Old 08-29-2003, 12:17 AM   #3121
Ok i need a Socal Stock setup Please i need 1 can anyone help!!!
Yokomo_King is offline   Reply With Quote
Old 08-29-2003, 10:21 AM   #3122
mo
mo's Avatar
Default Rayspeed Chassis
The Rayspeed chassis set is now up on the Yokomo Japan website. Looks pretty nice.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 08-29-2003, 12:21 PM   #3123
EricF's Avatar
Default Re: Rayspeed Chassis
Where??
AE 12R5.2 & R6(x2) - TC7.1 convert, F6 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 08-29-2003, 12:43 PM   #3124
mo
mo's Avatar
www.yokomo.co.jp
then click new products
Old 08-29-2003, 01:41 PM   #3125
peter_robinson's Avatar
Trader Rating: 21 (100%+)
the picture makes it hard to tell if the material wil be the black carbon or the silver surface stuff... hope it will be black or else i will have to
For orders or inquiries, email [email protected] Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 08-29-2003, 01:41 PM   #3126
hehe j/k
Old 08-29-2003, 02:25 PM   #3127
EricF's Avatar
www.yokomo.co.jp
Thanks, I went to teamyokomo.com, that's why the WHERE??
Actually that chassis looks to flexable for carpet- thats what I race on.
E
Old 08-29-2003, 02:50 PM   #3128
Registered User
2Tenths's Avatar
The way its pictured, the Rayspeed chassis looks like a conversion kit. Does anyone know whether the pieces will be available separately? (I'm mostly interested in the shock towers.)
2Tenths is offline   Reply With Quote
Old 08-29-2003, 04:14 PM   #3129
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
MattHoward I have one of those new Yoke chargers. Very nice and compact size. Do you use that Yokomo Peak on yours or do you stick with the standard Peak Charge? If you used the Yokomocharge did you notice any differance in the way your car ran, like more punch?
Brian
ST Racing Concepts (STRC)
Old 08-29-2003, 06:48 PM   #3130
Default building my MR4-SD
Hi,
I am building my MR4-SD and find that the drive train is very stiff, sort of binding. Is there a problem with the manual of having 3 shim at the bevel gears ?
Also, I got spare bevel gears from my LHS, and the new bevel gears are sort of brown color, but the kit gears are black. Is there a difference between the two ?
I saw a light weight carbon staft on my LHS, is it a good buy ?
I just wonder if there is a dedicated web site on MR4-SD tips and tricks ?
ongbenghui is offline   Reply With Quote
Old 08-29-2003, 07:05 PM   #3131
Roger's Avatar
That RaySpeed Chassis does look pretty trick.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 08-29-2003, 08:29 PM   #3132
rc_bam226's Avatar
For the carbon shaft, are you running stock or mod? The shaft will hold up well for stock, for mod, I have heard that people have shattered the shaft, I have one put an 8T double and drove on the street, didn't break. It is a worthy purchase.
As for that Rayspeed chassis, it is sweet. Can't wait to see the off the shelf version.
rc_bam226 is offline   Reply With Quote
Old 08-29-2003, 10:13 PM   #3133
RC-BAM are you racing tomorrow at Speedworld..?
Nevada is offline   Reply With Quote
Old 08-29-2003, 11:22 PM   #3134
You are going to have to play around with moving the shims. I believe my car only has 2 on the bevel gear and both shims on the long diff halve so it moves the gear away from the little bevel gear freeing up the car. Just move them around until you get the least amount of drag. It is pain to do, but well worth it once it is right.
The gears are suppose to be the same. The first kits where to be white, but they ended up a brown color. People did not like this so they made them in black.
Only run the graphite shaft if you are running stock. That is all it is designed for and will break with a mod.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 08-29-2003, 11:26 PM   #3135
view my setup
That is my setup for stock -- very similar to Masami's Reedy setup. For me and my style it works excellent! Email/PM me if you have any other questions. Some biggies for SoCal IMHO are the rear tower up front and a front one way. Also see my notes about the Stratus 2.0 v Alpha (short answer = Alpha much better suited for SoCal due to high front downforce). BTW, the SD is much faster that a Losi (my old car) out of the corners and top speed may be equal -- we have looks AND performance!
For the gurus here -- I have a (very) slight oversteer on exit -- does anyone recommend a solution so I can be a little more aggressive with the throttle past the apex? Or is that just the torque that isn't truly correctable outside a smooth trottle finger?
Rampant is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
