Old 10-01-2008, 01:25 PM   #15676
KandyRedCoi's Avatar
Send a message via AIM to KandyRedCoi
Originally Posted by azmio View Post
I still run my old SD cause it's still competitive. However, with powerful brushless motor, the plastic diff often ended up melted coming out of corner. Is there anything that I could do to solve this problem?
any pics?
what motor are you running?
how are you geared?
havent had that problem yet...maybe because im only running 13.5
https://www.facebook.com/ctdesigns09
KandyRedCoi is offline   Reply With Quote
Old 10-01-2008, 04:55 PM   #15677
Default 4.5 bl
it was never a problem with slower motor. i ran an LRP X11 motor with recommended gearing for high speed track
azmio is offline   Reply With Quote
Old 10-06-2008, 07:23 AM   #15678
part-time racer's Avatar
Default LCG question.
I recently got from a friend a Very Good condition LCG which has only ever been used in-doors on carpet.
Having been an xray user for the last 5 years an only racing 13.5 I felt a good quality shafty was the why forward still.
My question is; are the BD wish-bones the same as LCG ones? Same goes for C-hubs and caster blocks?
Also, can anyone suggest any advantages when using the narrower front wish-bones?
Regards,
Richard.
part-time racer is offline   Reply With Quote
Old 10-06-2008, 07:47 AM   #15679
SammyZ's Avatar
Trader Rating: 138 (100%+)
the sd/bd share the same suspension, dont use the SDW short arms.
SammyZ is offline   Reply With Quote
Old 10-10-2008, 08:17 AM   #15680
Dan415ms's Avatar
Questions?? Rayspeed SD on carpet with foam
Hi,
I am rebuilding and trying to set-up my old Yok/Rayspeed SD car to run indoors with foams on carpet....can anyone give me any tips please?
Thanks,
Dan
Dan415ms is offline   Reply With Quote
Old 10-10-2008, 08:51 AM   #15681
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default foam setup
foam setup
try a base setup
60 oil - front
40 -45 - rear
stiffer spring in front - 24 lbs or greater
softer spring in rear 20 lbs or greater
front droop +1 over ride
rear droop + 1.5 over ride height
front diff = med
rear diff = med
front toe 0
front ride height = 4.5
rear ride height = 4.5
try to start from there and change as needed and you should be able to get the car to handle nicely.
the only thing you might need to do is shave a bit from the inside of the foam tire, otherwise they might rub against the shock bottom.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 10-14-2008, 08:27 PM   #15682
few questions guys
which is the better performer.. the CGM or the BSG/SSG version??
is this still competitive against the current belt cars up to 23T??
lastly, what are the parts included in the CGM CONVERSION KIT??
thanks
sadig is offline   Reply With Quote
Old 10-14-2008, 09:51 PM   #15683
SammyZ's Avatar
i have a complete silver SSg conversion brand new, throw me an offer!
Old 10-14-2008, 10:01 PM   #15684
robk's Avatar
Trader Rating: 22 (100%+)
Is it a Tommy Kramer Edition?
Old 10-14-2008, 10:57 PM   #15685
Francis M.'s Avatar
This Tommy Kramer Edition SD is like Kaiser Sose from that movie Usual Suspects.... lol
Does it excist????
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 10-15-2008, 03:21 PM   #15686
robk's Avatar
I do have a picture of one
Old 10-15-2008, 04:41 PM   #15687
SammyZ's Avatar
thats wicked cool, ive never seen that before. Does it use LCG bulkheads? what kind iof motor mount? chassis and top deck?
Old 10-15-2008, 08:05 PM   #15688
SammyZ's Avatar
i have a NIP set of Acer Ceramic ball bearings for this car, $50 shipped
Old 10-15-2008, 08:14 PM   #15689
I would buy that. That chassis looks good. Who's got a LCG?
wilsonproperties1.com
Isaac is offline   Reply With Quote
Old 10-15-2008, 10:33 PM   #15690
ben there's Avatar
Default yokomo mr-4tc sd ssg special/rayspeed conversion
anybody have a set up 4 the trans am class .4 a yokomo sd ssg /rayspeed conversion 4cell stock motor? thanks, ben there rcp madison wi
ben there is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
