Old 06-03-2003, 03:06 PM   #1696
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Mo what setups on your website are with the stock yokomo springs? Is there any advantage to running the Rayspeed springs?
Jeff
Jeff Werner is offline   Reply With Quote
Old 06-03-2003, 04:11 PM   #1697
Regional Moderator
kansasracer's Avatar
Originally posted by Randman
What is the lowest ride height you guys are getting on the rear end using the stock stuff with the lower holes in the shock tower?
I can get 4.5 with all the kit settings....
I am watching.....always watching....
kansasracer is offline   Reply With Quote
Old 06-03-2003, 04:17 PM   #1698
mo
mo's Avatar
Jeff, I believe there is only 1 setup on my site that doen't use Yokomo springs and it is with Associated springs. I just got the Rayspeed springs this weekend. I will probably be using mostly the rayspeed and associated springs now though. The longer springs will be less progressive and should give a more consistant feel to the car.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 06-03-2003, 04:20 PM   #1699
Komkit- should be here next Monday.
Isaac is offline   Reply With Quote
Old 06-03-2003, 04:44 PM   #1700
Default Question
Hi,
What is you guys set up for kingpin shims on front C-Hubs? It seems that most of setup sheets does not indicate placement of shims on a kingpins. Unless I'm missing something.
Thanks,
D.
DoCoMo is offline   Reply With Quote
Old 06-03-2003, 07:13 PM   #1701
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I don't see how you are getting 4.5mm ride height. I have been racing for years with tons of cars in every class, so it's not like I am a noob to building cars... I'll double check the manual and make sure I did everything right though.
Old 06-03-2003, 07:28 PM   #1702
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
SUPER!
TheGame can help you with the setup hahahaha
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 06-03-2003, 07:36 PM   #1703
komkit's Avatar
I probably missed your posts early.
I build the shock in shuch a way that I can run my foam tires from 59.5mm ~ 54mm with 5mm constant ride height. I only have to adjust droop screw and shock adjusting nut. And I always have 1mm of an up travel.
Old 06-03-2003, 07:49 PM   #1704
komkit's Avatar
Oh, what spring were you using?
The photo is showing my 5mm ride height with 59.5mm tires on it.
As the tires getting smaller I back off droop screw and adjusting nut goes down toward the ground. As you can see I still have more room from the adjusting nut and the shock end cap... So, if I want to, I can drop the chassis down to 4mm or more with out any problem..
One thing that you can't see is I put an external limiter (1.8mm) on the shock shaft.
Old 06-03-2003, 08:44 PM   #1705
I think my tires are what's playing a big role in the problem, they are 64mm Sorex 36R's...
Old 06-03-2003, 08:46 PM   #1706
Yellow springs all around, but I am thinking about switching to Associated with their shock ends and spring retainers.
Old 06-03-2003, 10:22 PM   #1707
What are the spring rates for the Rayspeed springs?
Thanks, Lee
Lee Schultz is offline   Reply With Quote
Old 06-04-2003, 04:44 AM   #1708
komkit's Avatar
I see, I never put 64mm tires size on it. Have you try to put the limiter on the inside shock shaft?
Shortening 1mm of tolal shock length goes a long way.
Oh-BTW, did you get your Alinco pwr supply yet?
Old 06-04-2003, 05:53 AM   #1709
johnbull's Avatar
Hi guys. greetings from Malta.
The shock and spring issue is intersting, but never ending.
I ran my Belt drive Special with Associated TC3 shocks for years, simply to get what Mo says you get with the longer springs. He is absolutely correct; the longer springs do give the car more progression.
When I built up the SD I also built it up with TC3 shocks, though I put the new bladder type caps.
The reason for the longer shocks is more travel. The reason for the longer springs is more progression. In fact I have been using Fastrax springs on both my SD and my son's TC3. They are slightly longer than the Associated springs and go to a softer range, thus increasing our choice.
I did try the Yokomo shocks supplied with the kit, and I even put longer shafts in those (HPI), but found the car best everywhere with the TC3 shocks, number 3 pistons, and 40 oil. I have not run on carpet but on grippy asphalt.
I run a ride height of 5.5 front and 6 rear and the shocks have plenty of compression and rebound (droop). I did put bump limiters on the shocks which bottom out just before the chassis grounds.
I have not run the car for the last 10 days because I have been working on improving my son's TC3, but we are racing again this weekend so I will be running the SD again then.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 06-04-2003, 06:02 AM   #1710
Talking
Sooo... what do you guys think of the Black Special?
Anyone think the SD SSG could be stiffer?
jwwu is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
