Old 09-10-2003, 11:13 AM   #3286
IH
IH's Avatar
Default Anti-roll bars?
What is the difference between the stock anti-roll bar set and the tuning part, which is a upper roll-bar. In other words:does the different mounting position affect handling in a special way?
Thanks,
ingo
IH is offline   Reply With Quote
Old 09-10-2003, 12:04 PM   #3287
Hey Guys,
Can somebody explain what difference is between an upper and lower sway bar. I have been running the car since it first came out with great results, but never figured out what they ment by upper and lower. I have been using a Buds AE .075 bar on the front for carpet racing. In most other respects my setup is very close the carpet setup posted last week.
Thanks, Lee
Founding Member of CORRC
www.OnRoadColorado.com
LeeS is offline   Reply With Quote
Old 09-10-2003, 12:26 PM   #3288
peter_robinson's Avatar
Trader Rating: 21 (100%+)
Originally posted by atheena
What are your impressions when running the SD on carpet with both rubber and foams? Handling, Setup, chassis stiffness?
i have lately been testing on carpet with foam tires, and have had great success. i have only been to the track two days for setup work and already my lap times are 1-2 tenths lower than other factory drivers that run there. chassis stiffness is not an issue as long as you are running the black chassis and top deck. i like my car to be really stiff on foams so i actually doubled up the top decks on the car. the car is like a rock now and works very well on plaids and purples. i do not run rubber tires on carpet as my local track does not run rubber tires in the 19T and Mod classes...
For orders or inquiries, email [email protected] Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 09-10-2003, 12:43 PM   #3289
Send a message via AIM to munrath
What are the part numbers for the black SD chassis, midbrace, and upperdeck?
Peter - Care to share you setup for foam tires running on carpet?
Later,
Mark
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 09-10-2003, 01:23 PM   #3290
iron chef's Avatar
Lee
I got the upper bar set- Ill send tomorrow with J for you to try- the upper bar set works better on bigger track - it attaches on top plate and leverages higher than lower bar set, probably no good on carpet
iron chef is offline   Reply With Quote
Old 09-10-2003, 02:06 PM   #3291
Registered User
2Tenths's Avatar
As to running foam on carpet, I haven't run it yet, but some people at Rain who have have noticed that a 28mm Jaco rubs on the front knuckle. To fix this they true the side of the wheel, making the front tire 27 mm.
2Tenths is offline   Reply With Quote
Old 09-10-2003, 02:54 PM   #3292
Default New setup sheete
Tell me what you think of my brand new setup sheete.
I think that it is better than the original and I woork whit it för many hours.
http://www.hotel.ymex.net/~s-19017/setupsheete.pdf
Gezuz is offline   Reply With Quote
Old 09-10-2003, 02:56 PM   #3293
rc-zombies's Avatar
Default Re: New setup sheete
Great job!!! best I've ever seen...
will you have a version with the Rayspeed chassis and towers?
Old 09-10-2003, 04:39 PM   #3294
rc_bam226's Avatar
Gezuz, what's with the "Setup BLAD"? Just wondering out of curiousity. Great job with the setup sheet, now that's what I call a real racer's setup sheet.
rc_bam226 is offline   Reply With Quote
Old 09-10-2003, 05:30 PM   #3295
EricF's Avatar
Thumbs up
That is nicely done. Good job.
AE 12R5.2 & R6(x2) - TC7.1 convert, F6 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 09-10-2003, 07:25 PM   #3296
Kenneth Tan's Avatar
I spotted a spelling mistake under the rear shocks ends. 'Kort' is there instead of 'short'.
Kenneth Tan is offline   Reply With Quote
Old 09-10-2003, 08:11 PM   #3297
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Thumbs up
Great setup sheet. Very nice and easy to see. I just might have to take it to the printers and have some nice colored ones made instead of black and white.
ST Racing Concepts (STRC)
Old 09-10-2003, 09:11 PM   #3298
JimmyMac's Avatar
Here is a pic of the Shooters Upper Deck Camber mounts.
Has anyone tried Yokomo Inch up Foams? Just something to consider for those with rubbing ballcups...
JimmyMac is offline   Reply With Quote
Old 09-10-2003, 11:11 PM   #3299
anyone tried a tc3 oneway is the SD? It looks like it would fit but are the gears have the same amount of teeth? ANyone have any pics of pros yoks like toso's, I have not seen very many except for at yokomousa?
teamAE is offline   Reply With Quote
Old 09-10-2003, 11:17 PM   #3300
Thanks guys. Ther is some spellings problems that I have to fix. And when it´s done I post here.
rc-zombies>> I don´t have any pictures on the Rayspeed tower but if you post I picture here I my think to do one for you.
KilRuf>> Is the Shooters upper deck camber mounts better than the original and what does it do different from the original.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
