Old 07-26-2003, 05:40 PM   #2731
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
Help, broken screws!
Guys,
Have anyone ever experienced broken a Diff Adjusting screw?
I did that twice (Front) within 1 week.
Any thoughts?
I was running EPIC 8x1, carpet indoor track.
Is there such a thing as too much power?
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 07-26-2003, 10:30 PM   #2732
THeGame's Avatar
Send a message via AIM to THeGame
Default Re: Help, broken screws!
Originally posted by komkit
Guys,
Any thoughts?
Yes to much Power its that EPIC POWER MAN!!!!
Did you hit something then they broke. ?
THeGame is offline   Reply With Quote
Old 07-27-2003, 12:17 AM   #2733
mo
mo's Avatar
komkit, the diff screws are prone to breaking if the diff is overtightened. Try running the diff a little looser and make sure you put a lot of black greese on the thrust assembly so that it stays lubricated. If the thrust dries out, the extra friction can weeken the screw and make it snap too.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 07-27-2003, 05:52 AM   #2734
komkit's Avatar
Default Re: Re: Help, broken screws!
No, it's snaped right in the middle of the run.
Old 07-27-2003, 05:55 AM   #2735
komkit's Avatar
Okay, I'll try to back off the diff a tad.
The thrust bearing were fine when I replaced the screw both times. But I'll keep an eyes on it.
Old 07-27-2003, 09:21 PM   #2736
THeGame's Avatar
Default komkit
I should be there this weekend. I want to see this....
I give you the awsome carpet setup with foams....
Old 07-28-2003, 05:26 AM   #2737
komkit's Avatar
Default Wow!
Wow! Since when you have a carpet setup with foam?
Old 07-28-2003, 12:49 PM   #2738
yodace's Avatar
R/C Tech Charter Subscriber
I just got my car, finished putting it together at the track ran one battery. Looked pretty cool. The steering was more responsive then my old TC3.
What are your guys thoughts on running AE springs?
yodace is offline   Reply With Quote
Old 07-28-2003, 12:56 PM   #2739
rc-zombies's Avatar
TC3 springs will fit. just make sure you change the ballends and spring cups to the same ones used on the TC3. TC3 springs are longer compared to the Yok.
Old 07-28-2003, 01:03 PM   #2740
Trader Rating: 74 (100%+)
Default Making the switch
I be bitten by the shaft drive bug guys, awaiting the arrival of my SD. Hopefully this will be as good or better than my belt driven car. I can t wait to test it out. Ill keep you all posted. Any setups for a prepped asphalt track, and anything to watch for in assembly. Thanks ahead of time everyone.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 07-28-2003, 01:37 PM   #2741
utieh's Avatar
Does anyone have the last RCworld?I am really curious to see the Rayspeed Chassis for the SD.
utieh is offline   Reply With Quote
Old 07-28-2003, 02:55 PM   #2742
Default Re: Making the switch
There are setup sheets included with the kit. You can go to the Yokomousa site or look through this thread for more.
As far as assembly:
0. Optional: Remove the packed grease from all the bearings and relube with light oil.
1. You might need to use the long shock ends for the front to get proper ride height depending on if you are running foam or rubber.
2. Make sure you push the input shaft all the way into the bevel gear and use the proper shims or the diff cover may bind the gears.
3. Break-in the drivetrain by running a motor with a small pinion with a 4-cell or 5V for about 2-3 hours.
Headbanger is offline   Reply With Quote
Old 07-28-2003, 04:19 PM   #2743
SpeedTech's Avatar
Hi Guys,
Just want to let you guys know we received our Tobee Craft shipment today. All the parts for the MR-4TCSD are back in stock.
Also, Delrin outdrives for the MR-4TCSD from Japanese manufacture Excel (featured on Orion newsfeed awhile back) are in stock as well. i will get these on the website as soon as possible.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 07-28-2003, 05:20 PM   #2744
rc-zombies's Avatar
Steve..
did you get any of the new Tobee Craft aluminum front / rear body post? just curious...
Old 07-28-2003, 08:45 PM   #2745
lonestar1127's Avatar
guys any gd set up for carpet?!?
lonestar1127 is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
