Old 06-29-2003, 07:11 PM   #2251
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by ckh1328
Hi guys. I haven't post any message here for a long time. I used to drive a TA03F before, but once I see the new Yo SD, I sold my TA03F with the hope up (carbon chassis: lower & upper, aluminum shocks, a Rooster ESC, n with few other parts). I got my SD few weeks ago from speedtech and just had my first test run indoor carpet today with my friends. However, After like around 3 laps (hitting on the wooden wall at the side of the car few times), the front-right steering block broken. And here are some of my SD pics and my Pro pics.
Does any of you guy know is there any aftermarket Steering block like Aluminum or Titanium steering block?
If so, does it preform better than the stock one?
Or is there any other setup I can try to help reduce the breakage or parts? Well, I am using the stock setup.
Thank you vey much, guys.
By the way, is the steering block and steering hub carry comparable to SD from the Pro or SP? Thanks.
What else I should buy to make my SD stronger? Please let me know the parts number too. Thank you very much.
Team Suzuki makes steering blocks, very well made, fit perfectly on my SD. You can get them for about $30 at rainbowten.co.jp
Old 06-29-2003, 07:19 PM   #2252
Joel Lagace's Avatar
Question?
When you guys talk about spools you basically mean a limited slipping diff right? Your building a slipper clutch within your diff right? Losi used slipper pegs instead of diff balls to achieve this.
Does anyone use solid diffs? as in no diff action. A locked diff? I had used those on my nitro car and found they caused alot of push off power.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 06-29-2003, 07:28 PM   #2253
I think there are Team Suzuki aluminum parts. You can search back through this thread to find the specifics.
Also, Joel Legace made a bigger front bumper. That should cut down on th breakage.
Square makes Ti axles and dogbones. Speedtech might have them soon. Tobee Craft make aluminum parts, too.
Headbanger is offline   Reply With Quote
Old 06-29-2003, 07:46 PM   #2254
THeGame's Avatar
Send a message via AIM to THeGame
Default Joel Lagace
A spool is a locked Diff.
Yokomo Hasnt mad a solid front yet. It should be out soon...
THeGame is offline   Reply With Quote
Old 06-29-2003, 07:46 PM   #2255
JimmyMac's Avatar
A spool is a locked diff or solid axle. That is at least the reference or terminology that is understood in Touring talk.
JimmyMac is offline   Reply With Quote
Old 06-29-2003, 07:49 PM   #2256
THeGame's Avatar
Default KilRuf
what happend man ??? bad luck again.. Heard Chirs broke at the first Turn .. Man that sucks....
Old 06-29-2003, 08:00 PM   #2257
Who are our new national champions.
Old 06-29-2003, 08:05 PM   #2258
THeGame's Avatar
Default Randman
12th Scale Stock: Mike Dunnigan
12th Scale Modified: Josh Cyrul
Touring Car Stock: Mike Dunnigan
Touring Car Modified: Mark Pavidis
Old 06-29-2003, 08:47 PM   #2259
Cool, any idea where I can get full results?
Old 06-29-2003, 08:57 PM   #2260
THeGame's Avatar
look right on the main page of Electric On road...
Old 06-29-2003, 09:00 PM   #2261
Team Suzuki only has Aluminum Front Knockle for MR4TC SD , Aluminum Rear Knockle for MR4TC SD , n Aluminum Upper Deck Mount for MR4TC SD .
I can't find the Steering Block.
ckh1328 is offline   Reply With Quote
Old 06-29-2003, 09:13 PM   #2262
Oh, sorry, I found it, is that Team Suzuki - Aluminum Front Knockle for MR4TC SD. Thanks a lot.
Old 06-29-2003, 09:29 PM   #2263
Hi guys. Does anyone know where I can order Team Suzuki - Aluminum Front Knockle for MR4TC SD in the United States web site? I found two stores online, but one is in Japan, and one is in Hong Kong. You know that Knockle is around $35, and the shipping from Hong Kong is like another $30. If there is another store in USA, the shipping will be around $7. That will be a huge different. Please let me know if you know it. Thank you.
Old 06-29-2003, 09:49 PM   #2264
rainbow ten doesn't charge much for shipping, I've ordered a couple times from them with great results.
Old 06-29-2003, 10:05 PM   #2265
I c, but rainbow ten they take order by email, and you have to type all ur credit information out through email. It is not that safe, right?
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
