Old 08-15-2003, 02:05 PM   #3001
rc-zombies's Avatar
Originally posted by Fike
How does the RS spring rate compared to Assoc. springs? What equals what?
Thanks,
E
I posted it many pages ago..... I'm at work right now..sorry don't have my SD book with me....
Old 08-15-2003, 02:06 PM   #3002
rc-zombies's Avatar
Originally posted by Difuser
Kaizen you also have to trim the shock end 2 mm this will lower the perch to help with ride height.
On the AE shock end you have to trim 2mm off... but with the YOK ends and RS perch... you do not have to.
Old 08-15-2003, 04:30 PM   #3003
kaizen's Avatar
Hi! Zombies,
Okay, I am going to try the lower c-mount. But the rear is still well above ride height even though it is in the lower hole on the carrier. May I ask what shock mounting positions you are using?
Thanks,
Stu
kaizen is offline   Reply With Quote
Old 08-15-2003, 04:32 PM   #3004
rc-zombies's Avatar
Originally posted by kaizen
Hi! Zombies,
Thanks,
Stu
on the rear...outer mounting hole... on the front I had the rear shock towers mounted... outer upper hole.
Old 08-15-2003, 07:06 PM   #3005
Another way to lower ride height is to unthread the shock ends more. Though this does change the length of the shock, it allows the spring to sit lower on the shock, and thus lowers the overall ride height. Basically it gives you more usable preload.
coolrcdad is offline   Reply With Quote
Old 08-15-2003, 09:37 PM   #3006
yodace's Avatar
R/C Tech Charter Subscriber
When I use all four shims up front to adjust roll center? Still have no figure this out?
yodace is offline   Reply With Quote
Old 08-15-2003, 10:32 PM   #3007
kaizen's Avatar
Kaizan....
will you be racing in RcCar at S.J. this Sunday?
I'll be there..... I'll help you with your car.
Thanks for your help. Figured it out...actually had the shock cup upside down.
Ultimately, I ended up with the center facing upwards on the rears (upside right?) and facing downwards on the rear (upside down?) to get ride height and preload about right. Anyway, looks good now. Looking forward to trying these springs out on Sunday.
Yeah, I will be there. See you then.
Cheers.
Old 08-16-2003, 01:40 PM   #3008
Dooh! Operator Error!
I'm sorry, I couldn't help myself. I'm glad you were able to figure it out
Headbanger is offline   Reply With Quote
Old 08-17-2003, 01:22 AM   #3009
Roger's Avatar
Default yokomo springs
Whats is the order of the spring variations by color ? I forgot
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 08-17-2003, 01:26 AM   #3010
Roger,
Did you pick up an SD?
Yokomo Springs:
Softest to Hardest
Black
White
Blue
Yellow
Pink
Stainless
Green
Orange
Rayspeed:
Softest to Hardest
Green
Blue
Yellow
White
Red
Gray
James Nguyen is offline   Reply With Quote
Old 08-17-2003, 01:28 AM   #3011
kentech's Avatar
Default Re: yokomo springs
TC springs (g/3mm)
YS-1360 Black (519g)
YS-1355 Blue (561g)
YS-1465 White (591g)
YS-1460 Hot Yellow (690g)
YS-14525 Stainress (692g) (different material)
YS-14575 Hot Pink (703g)
YS-1455 Hot Green (738g)
YS-1450 Hot Orange (949g)
GT4 springs
YS-1560 Dark Green (870g)
YS-1660 Red (982g)
YS-1655 Yellow (1210g)
YS-1650 Green (1335g)
YS-1760 Silver (1389g)
YS-1755 Gray (1416g)
YS-1750 Brown (1722g)
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 08-17-2003, 01:30 AM   #3012
Roger's Avatar
thx James. I just picked up a SD.
Old 08-17-2003, 01:32 AM   #3013
cool, im sure you'll like it. anything you got a question on ask us here.
Old 08-17-2003, 09:38 AM   #3014
Does anyone know the pound or gram spring rates of all of the Rayspeed springs?
Old 08-17-2003, 11:33 AM   #3015
Default Re: Spring Rates:
Found this post back on page 40.
Part Number Colour Spring Rate lbs/inch
YS-1360 Black 9.67
YS-1355 Blue 10.45
YS-1465 White 11.01
YS-1460 Hot Yellow 12.85
YS-14525 Stainless 12.89
YS-14575 Hot Pink 13.09
YS-1455 Hot Green 13.75
YS-1560 Dark Green 16.21
YS-1450 Hot Orange 17.68
Usualbe TC3 springs:
Associated TC3 Green 12.00
Associated TC3 Silver 14.50 Same as Rayspeed Silver
Associated TC3 Blue 17.00 Same as Rayspeed Blue
Associated TC3 Gold 19.50
Anti Roll Bar chart:
Colour Torsion Rate (N/rad) Equivalent rate at wishbone(lbs/inch)
Black 24.57 9.1
Silver 30.57 11.4
Brass 38.34 14.2
Copper 40.77 15.1
Found the following at the Yokomo USA site:
Part# RS-05 Shock Spring, Yellow (Long-Type, 2 Ea) $5.25
Part# RS-06 Shock Spring, White (Long-Type, 2 Ea) $5.25
Part# RS-07 Shock Spring, Red (Long-Type, 2 Ea) $5.25
Part# RS-08 Shock Spring, Gray (Long-Type, 2 Ea) $5.25
Part# RS-09 Shock Spring, Blue (Long-Type, 2 Ea) $5.25
Part# RS-10 Shock Spring, Green (Long-Type, 2 Ea) $5.25
Compared to the stock spring lengths, the longer length of the Rayspeed spring allows for a more progressive spring rate.
Available in the following order of soft to hard: Green, Blue, Yellow, White, Red, Gray.
When using these springs on the MR-4TC SD with the stock shock ends, use Rayspeed Spring Cups (Part#RS-15).
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
