Old 06-02-2003, 09:11 AM   #1651
Regional Moderator
kansasracer's Avatar
Originally posted by Jeff Werner
What days are you guys racing? We are interested in coming up for sure!
May have to get some setup stuff from you for up there. My car was good but needed just a little more turn in speed...going to try the rear shock tower conversion.
Jeff
Jeff,
Still working on a setup, using foams (40 shore all the way around) running a 10X2. I can't get enough turn in with the stock setup. Still trying to get some Yok springs so I can tune a little better....
Fastlane is running Sun. starting @ 11. We were finished around 4.
Track is super cool...Did you see the ad in Xtreme for the big nitro race?
I am watching.....always watching....
kansasracer is offline   Reply With Quote
Old 06-02-2003, 09:23 AM   #1652
sosidge's Avatar
Originally posted by DoCoMo
MRTC-SD1 is original Japanese version with front One-Way, SD-2 is a export(U.S.) version with NO One-Way, SD-3 is a Black version in Japan. My guess would be a SD-4 with Black Version with No one-way??
D.
Hmmm... well it says SD1 on my double diff car box, and it's listed as SD1 by both Yokomo USA and CML Distribution (UK).
I had a bit of a glitch problem once on the bench, but not on the track, caused by new brushes I think.
Old 06-02-2003, 09:58 AM   #1653
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Will do Mo, was wondering what elctrics layout everyone was using. Had my reciever on top of my servo.
Also made one other mistake with the car...put MIP CVDs on the rear and still used the stock wheel nuts...lost 3 of them during the day...got home and saw that MIP was nice enough to include lower profile nuts that allow the shacf of the axle to even stick out a bit...problem solved!
Jeff
Jeff Werner is offline   Reply With Quote
Old 06-02-2003, 10:00 AM   #1654
Default New SD Parts
sosidge,
Or may be SD-1 is a double diff, SD-2 is with One-Way. I wasn't sure which one is which.
Jeff,
I had a problem with glitching but it was mostly a 19T turn motor that we've used for a local club race. I have my recever on top of my servo and no problems.
Just checked a Japanese web site and looks like Team Suzuki is coming out with some aluminum parts for SD, also Square will release a titanium dog bones in June. I am sure we will hear more about this in coming week or so.
D.
DoCoMo is offline   Reply With Quote
Old 06-02-2003, 10:27 AM   #1655
Randy Caster's Avatar
Trader Rating: 46 (100%+)
What is the Suzuki site? They made a lot of nice parts for the MR-4TC, I was hoping they would release stuff for our car soon.
Old 06-02-2003, 10:32 AM   #1656
Joel Lagace's Avatar
My only issue was a glitch problem at times. I am running the novak xxtra with my m8...thinking about putting back in my blue airtronics. Anyone else have any radio problems with the new SD?
Jeff
This seems to be a normal things with this radio. I beleive there are at least 2 guys here that have the M8/NOVAK combo and are for ever fighting glitch problems... One runs a X-ray... I dont know that its a car problem. More of a novak problem
My beef is why the hell Airtronics and Futaba dont jsut make there own receiver and module. The airplane guys have had these units for years why do the car guys have to pay the higher prices and get less in return?
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 06-02-2003, 11:08 AM   #1657
Kenshin's Avatar
Default Tobee and Square stuff
Hi guys,
I just got my shipment of Tobee craft and Square stuff and I must say I was pleasantly surprised. The Tobee aluminum drive shaft comes TWO per pack for only about 7 bucks. I ordered 5 packs thinking that they only come one per pack. Now I can do front and rear with lotsa spares. That is pretty cheap if you ask me. I also got the lightened alu main drive shaft. I haven't weighed it yet to find out the difference between it and the stock one. I also got the front and rear alu input shafts. It costs about $8.50. It feels light, but I will confirm when I pull out the stock ones. Next is the Ti axle from Square, it is about $26. I got the fronts since I already broke two of the stock one. The boards keep getting in my way. Again, the finish is top notch as expected from Square. Durability test will have to wait until this weekend. Well, that's it for goodies right now. I will post pix later.
Kenshin is offline   Reply With Quote
Old 06-02-2003, 01:01 PM   #1658
Finnally bit the bullet and ordered a SD... Thanks Steve for the good phone service.
Now ill be running home from work like a kid at lunch goin home to watch the Flinstones!!
I noticed that this car comes with a stubby front bumper. Looks all pro and stuff but ill always run a full width bumper no matter what car. Xray sold a full width, TC3 used a buds or RPM... What are u guys doing about the bumper? OR do you just changes the broken parts when needed? Im sure RPM wont make one anytime soon so i guess ill get a sheet if kydex for now.
www.rcottawa.com
Old 06-02-2003, 01:34 PM   #1659
rc-zombies's Avatar
it's not really a stubby bumper... it's about 3/4 width of the foam bumper...have not have any problems with it....even with a head on collision when the wall came out of nowhere..
Old 06-02-2003, 02:14 PM   #1660
Kenshin, had a question about the Tobee Craft driveshafts, check your PM.
Old 06-02-2003, 04:06 PM   #1661
Default Front body posts get in the way.
I have the front body posts mounted on the inner holes per the instructions and find that access to the upper shock mounting screws is limited. I see that Masami has moved his posts to the outer position and used the bumper hold down from the 'SSG Special'. After I tear up my current body, I think I will try this mod.
Also have you noticed that Masami removed the small graphite center brace under the drive shaft. Anybody try this mod, yet?
-H
Headbanger is offline   Reply With Quote
Old 06-02-2003, 04:12 PM   #1662
rc-zombies's Avatar
Default Re: Front body posts get in the way.
-H
removing the lower center brace makes the chassis flex a little more...may increase traction on some tracks...
Old 06-02-2003, 05:23 PM   #1663
JimmyMac's Avatar
THeGame... Craig X won Mod and I think Mark U. But the fast guys weren't there racing Mod today. Including myself. hahaaha But it looked like he needed to work alittle on the uhh chicane area alittle. But Craigs car was fast.
Mark also raced Stock. He qualified 3rd behind myself and my friend who TQ'd. Actually Mark TQ'd first round. I TQ'd second round. And my friend Jairo TQ'd third round. For the first 2 laps of the main I swapped leads with Jairo until he got too much pressure from me.. hehe... He hit a corner dot and ended up 6th. And I took the lead til the end. Mark finished 2nd and Jairo worked back up to 3rd. It was a good race.
Well here is a pic of my Racing SD... (not the Brushless). hehe
JimmyMac is offline   Reply With Quote
Old 06-02-2003, 05:46 PM   #1664
SEtups:
Could you guys post your CARPET setups for me?
The classes i run now with TC3 are:
-STOCK WITH RUBBER TIRES on ozite
-19T with foam tires on ozite
I would like your suggestions with the YOK SD.
What springs do you guys use? I plan to use my associated sets. Does yokomo rate there spring rates the same as AE?
www.rcottawa.com
Old 06-02-2003, 05:50 PM   #1665
-H
I am wondering which kit comes with that bumper hold down? You said the SSG Special, but that's the car I have. I use the outer mounting holes to try and get a little more body side support, but would like a brace like that.
Also, most setups call for the longer lower shock mounts on the front shocks, but when I have those on the ride height is too high, I am wondering if I am doing something wrong, or if that's just the way they are. I have the short mounts now not threaded on all the way.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
