Old 08-25-2003, 09:42 AM   #3091
Joel Lagace's Avatar
Thanks guys.
Running rubber right now, but was hoping to run foam as well. (my TC3 is my current foam car)
Thanks email me: [email protected]
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 08-25-2003, 10:14 AM   #3092
EricF's Avatar
I too could use a tried carpet setup...
Does anyone know how the springs for the GT4 rate in comparison to the standard springs for the SD?
Are the Gray GT4 springs significantly stiffer than the Orange springs for the SD?
I have Assoc. springs mounted on the car now, but I don't like the way I have to adjust the shock lengths in order to acheive a 3.5mm to 4.5mm ride height.
Also, I'm runnig TRC 26mm foams on a 90'x43' track.
Thanks,
Eric
AE 12R5.2 & R6(x2) - TC7.1 convert, F6 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 08-25-2003, 11:06 AM   #3093
Registered User
2Tenths's Avatar
This is my new user name, I've been posting under my dad's name, coolrcdad, but now finally have my own.
I tried to post my own setup sheet for the SD with rubber tires on carpet as a jpeg but the file was too large for the site. If anyone wants this setup sheet, send PM and I will send it to you. It is about 1 MB I think. If anyone knows how I can use the rear shock tower setup sheet as a pdf, I will be able to post it as one, but I don't know how.
2Tenths is offline   Reply With Quote
Old 08-26-2003, 02:26 AM   #3094
OHBRAD's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to OHBRAD
Default ONE WAY
DOES THE YOKOMO Yokomo MR-4TC SD Shaft Drive COME WITH A FRONT ONE WAY IN THE KIT DOES ANYONE KNOW
or are these the parts, and if they are do i need all the ones that say one way or jus the one part
http://www.sslorder.com/speedtechrc/287.htmlhttp://www.sslorder.com/speedtechrc/287.html
Yokomo BD818 | Sanwa | HW | Zombie | Team Yokomo | Meakin Park | Bayside | Hearns Hobbie | SpeedyRC
OHBRAD is offline   Reply With Quote
Old 08-26-2003, 03:32 AM   #3095
YOKOMOSHO's Avatar
Apparently (last I heard anyway), US version sd's have a ball diff in the front. Asian version (including Australian sourced cars) sd's come with the one way diff in the front (what I have found to work best most of the time).
Keith M.
YOKOMOSHO is offline   Reply With Quote
Old 08-26-2003, 06:46 AM   #3096
sosidge's Avatar
All the GT4 springs are a stiffer rate, the Grey's are about 70% stiffer than the Orange, according to CML's chart.
Old 08-26-2003, 08:39 AM   #3097
Originally posted by rc_bam226
One way to free up your drivetrain is to remove a shim from the input shaft's small pinion. There are 3 of them, just remove one or two to get a little of free play in the meshing of the gears. Another way to free up your drivetrain, get bearings than you can clean out, and put thinner oil inside instead, the ones included are grease packed ones have a lot of unwanted drag. The ones that you can clean out are the large diff one, just remove the rubber shield, clean and put ball bearing oil inside.
Thanks for your reply. Should I remove the front or rear input shaft shim?
Explorer is offline   Reply With Quote
Old 08-26-2003, 09:40 AM   #3098
Registered User
2Tenths's Avatar
Here's my carpet setup on CS-27s. It's kinda hard to read, but at least it fits on the website.
Old 08-26-2003, 09:46 AM   #3099
EricF's Avatar
Thanks, that what I needed to know, I think that I'll go ahead an order the GT4 springs. I run primarily run on carpet, that's why I want the stiffer springs.
I'm using Assoc. springs now, but I think that I'd prefer to use the shorter yokomo springs, mainly because I don't true my foams down out of the box, unless I'm having traction rolling problems.
Anyway... Thanks, Eric
What's CML address?
Old 08-26-2003, 09:48 AM   #3100
Just building my SSG SD and noticed when i turn the spur gear by hand i get alittle wobble on the input shaft to the front gearbox. Also feels like the mesh is going alittle tight on the front ball diff as this happens.
Is this normal until the drivetrain beds in or is there something not quite right. I have built the car 100% to what the manual says.
Here is a pic of where i have got too so far.
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 08-26-2003, 09:50 AM   #3101
rc-zombies's Avatar
Default SHOOTERS SD OPTION PARTS
Have you guys seen these yet?
Old 08-26-2003, 10:34 AM   #3102
EricF's Avatar
That seems to be the case, my car was the same until I actually put power thru the drive-train.
Eric
Old 08-26-2003, 12:25 PM   #3103
Registered User
2Tenths's Avatar
When I first got the car I built it just as the instructions pictured, but now I realize that their shimming is off. I don't know whether you want to take your gearboxes apart again, but if you do, you should spend time finding the proper shimming, not simply the one in the instructions. From my experience, the shimming should be done in such a way that there is a little backlash between the gears, and when you rotate the the gears slowly by hand, you can feel no binding. Another thing to look for in the shimming, is shimming the gearbox so that the gears make a minimum amount of noise. I tried several combinations until I found the smoothest, quietest setting.
I have a question of my own. Does anyone have any luck running a gear additive to their gearboxes? Whenever I use something like White Lightening or Krytech, which are both parafin based, they leave a waxy build-up which eventually binds the gears. Is there anything out there which is thinner but works?
Old 08-26-2003, 12:31 PM   #3104
rc-zombies's Avatar
I never had any problems with binding using White LIghtening.
Are you letting the grease sit overnight on the gears so it can bond and be absorbed.
Old 08-26-2003, 12:50 PM   #3105
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
When I built my SD i sprayed all the bearings out and then relubed with WD-40. Then I built the car as per the directions. I did use some Paragon Liquid Graphite on my gears. It only takes like 2 minutes for it to dry and then I put the trans together. I then just ran my car like normal. After a run or two the gears where all ran in and the drivetrane is free and very smooth.
Where can we get some of that Shooter alum parts from? They look trick.
ST Racing Concepts (STRC)
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
