Old 08-07-2003, 11:09 AM   #2881
dremel with a cut off disk, then sand it down with some sandpaper.
James Nguyen is offline   Reply With Quote
Old 08-07-2003, 12:42 PM   #2882
sosidge's Avatar
Originally posted by utieh
For the 1mm spacer, should I raise all the car Roll center and then try to change kick-up/antisquat setting?
Worth a try! See if it works for you and your track - I think a slightly longer screw would be worth fitting if you use two spacers though.
Old 08-07-2003, 10:54 PM   #2883
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I use the cut off, then a sanding drum to get it closer, then sand it to perfection.
Old 08-07-2003, 11:26 PM   #2884
Default diff case grease
I recently got a slightly used SD and when I opened the diff cases there was some light grease all over the place. Is this normal? I looked through the manual and couldn't find anywhere it says to grease the gears once the diff is built. I was just checking what the purpose would be.
Rampant is offline   Reply With Quote
Old 08-07-2003, 11:28 PM   #2885
The grease probably came from the diffs. The person might have built the diffs with a little too much diff grase. It will sling off onto the diff case cover.
Old 08-08-2003, 01:30 AM   #2886
So should I clean it out, or leave it alone?
Old 08-08-2003, 02:23 AM   #2887
analyzer's Avatar
Send a message via Yahoo to analyzer
just clean it the next time u build your diff....
in a japanese mag i browse through, they apply some diff lube to the gears...so its normal the lube will be all over inside the diff case when u run the car..
analyzer is offline   Reply With Quote
Old 08-08-2003, 08:26 AM   #2888
Trader Rating: 74 (100%+)
Default Carpet Setup??
I know it is a little out of season, but I have the itch to run on ozite. I need to know if anyone has a setup for 19 turn or mod as a base point. This will be the first time I am running the SD on carpet. Thanks for the help.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 08-08-2003, 09:28 AM   #2889
lonestar1127's Avatar
thanks guys...hope tat i got good results with the modification
lonestar1127 is offline   Reply With Quote
Old 08-08-2003, 10:15 AM   #2890
Default Re: diff case grease
Actually I used Associated Green Slime to lube the gears. You dont really need to apply anything, but it's just like adding lubrication to anything else, it should make it last a little longer, and keep temps down (not that the gears would get hot enough to get any damage)
Old 08-08-2003, 09:01 PM   #2891
Are you looking for a rubber tire or foam tire carpet setup? I have one for use with CS-27 tires.
coolrcdad is offline   Reply With Quote
Old 08-08-2003, 09:42 PM   #2892
Anywhere I can get the ratings for Yokomo springs.
Isaac is offline   Reply With Quote
Old 08-08-2003, 10:53 PM   #2893
Schuemacher had a great chart on his website, but it's no longer up. It was posted here:
http://www.rctech.net/forum/showthre...ate#post365613
Headbanger is offline   Reply With Quote
Old 08-09-2003, 02:09 AM   #2894
Nitro_Crash's Avatar
Send a message via AIM to Nitro_Crash Send a message via Yahoo to Nitro_Crash
Default The Drive Train
I have heard and seen that thet Yokomo MR4TC SD Drivetrain can be freed so much that you can spin the wheels and they can spin forever almost of course without the motor installed. How do you get it to be that free? I heard of removing the shims from the inside of the diff case. Is that correct? Or do you move the shims from the front of the bearing to the rear? HELP. Took my car apart and want to do this correctly. Thanks.
Nitro_Crash is offline   Reply With Quote
Old 08-09-2003, 06:30 AM   #2895
AllPimpRacing's Avatar
Send a message via ICQ to AllPimpRacing Send a message via AIM to AllPimpRacing
Default Finally!
Finally! Piching up My SD This Morning From the LHS!!!!! I'm SO glad to be coming Back to my roots. Should have never left my Special. Anyway, I'll be building and getting things right with it tonight!
AllPimpRacing is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
