Yokomo MR-4TC SD
Old 06-17-2003, 02:14 PM
  #2026
Thank You..R-C Zombies on the info!!!!!!
Tom M is offline
Old 06-17-2003, 02:32 PM
  #2027
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Isn't the NTC3 shaft aluminum?
Randy Caster is offline
Old 06-17-2003, 03:59 PM
  #2028
the NTC3 is alum but it fits
Chris@WeaponR is offline
Old 06-17-2003, 04:54 PM
  #2029
The stock shaft is aluminum, I am looking for CF because it's lighter weight.
Old 06-17-2003, 05:03 PM
  #2030
Default More newb questions.
I just assembled and installed the front shocks on my MR-4TC SD and the edge of a bare wheel/rim rides very slightly lower than the chassis...between 1-2 mm. Is this normal, or should there be more clearance?
kidsafe is offline
Old 06-17-2003, 06:03 PM
  #2031
Just got my order from RainbowTen today, the Suzuki steering blocks are extremely nicely made, and the anodizing matches the SD perfectly. Square axles fit perfect, also bought their delrin shim kit, and it came out great as well.
What kind of gear ratio should I run on a Reedy Kr 8x2 for a track with 90-100 foot straight?
Old 06-17-2003, 06:34 PM
  #2032
CSF0623's Avatar
Randman: How is the performance of car on the track? Have you ran your car yet? Are all these hop-ups needed?
CSF0623 is offline
Old 06-17-2003, 06:39 PM
  #2033
Kenshin's Avatar
Randman, I see that you got bitten by the R10 buying bug too.
Kenshin is offline
Old 06-17-2003, 07:21 PM
  #2034
JimmyMac's Avatar
I got my order in today too from RainbowTen. I too got the Suzuki Steering Blocks and a few other things. They look nice! Didn't get my Tobee Craft light weight main shaft though. Maybe next time when they actually have them.
As for the Graphite Shaft, mine is okay so far. Been racing it in Stock so far. But I have ran a few packs of Mod through it as well. I guess I'll have to switch back to the stock one for the Nats.
Lonestar, my opinion on the SD is that it's a great well designed car. Yes it's new. And yes it will go through changes. But the XXX-S has and so is the TC3 (still changing/improving). So you will not get one car that is "perfect." As for flaws... the only thing I don't like are the front axles. But I bought titanium ones to correct this. The main problem is they tend to break easy. But I've only broken one of them out of the 2 SD's that I own. I've had 2 TC3's in the past... XXX-S and XXX-S G+ and other cars as well. The SD is a great car. Very easy to work on and maintain. It won't be a wrong decision as long as you can get parts for it where-ever you are. TC3 is not a bad car either. As I'm sure you know. If you are just looking for resell value... I dunno. They both cost almost the same new. I think this is just a personal decision.... so why not just try something new!!
Anyways, like a kid with candy... or new toys... I gotta go play with my RainbowTen Order!!
JMac
JimmyMac is offline
Old 06-17-2003, 09:23 PM
  #2035
Regional Moderator
Darkseid's Avatar
The car is quite potent in stock form. It performs well and is very durable.
Darkseid is offline
Old 06-17-2003, 09:25 PM
  #2036
SpeedTech's Avatar
Hi Guys,
I'm updating the website with our shipment of Tobee Craft stuff as we speak. I should have the SD section up tonight.
My goal with Speed Tech R/C is to be able to carry the parts you guys need so you guys wouldn't have to purchase from over seas anymore
Steve Wang
SpeedTech is offline
Old 06-17-2003, 09:27 PM
  #2037
Matt Howard's Avatar
I'll keep refreshing your site so I can order some stuff tonight
Matt Howard is offline
Old 06-17-2003, 09:44 PM
  #2038
SpeedTech's Avatar
Hi Guys,
It's up right now, have at it! here's a direct link to it:
http://64.70.208.72/speedtechrc/186.html
Steve Wang
Old 06-17-2003, 09:52 PM
  #2039
you just got my order
Old 06-17-2003, 09:54 PM
  #2040
mo
mo's Avatar
Mine too.
mo is offline
