) people use different springs would be a) if they already had a stack of AE springs or b) if they were very particular about a spring rate. I find Yok springs work well, have a good set of spring rates and fit well for ride height issues. I would say stick with the Yoks. Just my $0.02.
Rampant is offline   Reply With Quote
Old 09-12-2003, 02:28 PM   #3338
rc-zombies's Avatar
the use of longer springs is more linear... compared to shorter springs which tend to be more progressive...
I've compared the 2 and with longer springs the SD handles and transitions better....
Old 09-12-2003, 02:32 PM   #3339
Registered User
At parking lot.
SLC sucks, no track for on-road. Only one local club race f201 at parking lot most once a week.
Why ask?
Old 09-12-2003, 03:00 PM   #3340
EricF's Avatar
Is that why most 1/10 gas cars use the shorter springs, they need the progressive rate because of the extra weight?
Actually I think what makes a spring more or less progressive is the number of coils in the length of the spring. For example if a spring has 20 coils per inch vs. 10 coils with all else being equal. The spring with 20 coils will give the feeling of being stiffer faster althoght all else is equal.
Make sence???
E
AE 12R5.2 & R6(x2) - TC7.1 convert, F6 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 09-12-2003, 03:28 PM   #3341
Registered User
2Tenths's Avatar
Thanks for posting the picture of the golden Masami car!
I recommend running the associated springs if you feel your car is rolling through the corners to much, such as on a high traction surface (carpet). This way you can run a stiffer spring.
2Tenths is offline   Reply With Quote
Old 09-12-2003, 03:59 PM   #3342
EricF's Avatar
If you need stiffer springs that are the same size as the original springs, you can run the spring set for the GT-4 gas car.
E
Old 09-12-2003, 04:24 PM   #3343
vtl1180ny's Avatar
That's kind of what I was wondering... I'm going to gather that the concesus says go for the AE springs...
Old 09-12-2003, 07:25 PM   #3344
at parking lot
Matt Howard who runs for Yokomo is moving to Salt Lake City in the near future, just wondering if anyone had a full time track. I thought that the off road track in Magna had a asphalt on road track too.
Old 09-12-2003, 07:35 PM   #3345
Registered User
They do? Are you sure? I thought they only have off-road. Somebody told me intermountain going to have one, but don't know for sure.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
