Old 06-02-2003, 05:54 PM   #1666
Matt Howard's Avatar
randman- when you use the longer shock ends you use the other hole for the hingpin in the castor block
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 06-02-2003, 05:55 PM   #1667
rc-zombies's Avatar
Default Re: Re: Front body posts get in the way.
Originally posted by Randman
I am wondering which kit comes with that bumper hold down? You said the SSG Special, but that's the car I have. I use the outer mounting holes to try and get a little more body side support, but would like a brace like that.
Also, most setups call for the longer lower shock mounts on the front shocks, but when I have those on the ride height is too high, I am wondering if I am doing something wrong, or if that's just the way they are. I have the short mounts now not threaded on all the way.
The SSG Special is for the MR4TC belt drive car. The wide bumper brace is not sold seperately.
Old 06-02-2003, 06:11 PM   #1668
Default plastic bumper holdown
There is an older plactic bumper holdown kit for the MR4TC. I think the part number is ZS-016H "Front Body Post Support for MR-4TC".
-H
Headbanger is offline   Reply With Quote
Old 06-02-2003, 08:02 PM   #1669
analyzer's Avatar
Send a message via Yahoo to analyzer
Default Re: Tobee and Square stuff
Originally posted by Kenshin
Hi guys,
I just got my shipment of Tobee craft and Square stuff and I must say I was pleasantly surprised. The Tobee aluminum drive shaft comes TWO per pack for only about 7 bucks. I ordered 5 packs thinking that they only come one per pack. Now I can do front and rear with lotsa spares. That is pretty cheap if you ask me. I also got the lightened alu main drive shaft. I haven't weighed it yet to find out the difference between it and the stock one. I also got the front and rear alu input shafts. It costs about $8.50. It feels light, but I will confirm when I pull out the stock ones. Next is the Ti axle from Square, it is about $26. I got the fronts since I already broke two of the stock one. The boards keep getting in my way. Again, the finish is top notch as expected from Square. Durability test will have to wait until this weekend. Well, that's it for goodies right now. I will post pix later.
kenshin,
where do you get your stuffs from the Tobee & Square website or some other hobbyshops?
analyzer is offline   Reply With Quote
Old 06-02-2003, 09:24 PM   #1670
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Thanks Matt, I totally forgot about the castor block holes, and yet I used to run that setup on my MR-4TC cars...
Old 06-02-2003, 11:55 PM   #1671
Well I changed the castor block holes, and have the long shock ends back on, and I still can't get the front end lower than 7.5-8mm ride height. Any other suggestions, or should I just run the short shock ends? I do have the rear shock tower on front.
Old 06-02-2003, 11:58 PM   #1672
are you using the low or high holes on the tower? All the setups that I've seen with the rear tower on front have been using the upper holes. If the short shock ends get you the ride height that you need then just use them.
RCTech #361
Old 06-03-2003, 12:02 AM   #1673
I am running the upper holes, so I guess I just can't get any lower with this setup. What is the purpouse of running the different length shock ends?
Old 06-03-2003, 12:05 AM   #1674
the different length shock ends allow you to achieve the desired ride height. I just got another rear tower to put on the front but haven't installed it yet. What some other Yokomo guys are doing with the rayspeed springs is using the AE shock cups and a regular ball end for the shock end and putting the ball in the arm so you just snap the shock on the arm
RCTech #361
Old 06-03-2003, 12:12 AM   #1675
I'm using the long shock ends and have the top of the shock on the outer hole. The bottom of the shock is mounted on 2nd outer hole. With the Yokomo orange spring and no preload, the ride height is 4.5mm (measured from the front of the graphite chassis). If I measure from the plastic bumper, it is a lot higher (like 6 or 7mm).
-H
Old 06-03-2003, 12:15 AM   #1676
I have heard a little about the rayspeed springs, but is there any advantage to running them?
The lowest I can get the back of the car is 5.5mm now, so I will just thread the shock end onto the shaft a little more. I am wanting to get 5mm all the way around the car for a neutral setting point.
Old 06-03-2003, 04:20 AM   #1677
sosidge's Avatar
The only reason for using the long shock ends is to get more droop/ride height. If you can't get your ride height low enough, take them off. I use the short ends, unscrewed.
I took the center brace off the car for a bit, in all honesty I couldn't notice a difference, but I was running on a low grip surface. It's close to an ounce of weight though.
Old 06-03-2003, 05:29 AM   #1678
kentech's Avatar
Here's a setup that worked well for me in cold conditions (around/under 15 deg C) on a high speed track last Sunday.
http://www.netikka.net/kentech/tattarisuo_010603.PDF
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 06-03-2003, 05:30 AM   #1679
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
Originally posted by Joel Lagace
SEtups:
Could you guys post your CARPET setups for me?
The classes i run now with TC3 are:
-STOCK WITH RUBBER TIRES on ozite
-19T with foam tires on ozite
I would like your suggestions with the YOK SD.
What springs do you guys use? I plan to use my associated sets. Does yokomo rate there spring rates the same as AE?
I am using Yokomo GT-4 springs, that's what I can find at the LHS.
Posted the Ozite set up maybe a page back... anyway here is the link Ozite Set up sheet
I was running 12X2 though, but shouldn't be any problem if you put the milder Motor on. I don't run Rubber on the carpet, sorry.
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 06-03-2003, 05:34 AM   #1680
komkit's Avatar
Default Need the size please.
Arg
I was about the order some bearing on-line... But I forgot the manual... So, I could use some help from whomever that got the manual on hand.
What is the size of the Steering Hub bearing and Diff (out drive) bearing?
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
