Old 07-24-2003, 12:41 AM   #2701
Matt Howard's Avatar
I didn't grease the gears and the car will loosen up quite a bit after running a couple of packs
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 07-24-2003, 04:51 AM   #2702
sosidge's Avatar
...and once you've run the car a bit you can adjust the shimming on the input shafts and the diffs to get a slightly freer mesh, with a tiny bit of backlash.
Old 07-24-2003, 07:43 AM   #2703
kt racing's Avatar
Send a message via AIM to kt racing
I was wondering if you guys put any grease were the diff and the input gear meet.
yodace,
The drivetrain will free up some. If you really want to get the gear mesh smooth. Put some toothpaste in the mesh. And then spin the diffs over for about 2min. Then take it apart and clean all of the toothpaste off. Relube everything put just alittle bit of grease on the gears if you want. I don't because the grease attracts dirt.
And then the diffs should be good and smooth. Sounds crazy but it works well. also take the diff cases out and spin it with a cordless drill this seems to work the best.
kt racing is offline   Reply With Quote
Old 07-24-2003, 08:28 AM   #2704
lonestar1127's Avatar
guys...anyone tried sd setup on carpet..
isit better to remove the center bar of sd??
lonestar1127 is offline   Reply With Quote
Old 07-24-2003, 09:56 AM   #2705
Joel Lagace's Avatar
I am running mine on carpte with rubber and stock motor.
My 3rd race with it tonight. And i plan to use a oneway. I have been pushing through the 180s hope this helps.
Here is my track:
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 07-24-2003, 10:59 AM   #2706
Here is my track:
wat abt removing the center stiffener??? the small ssg bar below the top deck
Old 07-24-2003, 11:12 AM   #2707
I would not recomend it at all. On carpet the traction is high and the cornering hard. You typically want a very stiff chassis. Especially when i go to foams. But i wont be removing that stiffner for rubber either.
www.rcottawa.com
Old 07-24-2003, 11:13 AM   #2708
rc-zombies's Avatar
yes..definately remove the center brace.
Old 07-24-2003, 11:15 AM   #2709
Remove it for carpet? Why?
I have been skooled to think stiff on carpet flexy on pavement.
www.rcottawa.com
Old 07-24-2003, 11:35 AM   #2710
THeGame's Avatar
Send a message via AIM to THeGame
Yea I would leave Both top deck and the center brace on for carpet.
THeGame is offline   Reply With Quote
Old 07-24-2003, 12:19 PM   #2711
The Teacher's Avatar
Trader Rating: 49 (100%+)
He's running rubber tires not foams....
The Teacher is offline   Reply With Quote
Old 07-24-2003, 12:56 PM   #2712
could someone post all the problems with this car? i wanted to know because i think im going to buy one next week.
jiggamacdaddy is offline   Reply With Quote
Old 07-24-2003, 03:52 PM   #2713
Trader Rating: 47 (100%+)
can anyone give me a good gear ratio for a 10 turn on asphalt, that about 75'x40', fairly tight layout. I've been running about 8.1
porter is offline   Reply With Quote
Old 07-24-2003, 07:26 PM   #2714
JimmyMac's Avatar
8.1~8.5 would be good. If's it's very technical, I'd start on the 8.5 side. Does your motor wind out on the straight? Or is it still accelerating? A good deal would be to try 8.1 in one qualifier and 8.5 in the other. Compare lap times......
JimmyMac is offline   Reply With Quote
Old 07-24-2003, 10:16 PM   #2715
yodace's Avatar
R/C Tech Charter Subscriber
Tweak question.
When I have the car sit on my table it does not sit completely level I have no shock or electronices. I have not dropped it or anything is this normal. How do I fix the car with out buying a new chassis.
yodace is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
