Old 08-19-2003, 01:03 AM   #3031
VenomRcR's Avatar
Send a message via Yahoo to VenomRcR
Default Hiro Factory Carbon Driveshaft
Has anyone used the Hiro driveshaft yet? Any problems? I'm thinking about switching because of the Yoke carbon shaft twisting in stock class.... Thanks guys
VenomRcR is offline   Reply With Quote
Old 08-19-2003, 01:35 AM   #3032
Matt Howard's Avatar
haven't tried or even heard of the Hiro driveshaft but I've been using the Tobee lightweight aluminum one in mod with no problems at all. It's almost as light as the yokomo graphite one but much more durable.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 08-19-2003, 01:45 AM   #3033
I have to shim different than the instruction. The major problem is that the bearing that hold the small gear. You must install that first before installing the shaft.
If you have a chance, try to use ceramic bearings instead in the drivetain. You will increase performance but it is very expensive.
Kamen Rider is offline   Reply With Quote
Old 08-19-2003, 01:50 AM   #3034
I use Shooters center shaft. Hiro's shaft, is it dark blue and graphite in the middle. If it is, you can buy the Shooters because it is the same. Shooters will also come out the upper deck mount that is very similar to EVO 3 Surikarn for the SD. They will release this mount very soon.
Yok's orginal shaft 11~13 grams
Tobee or Project D 7~9 grams
Shooters 6 grams
Old 08-19-2003, 07:02 AM   #3035
rc_bam226's Avatar
Hey Kamen Rider where do you get a Shooter's shaft from? Thanks.
rc_bam226 is offline   Reply With Quote
Old 08-19-2003, 08:19 PM   #3036
Speaking of Hiro Factory, does anyone have a picture of the Hiro Factory heat-sinked motor plate/mount?
coolrcdad is offline   Reply With Quote
Old 08-20-2003, 01:39 AM   #3037
From HK, Control Centre is the name of the store.
Shooters is making some items and export to Japan. The Center Shaft is around US20.00
Old 08-20-2003, 04:50 AM   #3038
utieh's Avatar
they are announcing the rayspeed chassis is for late september at controlcentre.... hope they will release a conversion kit.
utieh is offline   Reply With Quote
Old 08-20-2003, 05:19 AM   #3039
Chrissy C's Avatar
Default Ceramic Bearings
Hello all,
I have just purchased some ceramic bearings for the input shaft assembly and the diffs. When they arrive how should i clean and lube them? As they are so expensive i don't really fancy taking the shields out as i never seem to get them back in properly Also will there be a marked improvement over the standard bearings?
Thanks for your help
Chris
Chrissy C is offline   Reply With Quote
Old 08-20-2003, 06:18 AM   #3040
chrissy c,go to acer racings website and they do oil just for ceramic bearings.do not remove the shields or clean with deagreaser.if u want to clean them just get some airduster and blow them out then re lubricate with the special oil.
trf racer is offline   Reply With Quote
Old 08-20-2003, 06:21 AM   #3041
Chrissy C's Avatar
cheers trf, will take a look now. I take it you can't / not advised to use Trinity Royal oil?
Old 08-20-2003, 06:25 AM   #3042
i wud not recomend it.use the proper stuff.these are high performance bearings and take a lot of pressure.
it will be like running a v12 engine with some super market oil for abot 50p a litter!use the proper oil then they will last and have high performance
Old 08-20-2003, 06:31 AM   #3043
Chrissy C's Avatar
Thanks for your help mate.
Old 08-20-2003, 11:00 AM   #3044
Send a message via AIM to munrath
I noticed the SSG SD comes with washers to change the kickup, however, some are notched and others are not. What is the difference?
Mark
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 08-20-2003, 11:27 AM   #3045
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
munrath they are actually the same size but the notched ones are more than likely so you can tell by looking what extra amount of caster you put in the car. I used calipers on both ones you are talking about when I built my car. Both were the same so I took it as you can just look for the notch to see what extra caster or pro squat you added.
ST Racing Concepts (STRC)
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
