Old 07-24-2003, 10:17 PM   #2716
yodace's Avatar
R/C Tech Charter Subscriber
I have not even driven the car yet.
yodace is offline   Reply With Quote
Old 07-24-2003, 10:26 PM   #2717
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by yodace
Tweak question.
When I have the car sit on my table it does not sit completely level I have no shock or electronices. I have not dropped it or anything is this normal. How do I fix the car with out buying a new chassis.
You'll need a buddy for this. Loosen all the screws on the top deck a turn or 2. Have someone push hard on the front and rear shock towers while the car is on a perfectly level surface. Tighten all the screws on the top deck back up, and your car should be tweak free. I do this several times a night with my Barracuda to ensure it stays flat.
Old 07-24-2003, 10:36 PM   #2718
Joel Lagace's Avatar
REMINDER! The only screw not contersunk on your chassis is one of the 2 screws holding your servo into the car
On a flat table or glass the car will appear tweaked or not straight
FYI
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 07-25-2003, 12:06 AM   #2719
Regional Moderator
kansasracer's Avatar
Originally posted by porter
can anyone give me a good gear ratio for a 10 turn on asphalt, that about 75'x40', fairly tight layout. I've been running about 8.1
Porter,
I have been running around a 5.4 with my Kr 10 double at fastlane. Kinda hard on the motor, but boy is it fast!!!!
You ought to come over sometime...
Posted a pic for your viewing pleasure!!!
Here is the home track!!
I am watching.....always watching....
kansasracer is offline   Reply With Quote
Old 07-25-2003, 05:20 AM   #2720
sosidge's Avatar
...so the answer is to get a small file or a dremel and just take the edges off the servo screw slot, so that screw is flush.
You can then place the chassis on a flat surface and it won't be lifted by the screw - that means you can un-tweak the chassis plates.
You don't need any extra man-power to do it - just slacken the top deck (and the centre stiffener as well if you like), sit the chassis on your flat surface (I use the kitchen worktop), check it's flat (a little twisting by your own hands may sort any minor problems, but normally it will sit flat as soon as the deck is loose), then tighten the top deck in a star pattern to keep things nice and flat.
If you have a big impact in a race, and the car feels funny, you'll probably have to redo the chassis tweak, the left rear is prone to lifting out of line (something to do with the motor mount design I think). I loosen and retighten the chassis after every meeting.
Old 07-25-2003, 07:53 AM   #2721
Fuzzy's Avatar
Default carpet performance
Well, here is my first post on this forum and I have a question that needs answering. Why do I keep hearing that the Yokomo SD SSG is a slug on the carpet? I think I heard something about the diff cases flexing and causing the drivetrain to bind. Is there any truth to this? I was disappointed to hear this because I am really itching to buy one. Now I don't know if I want to give up my TC3.
Fuzzy is offline   Reply With Quote
Old 07-25-2003, 08:06 AM   #2722
I dont feel its a slug on carpet. IT goes as good as anyother car on carpet.
I also own and run a TC3 and found this car runs fairly similar.
As for this diff binding deal. I have yet to see it on my car. The gear case covers are held on with 2 screws and i guess some guys are torquing the hell out of them. They are simply covers to close the gear box. So they only need to be a 1/8th of turn past hand tight. This cover is different in comparison to the TC3 in that if you dont get it on tight it can come loose and effects your shock towers.
www.rcottawa.com
Old 07-25-2003, 08:13 AM   #2723
Fuzzy's Avatar
Thanks Joel.
Old 07-25-2003, 10:25 AM   #2724
lonestar1127's Avatar
thanks Joel Lagace and pro-zombies
lonestar1127 is offline   Reply With Quote
Old 07-25-2003, 11:15 AM   #2725
Trader Rating: 47 (100%+)
kansasracer, track looks good, I can see why your running such a tall gear, very wide open. I don't believe a gear like that would work at mikes, it would take the whole strait to spool up and still wouldn't be at top speed. My 8.1 seems to work just right just wanted to see others opinons.
I'll try and make it up at least once before summers end, I think a group of topekans are going to witchita this weekend.
Yodace bring your car into mikes saturday, I will be ther to help you out.
P.S. Joel is right about that servo screw be sure to countersink it some how. your car sould sit completly flat on a level surface.
porter is offline   Reply With Quote
Old 07-25-2003, 01:14 PM   #2726
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Would be cool to have you guys come race in Wichita. That is good to hear.
I know on the track we race on that the 8.0 to 8.5 is the range that I have found to work well with most 10 turn mods. Never had a stock motor in the car and would not know where to start on one of them.
Jeff
Jeff Werner is offline   Reply With Quote
Old 07-25-2003, 02:57 PM   #2727
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
hey guys i just saw on the yok homepage the SD BLACK special
Homepage
it fades from the SD to the GT-4 rtrII
whats the differnece between the two chassis?
-R
_|Team Academy GV2 Pro_|_Team Academy SBV2 Pro|_--->Losi xxxbK2 (FOR SALE)
_|Factory Tracks Midwest Series_|_www.factorytracks.com|_
_|Team Upgrade-RCid_|_www.upgrade-rc.com|_
_|MRC/Team Academy_|_www.modelrec.com|_
rdub202 is offline   Reply With Quote
Old 07-25-2003, 03:02 PM   #2728
The black one is slightly stiffer then the SSG special. other than that they are exactly the same.
James Nguyen is offline   Reply With Quote
Old 07-25-2003, 04:25 PM   #2729
peter_robinson's Avatar
Trader Rating: 21 (100%+)
i personally run the black chassis version, and i feel that it is more than just slightly stiffer. it also looks a little better to me, i am not the biggest fan of the silver stuff.
For orders or inquiries, email [email protected] Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 07-26-2003, 01:34 AM   #2730
johnbull's Avatar
Hi guys. greetings from Malta.
I run my SSG with the centre brace fitted.
There's lots of talk of the black version being stiffer. But do we really need this car to be any stiffer.
The two top guys in England, Adam Rogers and Chris Grainger have both removed theirs and run without it, and masami ran without it at the Reedy race too.
Who am I to argue with them on what's good and what isn't?
Granted that they all run on asphalt. You guys could be right for Carpet in which case the ideal situation would be a black car for carpet and a silver car for asphalt.
Sounds abit expensive to me.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
