Old 03-13-2003, 11:10 PM   #196
icon's Avatar
Send a message via AIM to icon
i wonder why the changed the position for the front sway bars. the early pictures show the swaybar mounted on the upper deck with the sways going towards the lower shock mount. now the new pics have the sway mounted on the bulkhead. is it to make the front and rear sways symmetrical?
icon is offline   Reply With Quote
Old 03-14-2003, 12:37 AM   #197
Diva's Avatar
Send a message via Yahoo to Diva
Red face
Here is the manual. Pretty nice
Diva is offline   Reply With Quote
Old 03-14-2003, 02:01 AM   #198
johnbull's Avatar
Hi guys. Greetings from Malta.
Just one thing I'm not seeing that I would have liked.
The TC3 now has a spacer between the wheel bearings. Thus no matter how much you tighten, the bearings don't bind.
So simple. The MR4 has no spacer so overtightening wheel nuts can cause the bearings to drag. Now it looks like the new SD doesn't have this pacer either.
What a pity.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 03-14-2003, 02:06 AM   #199
Post
Hi Guys,
Here are some refs with release pricing, availability should be for April ?
SD-001 FRONT PLASTIC BUMPER : 380YEN
SD-001FS FRONT URETHANE BUMPER : 450YEN
SD-002 SSG GRAPHITE MAIN CHASSIS : 6800YEN
SD003USS GRAPHITE UPPER DECK : 1800YEN
SD003LSS CENTRE STIFFNER : 980YEN
SD003LM CENTRE STIFFNER MOUNT : 350YEN
SD007T UPPER I ARM : 1980YEN
SD-008 LOWER SUSPENSION ARM : 500YEN
SD-009 SUSPENSION ARM PIN : 720YEN
SD-010FS L.F. UNIVERSAL DRIVE SHAFT : 2000YEN
SD-017SSG GRAPHITE FRONT SHOCK TOWER : 980YEN
SD-018SSG GRAPHITE REAR SHOCK TOWER : 1280YEN
SD-118 BATTERY PLATE & MOUNT SET : 720YEN
SD-200B SERVO SAVER POST/LOWLET NUT : 420YEN
SD-200L SERVO SAVER MOUNT : 580YEN
SD-203 SERVO/STABILIZER/ANTENNA MOUNT SET : 580YEN
SD-204 SERVO HORN SET : 300YEN
SD-300 F&R SUSPENSION MOUNT SET : 650YEN
SD-302 TRANSMISSION CASE : 980YEN
SD-303F FRONT INPUT SHAFT : 580YEN
SD-303R REAR INPUT SHAFT : 650YEN
SD-303S INPUT SHAFT M2.6x6 COUNTERSUNK SCREW : PENDING
SD-304 ALUMINUM MOTOR MOUNT : 1500YEN
SD-401HC F&R HUB CARRIER BALL : 260YEN
SD-412 STABILIZER WIRE : 300YEN
SD-4134 FRONT STEERING HUB CARRIER : 580YEN
SD-414 KING PIN SET : 200YEN
SD-415 STEERING BLOCK/REAR HUB CARRIER : 580YEN
SD-501 DIFF JOINT/DRIVE CUP : 400YEN
SD-501R ALUMINUM DIFF JOINT RING : 200YEN
SD-503 RING GEAR/DRIVE GEAR SET : 380YEN
SD-630 SPUR GEAR ADAPTER : 980YEN
SD-640T HD FRONT ONE WAY ASSEMBLY : 3600YEN
SD-640TM FRONT ONE WAY MAINTENANCE KIT : 120YEN
SD-614T FRONT ONE WAY HOUSING : 2800YEN
SD-643 RING GEAR/DRIVE GEAR SET : 380YEN
SD-644 MAIN DRIVE SHAFT : 680YEN
SD-644G MAIN DRIVE SHAFT GRAPHITE : 2600YEN
BB-1480P SUPER PRECISION BEARING 2PCS : 980YEN
BB-1050P SUPER PRECISION BEARING 2PCS : 980YEN
ZC-N4AFB 4' FRANGE LOCK NUT : 280YEN
ZC-N3AB 3' NYRON LOCK NUT : 150YEN
SD-HDC HEIGHT & DROOPE GAUGE : 580YEN
Regards,
Ralf is offline   Reply With Quote
Old 03-14-2003, 05:25 AM   #200
sosidge's Avatar
You know, I think it's very telling that the best criticisms we've come up with for the car so far are "I don't like the plastic battery strap" and "I wish Yokomo had put a tiny plastic spacer between the wheel bearings"!.
I'm a big fan of good design - and this Yoke just seems to have all the shaft-drive design principles spot on.
Lets hope it runs right on the track.
(PS I bought a Pro 3 becasue of it's design - shame about the material quality - I've stiffened and shimmed it up now and it's a good car)
Old 03-14-2003, 10:42 AM   #201
RBLove's Avatar
Trader Rating: 72 (100%+)
Wheel bearing spacer is not a big deal. The TC3 has had this in their Team Kit and FTTC3 for quite a LONG time. I am sure you can come up with something to use as a spacer.......
This looks like it is going to be a good car. I think we should let the car actually get here before we start wishing and wanting!
This thread gets funnier and funnier as I read!
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 03-14-2003, 11:28 AM   #202
007yoshi's Avatar
ACTUALLY- for those who own the MR4 TC SP, use the clamp hexes instead of what comes in the new one. For some reason, the way they work, those clamp hexes wont get any closer to the bearings past a certain point and its impossible to tighten the wheel nuts too much. Ive tried but never couold get it to bind.
007yoshi is offline   Reply With Quote
Old 03-14-2003, 11:58 AM   #203
johnbull's Avatar
YOSHI.
Quite right. That's what I use in fact on the MR4, but I do like the idea of a spacer, just like they have in real cars.
Still, like RBLove says, these are little things. The car itself looks great and i'm sure it will be.
I can't wait for mine, even though my Sp still gives me pleasure and wins.
Regards
Old 03-14-2003, 12:40 PM   #204
Regional Moderator
Darkseid's Avatar
icon: I don't know why they changed it in the newer pictures. On the spec sheet, they say that we'll have the option of mounting the front swaybar up top or down low. Maybe they just wanted to show it in both positions.
TLR 22...Tamiya F104...
Old 03-14-2003, 12:45 PM   #205
Matt Howard's Avatar
it will come stock with the lower mounted swaybars, pretty much like on a tc3. It looks like the upper swaybar setup from the mr4tc special will fit on the car with no modifications if you want to mount it up like that.
Matt Howard is offline   Reply With Quote
Old 03-14-2003, 03:08 PM   #206
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
The one on my SP (front right) would bind all the time. I would have to loosen the hub and then retighten it. I tried not tightening the wheel very much, changing the bearings, swapping the inner spacer from the other front wheel hub, everything I could, but that one side would always get tight and when it did you could feel the bearing binding. Now that I think about it, it may have been the axle since that's the only thing I never changed....
BigDogRacing is offline   Reply With Quote
Old 03-14-2003, 05:05 PM   #207
007yoshi's Avatar
BigDog- LOL maybe so. I always sock my wheelnuts down and never have any binds. Oh hey we got the track here in baton rouge opened up now. You oughtta come see it sometime in the future.
Old 03-14-2003, 09:01 PM   #208
Send me some pics- you know we don't have an indoor track so we WILL travel!!! How big is it?
Old 03-15-2003, 12:20 AM   #209
007yoshi's Avatar
LOL
Its 100 x 45ft. 8 foot lanes, ozite, indoor of course.
www.CapitolCityRC.com
Its still under construction, its a temporary site but gets the point across
Old 03-16-2003, 08:16 PM   #210
Kenneth Tan's Avatar
7 Days to Launch!
Kenneth Tan is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
