Old 07-11-2003, 06:23 AM   #2536
kt racing's Avatar
Send a message via AIM to kt racing
Ingo,
About the drive pins. I actually when and got a thicker oring that goes around the drive cup. The thicker oring's cover the entire pin. I haven't lost one yet.
kt racing is offline   Reply With Quote
Old 07-11-2003, 06:51 AM   #2537
Default pm
Hi Johnbull, you have PM.
Mafodda is offline   Reply With Quote
Old 07-11-2003, 07:46 AM   #2538
lonestar1127's Avatar
Originally posted by CSF0623
I would think so too! You only raced the car once then you sell it the next day! Hope the R2 works better for you..just my 2 cents.
Carl
randman...u broke yr top deck or u purposely cut it??
lonestar1127 is offline   Reply With Quote
Old 07-11-2003, 08:42 AM   #2539
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by johnbull
Hi guys. Greetings from Malta.
RANDMAN.
I'm not surprised you complain of flex, without a top plate! I don't think you gave the Sd much of a chance, did you, though I can understand your fascination with the R2. I think it's a great car too. I could have had an R2 if the manufacturers showed any initiative towards selling them here.
Since they couldn't be bothered I'll stick with what I've got.
Regards
Joe from sunny Malta.
The top deck in the pics was just to test with, made it mainly to reduce the tweak the car would get by twisting, and to get a little more flex for looser tracks. The car was run with a full top deck at SoCal.
Old 07-11-2003, 08:50 AM   #2540
Originally posted by sosidge
I'm surprised you say the car lacks durability when you've only raced it hard for four packs - I've raced it hard for three months and I haven't broken or damaged a thing (granted my track has forgiving barriers and I don't crash very often).
I put about 10 packs on it, and was able to break on 2 of them. First time my radio went nuts and I lost control, someone got on my frequency, and I wouldn't expect any car to make it out of that running, but I managed to rip the left side of the car clean off. Second time was in the first qualifier, they mixed pro mod with sportsman mod, and as I was entering the straightaway from the sweeper, there was a car parked behind the roof supporting pole for SoCal that I couldn't see, and bam. There went the right front. The problem I had with the car is it wouldn't just break 1 part in those collisions, it would rip everything from limb to limb...
Old 07-11-2003, 12:35 PM   #2541
Fatboy Joe's Avatar
Default John Bull
Hi, you have a PM from Fatboy Joe
Fatboy Joe is offline   Reply With Quote
Old 07-11-2003, 01:03 PM   #2542
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Finally back from vacation at the beach and now I have a visious sunburn. Damn it hurts!!!!!!!!!! Had to catch up reading the Yoke stuff I missed.
ST Racing Concepts (STRC)
Old 07-11-2003, 04:56 PM   #2543
JimmyMac's Avatar
LittleDog, my car is set to 3.5mm ride height (up front) at times. This is with rear shock tower on front, rayspeed springs all around, and AE shock retainers and normal ball cup ends like on the turnbuckles.
Right now the car is set to about 4mm up front. Play around with shock length. That might help ya some. I also switched to another shock end that allows me to use the normal screws on the Yok.
KT, how do you like your car?
JimmyMac is offline   Reply With Quote
Old 07-11-2003, 06:24 PM   #2544
littledog's Avatar
R/C Tech Charter Subscriber
I'm a little confused bout what you are sugesting could you explain a little mor in detail?I have messed with the shock lengths and I still am at a minimum of 5 mm.Whith bout 8mm droop mimmum.I can't seem to get it any lower.It must be sumthing I have done during assembly.
littledog is offline   Reply With Quote
Old 07-11-2003, 07:51 PM   #2545
wyd
Tech Legend
wyd's Avatar
littledog what size tires are you using. I know when I built my SD to the stock book setup and put on 63mm tires my car was under 5mm of ride height to start with. Not sure how your car is so much higher. The stock setup is for rubber tires, thats for sure. With the stock setup I could never run my foams down to 57mm like I do.
Johnbull glad to hear your car is back to the way you like it. Spools are not for everyone. I had to do what you said and be alot more aggressive and drive the car a little harder than I normally would. It is very strange for me to do that. I have always ran diffs. Up until about a month ago I never ran a spool. A learning experiance to say the least. I did struggle for sometime.
I'm sure I will struggle again when I try my new one way when it comes in. I bet I will hit a few things for sure!!!!!!
Old 07-11-2003, 07:58 PM   #2546
Maj. Teeth's Avatar
Default Having the same problems
Ok, this is funny because I'm having the same ride height problems as littledog. What I used was the same Yokomo shocks, AE springs, AE retainers and AE #7217 shock ends and screwed on to the shaft leaving no more thread at all whatsoever and still gets 5.5mm front and 9mm in the rear so I'm thinking something is definately wrong. What other shock ends will be shorter?
Can someone be kind enough to post EXACTLY what you did to achieve the correct ride height? I was scared to death when I mounted the extra rear shock tower up front and see my ride heights changed from 5.5mm to 9mm.. LOL.. Something is definately wrong here.
What was the actual problem with the Yoke springs beside being shorter? I'm confused.
Dan
P.S. also, can someone post their set with the rear shock tower up front? Trying to figure out roll center without experimenting. Thanks.
Maj. Teeth is offline   Reply With Quote
Old 07-11-2003, 08:08 PM   #2547
THeGame's Avatar
Send a message via AIM to THeGame
This is what i do.. If your running the AE springs or ray speed springs set your shocks to 64mm, Using Stock Yok springs set to like 59mm or 60mm. Set ride hight then your droop...
THeGame is offline   Reply With Quote
Old 07-11-2003, 08:10 PM   #2548
THeGame's Avatar
Default wyd
What color Shock springs are you runing ?
Your junks looks good on the track...
Old 07-11-2003, 08:14 PM   #2549
Maj. Teeth's Avatar
Sorry for my ignorance but I still don't quite understand. I've already screwed my shocks down to 63mm and still getting a 9mm ride height in the rear. So with 64mm, then it'll be even higher right? Now, did you use the AE shock ends? or some other brand? Cause the Yoke ends won't fit the AE retainer.
How I have my droop up front at 7mm and rear at 3mm. From using the HUDY blocks.
Please further enlighten me.
So, it's the Standard Yoke shocks, AE or Rayspeed springs, AE retainers and what?? shock ends?
Thanks again.
Dan
Old 07-11-2003, 08:16 PM   #2550
Matt Howard's Avatar
I've been using AE ballcups for shock ends and screwing the ball into the arm so you just snap your shock on. This is with using the rayspeed springs and AE spring cups
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
