Old 08-03-2003, 09:06 PM   #2821
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Yodace, you could try yanking that rear bar.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 08-04-2003, 07:21 AM   #2822
Originally posted by lonestar1127
Hi Lonestar,
Would you know if the rayspeed edition be available as a complete kit or just the chassis?
Thanks.
Explorer is offline   Reply With Quote
Old 08-04-2003, 07:30 AM   #2823
lonestar1127's Avatar
i'm not too sure.... i tink it would be selling as hop ups under RaySpeed
lonestar1127 is offline   Reply With Quote
Old 08-04-2003, 07:41 AM   #2824
Old 08-04-2003, 07:55 AM   #2825
See
Trader Rating: 50 (100%+)
Originally posted by Matt Howard
I'm sure there's a couple people still running the old car but the vast majority of yokomo drivers are running the SD car now, It's by far easier to work on and setup.
Matt this is STLNLST....are you racing next weekend? We really got the crowd going this weekend with the smack talk. Now they're going to expect us to battle to the death Dujuan and Mike See are going to come out next weekend too. Should be fun if the weather isn't in the triple digits. If that's the case count us out. See ya then.
See is offline   Reply With Quote
Old 08-04-2003, 08:55 AM   #2826
Send a message via ICQ to Tsubasa Sakai
Originally posted by Explorer
Hi Lonestar,
Thanks.
Rayspeed Edition will be available in complete kit.Maybe its parts will be under Rayspeed brand too.
Tsubasa Sakai is offline   Reply With Quote
Old 08-04-2003, 08:58 AM   #2827
IH
IH's Avatar
Default Mid-turn understeer
Hi guys,
I raced with my SD yesterday and I was very happy with the setup of the car. Very easy and smooth to drive. The only thing
I couldn´t get rid of was some mid-turn understeer.
Turn-in and corner exit were quite perfect.
Drove the car with 2 diffs. no swaybars. rear:green springs
front: yellow, 40wt f+r, 3 degree rear toe-in.
Any suggestions?
Thanks,
IH
IH is offline   Reply With Quote
Old 08-04-2003, 09:01 AM   #2828
mo
mo's Avatar
IH, try going to 2 degree of rear toe-in or a green front spring.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 08-04-2003, 09:01 AM   #2829
wah... tat's cool...any idea how much will it be??
Old 08-04-2003, 01:20 PM   #2830
yodace's Avatar
Jeff,
The over- all car felt pretty good just the rear of the car was a little loose. I took the rear sway bar after the last race.
What set up did you use at Mike's track and spur gear.
Caleb
yodace is offline   Reply With Quote
Old 08-04-2003, 01:24 PM   #2831
yodace's Avatar
Jeff W,
Are u still using AE springs? Have you change your set up from Mike's
Old 08-04-2003, 01:29 PM   #2832
yodace's Avatar
Hello folks,
The kit included some extra spacers, are those to be used to raise the front roll center and rear roll center? You just place them under the hinge mounts/ suspension mounts.
Old 08-04-2003, 02:46 PM   #2833
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Yodace, I used the spacers included in the kit. Just remove the screws and slide the washer under the mount...real simple tuning change, make sure you readjust droop.
The changes I made to my car are for a concrete surface with less bite then Mike's. I ran Gold front, Blue rear with 40wt. at Mike's. I think if you try the roll center change you will be pretty happy!
Jeff
Jeff Werner is offline   Reply With Quote
Old 08-04-2003, 02:58 PM   #2834
yodace's Avatar
Jeff W.
Did you but the spacers in the rear hinge pin carriers ? Are you still using AE springs? So tell me again want the spacer do for the car. Please.
Caleb
Old 08-04-2003, 03:08 PM   #2835
OSherman's Avatar
Originally posted by yodace
Jeff W.
Caleb
spacer under the hinge-pin carriers alter the roll-center..did the same with my SD, made a big difference in handling,..
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
