Yokomo MR-4TC SD
Old 08-10-2003, 11:14 PM
  #2911
analyzer's Avatar
Type of grease
what type of grease do you guys use to lube the bearings of the front one-way?
analyzer is offline
Old 08-10-2003, 11:18 PM
  #2912
NMRCDude's Avatar
Its actually a KAI (k models) chassis kit. They do make other chassis kits for the high end cars (SD, Evo 3, Barracuda R2, etc..)
NMRCDude is offline
Old 08-10-2003, 11:54 PM
  #2913
Randy Caster's Avatar
Trader Rating: 47 (100%+)
You are spreading the K Models love everywhere
Randy Caster is offline
Old 08-11-2003, 09:51 AM
  #2914
Trader Rating: 21 (100%+)
anaylzer- The best lube I have found for a one-way is Serpent one-way lube. I think is around $7 or 8 and the bottle should last you forever.
Brian L is offline
Old 08-11-2003, 10:16 AM
  #2915
yodace's Avatar
Another roll center Question? Sorry
I would like to raise my roll center which spacer would I use? The one that looks like it has a bite taken out of it or the other one?
Also want is UNkeyed and Keyed mean?
These directions are hard to follow/ not enough information?
yodace is offline
Old 08-11-2003, 11:30 AM
  #2916
IH
IH's Avatar
What positions do you usually use when putting the rear shock tower on the front end?(Shock tower, A-arm, camber link...)
Thanks,
ingo
IH is offline
Old 08-11-2003, 11:35 AM
  #2917
When using 28mm tires on the front of the Yokomo SSG SD the tire rubs the steering knuckles. Does anyone make a wider hex to push the wheel further out on the axel?
Mark
munrath is offline
Old 08-11-2003, 12:13 PM
  #2918
sosidge's Avatar
You should use the non-notched spacers if you want to raise the suspension mounts to raise roll-centre. Another way to raise roll centre is to place a spacer under the balljoint on the caster block (1mm is the most that will fit though). You could also run a shorter camber link, fitted in an outer hole on the shock tower.
sosidge is offline
Old 08-11-2003, 04:11 PM
  #2919
rc_bam226's Avatar
NMRCDude, do you have a website where I can get KAI chassis? LMK 'cuz they are SWEEET!!!!
rc_bam226 is offline
Old 08-11-2003, 04:20 PM
  #2920
rc_bam226's Avatar
Old 08-11-2003, 04:24 PM
  #2921
rc-zombies's Avatar
the Kai chassis is only available in Japan and no where else...
They cost more than the SD kit itself... nice as it is... it's not very cost effective... You are better off getting the Rayspeed chassis and shock towers when they get released.
rc-zombies is offline
Old 08-11-2003, 04:38 PM
  #2922
As crazy as the Kai SD chassis looks, the chassis kit they have for the Evo is 3 times crazier
Old 08-11-2003, 06:55 PM
  #2923
rc_bam226's Avatar
Thanks for the info guys!!!
Old 08-11-2003, 07:11 PM
  #2924
Matt Howard's Avatar
the KAI chassis pictured there uses the EVO III suspension on it with the SD drivetrain. After you get the chassis you would need to get the suspension stuff as well. You would probably end up with the worlds most expension SD
Matt Howard is offline
Old 08-11-2003, 10:46 PM
  #2925
I think the Rayspeed version of the chassis have the battery slight forward than previous.
Kamen Rider is offline
