Old 06-05-2003, 02:13 AM   #1741
johnbull's Avatar
Hi guys. Greetings from Malta.
TYRES & INSERTS.
Someone earlier asked for suggestions for tyres / inserts for medium grip asphalt track.
Here is my experience from running my own MR4 Special, my son's TC3, and now my SD. We run rubber tyres exclusively, and temperatures here are always pretty hot.
TAKE OFF with Schumacher Grey insert. 27 lasts for ever and grips consistantly throughout. Grip not half as good with it's own blue or black moulded insert. 22 gives better grip, even in hot temperatures but does not remain as consistant over long use.
PITS. Probably the best all rounder. Again with Schumacher Grey insert. The D30 has more grip than both Take Offs but performance tapers off with wear and wear is not as good as Take Off. In the winter months we have even used D25. On a track with less grip in England (West London) we found the D25 worked best with it's own soft insert, even on a hot (by English standards) day.
SOREX. Tops for grip, but they don't half wear! Again found Schumacher Grey insert works best with Sorex 28 or 24. Son Josh does 2 x 5 minute heats on a set of 28s in modified. After that they are very thin. They are excellent when new, but performance tapers off with wear. On a really cold day the 24 works as well and at least lasts a couple of heats.
MO. I see you are into organising too. I know the feeling. I virtually run our club single handed.
Someone asked for picture of servo mod. See attachment.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 06-05-2003, 04:23 AM   #1742
sosidge's Avatar
Originally posted by Randman
I haven't tried limiting the shocks yet, but I guess it couldn't hurt at this point, I dont see why there is no way to lower the car any more than it is, even with large diameter tires.
Don't use internal spacers to force the shocks shorter than the springs will allow - you'll end up with no droop and strange handling as a result. I run large diameter tyres (schumacher minispikes, 66mm+ when new), and I can get the car down to about 4mm with the short shock ends and the standard mounting positions.
Old 06-05-2003, 07:53 AM   #1743
sosidge's Avatar
Found some new parts...
Team Suzuki steering uprights...
Team Suzuki rear hub carriers...
Team Suzuki top deck mounts (look good to me)...
Rayspeed shock pistons (looks like one has no holes - relying on flow around the edges I suppose)...
Old 06-05-2003, 09:06 AM   #1744
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Ahh finally, blue goodies Anyone know if they are avalible yet, or when they will be avalible? I think the front steering knuckles will be a bad idea seeing as how many castor blocks break as it is with plastic knuckles, you're gonna be breakin a lot more.
Old 06-05-2003, 09:14 AM   #1745
rc-zombies's Avatar
Originally posted by Yokomo_King
Does anyone have picture of the Servo Position diffrently like how the yokomo MR4-SP had?
I have mine rotated 90deg...similar to TC3 configuration.
Old 06-05-2003, 09:18 AM   #1746
V12
V12's Avatar
@ johnbull
Do you have a part number for the Schumacher Grey inserts?
V12 is offline   Reply With Quote
Old 06-05-2003, 10:23 AM   #1747
When you rotated your servo did you drill a hole in your chassis? or did you use SErvo Tape?
Yokomo_King is offline   Reply With Quote
Old 06-05-2003, 10:28 AM   #1748
rc-zombies's Avatar
drilled and countersunk holes in the chassis...
You will have to cut the inner ear of the servo in half to make it fit under the middle deck. and move the steering linkage to the left side and change to 180deg steering.
Old 06-05-2003, 10:40 AM   #1749
can someone get me the part numbers on the blue stuff so i can make and order for them.
Chris@WeaponR is offline   Reply With Quote
Old 06-05-2003, 10:42 AM   #1750
Steering Knuckles - TS2100
Rear Hubs - TS2101
Upper Deck Mounts - TS2102
James Nguyen is offline   Reply With Quote
Old 06-05-2003, 10:46 AM   #1751
on these parts, thanks james for the other part numbers tho and are you going to tcs?
Old 06-05-2003, 10:50 AM   #1752
Chris,
These parts are not available yet, except the blue battery holder posts : SD 118M
Ralf is offline   Reply With Quote
Old 06-05-2003, 10:51 AM   #1753
Im not going to the TCS race and those part numbers arent available yet.
Old 06-05-2003, 10:53 AM   #1754
rc-zombies's Avatar
Soon to be released from Square Ti Dog bones:
Old 06-05-2003, 11:10 AM   #1755
What Company does Chris Tos run for Batts and motors ?
John Q is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
