Old 08-31-2003, 11:52 PM   #3166
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I do like those cars, but I wouldn't recommend running them with those step pin tires
Old 09-01-2003, 12:04 AM   #3167
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
hi guys, i ve got a pair of yokomo rear low friction unversals for the MR4TC, i have heard these will also fit the new SD without modification, i think i have heard you guys talked about this a while ago just want to make sure they will fit thanks
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 09-01-2003, 12:44 AM   #3168
Matt I ran the car and it did free up. i took some of the shims out because Patt T. one of the yok drivers from socal told me wiht the stock ones it was to tight. I took one out from both the input shafts and put 2 on the long side of he diff pushing it away from the input gear, so it would spin freeer I thought? Should I go back to stock everything to see who that goes? Also do you guys shave the the diff cases like they do on the tc3?
teamAE is offline   Reply With Quote
Old 09-01-2003, 01:59 AM   #3169
TEam Ae whats your name? Are you Drew? umm what kind of body scheme do you have im going there maybe Tuesday to race but ill be there but see me and ill talk haha. for freeing up the drive train i just use 1 shim all round Degreased bearings fully in integy vibe thingy haha dont know what its called . Umm and used the white beval gears. Graphite shaft and umm made sure that the Gear box isnt to tight. SOrry for all the Umms haha its late im tired from driving everywhere
Yokomo_King is offline   Reply With Quote
Old 09-01-2003, 02:04 AM   #3170
Xazn.... the car parts are interchangable there is some mods that you can do to make the cars faster then what they are but it take a dremel and cutting. make sure that you use Center one-way as well as a front one way degrease all the bearings to kinda free it up. When i ran the car i didnt use a belt tenisor cuz it put to much pressure on the belt. you have to most recent versions of the Mr4-Sp if you have any question just PM me haha :-)
Old 09-01-2003, 10:51 AM   #3171
Matt Howard's Avatar
teamae- I haven't heard of anyone that has had to shave their gearboxes. I suppose there has to be some small production tolerances for the gearbox's so you might have to take a shim out from the input shafts, just make sure there is no play in them or you'll probably go through gears pretty quick.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 09-01-2003, 12:25 PM   #3172
Thanks Matt ya King its drew I mihgt come down tue or next tues
Old 09-01-2003, 01:02 PM   #3173
go to ultimate and buy the part for the one way its cheap
Old 09-01-2003, 11:58 PM   #3174
Default Pat T mod.
What do you think of Pat T car whit the center stiffer cut In two pices and put it on the main chassi. I found the pictures on www.yokomousa.com in the gallery if you would like to se some more pictures of the car. Here is the pictures.
http://www.yokomousa.com/phpBB2/albu...php?pic_id=295
Gezuz is offline   Reply With Quote
Old 09-02-2003, 12:22 AM   #3175
peter_robinson's Avatar
Trader Rating: 21 (100%+)
the link doesn't work for me, can you possibly post some pics of what you are speaking about.
For orders or inquiries, email [email protected] Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 09-02-2003, 12:31 AM   #3176
Kenneth Tan's Avatar
The mod looked as if its gonna give more side to side flex, but still retaining some of the forward/rear stiffness at the front end.
Kenneth Tan is offline   Reply With Quote
Old 09-02-2003, 05:47 AM   #3177
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Gezuz that setup kinda is fashioned like the split toplate that Xray has for their cars. Should let the car flex a little more . Might be good for asphalt but I don't think you would want that for carpet.
ST Racing Concepts (STRC)
Old 09-02-2003, 10:45 AM   #3178
Registered User
2Tenths's Avatar
I was wondering if anyone has compared the stiffness of the chassis when running 2 top decks (unglued) versus 2 top decks glued together? Does gluing them together help a lot or a little? I've been running 2 unglued for a while and was thinking of gluing them together.
Peter Plastic - Is your drivetrain free yet? I'm curious to see the results.
2Tenths is offline   Reply With Quote
Old 09-02-2003, 12:02 PM   #3179
mo
mo's Avatar
I received my Shooters lightened motor mount and alum top deck mount with additional horizontal camber mounts today. If I get them installed tonight, I'll post some pics. The parts look very nice. A little darker blue than the stock Yokomo motor mount, but should match the Suzuki stuff well. I got them at www.precisionrc.com.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 09-02-2003, 03:51 PM   #3180
JimmyMac's Avatar
I can't find it on their website.... but where is this place located MO?
JimmyMac is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
