Old 07-10-2003, 08:07 AM   #2506
i think the two most exotic cars are the 414m2 wcr then the evo 3 s then the r2.
i dont think yoke r that exotic.most places sell them.lol.exotic is things that are hard to get hold of[like limited edition]no way is the yoke limited
trf racer is offline   Reply With Quote
Old 07-10-2003, 08:08 AM   #2507
utieh's Avatar
durable and exotic was for the R2
its arms are like a 1/8 buggy's and it is absolutely impossible to find one in my country! but the car changes often and PAL option parts seem to be pretty expensive
utieh is offline   Reply With Quote
Old 07-10-2003, 08:12 AM   #2508
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
pretty true... now i dont kno which car to get again... black or ssg sd or cuda r2
cHckbOY5 is offline   Reply With Quote
Old 07-10-2003, 08:50 AM   #2509
Regional Moderator
Darkseid's Avatar
Got a question for you guys.
I'm this close to eliminating the use of all my allen wrencehes and replacing them with hex drivers.
But, I need to know what size hex the set screws, for the swaybars sliders, use on the SD? They also happen to be the same size as the set screws Yokomo uses on their pinions, if that helps any.
Can anyone who is already using a hex driver for these set screws hit me with a size. Only people who know for sure....no guessing guys!
TLR 22...Tamiya F104...
Old 07-10-2003, 08:56 AM   #2510
1.5 pinion
2.0 chassis
2.5 motor screws
I use the Losi set but Yok has their own along with others.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 07-10-2003, 08:57 AM   #2511
Randy Caster's Avatar
Trader Rating: 46 (100%+)
You will need 1.5mm for the set screws. A 2.0mm should work for just about everything else, but get a 2.5 as well. Nut drivers you'll need 5mm, 5.5mm, and 7mm.
Old 07-10-2003, 08:58 AM   #2512
BTW, I use Hudy tools, very easy to get from their E-Shop, and you can easilly replace the tips if you break one.
Old 07-10-2003, 09:14 AM   #2513
kentech's Avatar
Could somebody that has RC World magazine scan some pictures of the Rayspeed SD chassis once the new issue of the mag is out? Thanks!
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 07-10-2003, 09:27 AM   #2514
sosidge's Avatar
Originally posted by trf racer
just 1 question for all u sd runners.wot made u buy a sd over a tbevo 3?just wandering.
UK price for the EVO III is too high and The Hobby Company have a poor reputation for spares supply, whereas the SD is a better price, and CML have a good reputation for spares (even though SD parts seem to have been a bit slow reaching the shops, a friend broke his SD wishbone over a month ago, and couldn't get a part for at least two or three weeks).
Plus I already had a Yokomo buggy, and I liked the quality and handling, and the Yoke belt drive car always ran well locally.
Old 07-10-2003, 09:29 AM   #2515
Koya Dale.com's Avatar
Send a message via ICQ to Koya Dale.com
johnbull: been testing yesterday and found out that the stratus 1 seems to be the best overall body for the yoke. i've tried the the stratus 1, stratus 2.0 and the alfa 2.0 and the stratus is the best handler, lots of grip compared to the other 2.. but i tested that on carpet which has tons of steering. will test the alfa tomorow on asphalt
Koya Dale.com is offline   Reply With Quote
Old 07-10-2003, 10:01 AM   #2516
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
I`ll get some pic`s of the Ray Speed Chassis for you guys here within the next..day..
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-10-2003, 10:03 AM   #2517
NightKidZ's Avatar
Send a message via ICQ to NightKidZ
For the motor mounting screws, its best to use a 2.5mm tool with a "ball" end, like the one supplied with the kit. It makes it much easier to adjust the gear mesh "off centre" without removing the rear arm.
Cheers
NightKidZ is offline   Reply With Quote
Old 07-10-2003, 10:03 AM   #2518
utieh's Avatar
can't wait
Old 07-10-2003, 10:19 AM   #2519
Regional Moderator
Darkseid's Avatar
1.5mm.....I knew it! I had the chance to pick one of those up cheap a while ago, and passed on it. I knew I should have gotten it!
I already have an MIP 2mm (from my days with my first Yok) and a Losi 2.5mm for the motor screws.
I guess I'll have to go pay full price for the 1.5mm now.
Thanks for the quick answers.
Old 07-10-2003, 11:50 AM   #2520
you dont actually need to take out the rear arms top reach the bottom motor mount screw, just squeeze the arms up and insert the wrench under the arm and u can reach for the screw
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
