Yokomo MR-4TC SD
Old 10-14-2007, 09:50 PM
  #15631
lem2's Avatar
Default Freeing Your Drivetrain.
SD People!!!!!!
How free is your drive train? How long does the tire spin if you spin the wheels with your hand? With out the pinion on the motor (ofcourse).
I remember from a link in the TC3 thread, ages ago, there is this guy who blueprinted the drivetrain and it spins more than 15 seconds when spun with the hand?
Anyone has a link to that (if you can remember?)
Anyways, just asking. And post how lomg.
Lem
lem2 is offline
Old 10-14-2007, 09:52 PM
  #15632
Tim W.'s Avatar
My car does have diff cases. I just have had lots of rear diff problems the past two races. I run a few laps the the diff starts crunching and it strips the gears. I will order graphite ones and re shim the diff for the next race. Thanks for the help guys, I really like my SD its usually DIALED except for these diff problems
Tim W. is offline
Old 10-14-2007, 11:16 PM
  #15633
lem2's Avatar
you may have to buy a diff case, if it always happens. but try shimming it properly, better yet, follow the manual and go from there.
lem2 is offline
Old 10-15-2007, 08:15 AM
  #15634
MrUnlimited's Avatar
Originally Posted by lem2 View Post
SD People!!!!!!
Lem
Very free! I use ceramic bearings: metal shielded in the drivetrain and blue rubbershielded in the wheelhubs.
Graphite gears front and rear and 64dp spurs
MrUnlimited is offline
Old 10-17-2007, 03:09 PM
  #15635
Sd veterans, I have a question regarding dampers. I put on trf shocks(sacrilege?) on my rayspeed chassis, because I really hate the way yokomo shocks have to be screwed on top and bottom. The sus arms are so brittle, that I unscrew them once or twice to change springs and they are already loose. Anyway. I used long shocks ends for the rear to make them fit and all is well. For the front, Long shock ends wont give me enough throw and short ends max out the shocks at full droop. Is it bad that the shocks are resting in almost fully stretched position? My other cars, mostly tamiya have shocks set up like this. My evo 4 shocks at full droop are almost fully extended. Are yokomos the only shocks with internal limiters?
slomo is offline
Old 10-17-2007, 03:54 PM
  #15636
olhipster1's Avatar
Trader Rating: 99 (100%+)
The SD arms are more brittle than Ramen noodles....
Change your SD arms to the Yok Hard Arms the ones used on the Yok BDM ....
I always found those arms to be bullet proof..
i raced a BD for quite a while..and didn't break one arm...
then put those Yok shocks back
olhipster1 is offline
Old 10-17-2007, 11:07 PM
  #15637
So it's ok to have the shocks maxed out at resting position?
slomo is offline
Old 10-18-2007, 12:24 AM
  #15638
lem2's Avatar
are you using the TRF or yokomo shockends??
lem2 is offline
Old 10-18-2007, 11:49 AM
  #15639
Im using TRF shocks, the whole unit. They are about the same length as the yokomo short shock body. I dont think I'll be going back to yokomo shocks, just because tamiya shocks are much easier to take on/off and make adjustments. I was just curious if there is a clear advantahe for having the shock piston floating in oil like yokomo shocks. I have the long ends on the rear shocks and theyre fine> At full droop, the shocks are extended just about half way. Front shocks have short ends and they are fully extended before the droop screw touches the deck. Front droop is about 4-5 on the yokomo droop guage.
slomo is offline
Old 10-18-2007, 01:50 PM
  #15640
lem2's Avatar
I'm using TRF shocks also but to solve your problem, use the YOKOMO Shock ends, so you could also use the stock YOKOMO Spring retainer. And like what the others have suggested, use the hard arms.
Also, with your Rayspeed chassis are you using the plastic towers or the Rayspeed Ones?? If not get the Rayspeed towers. like thew ones on the CGM in the link below.
look here:
CGM Chassis....
http://www.rctech.net/forum/attachme...3&d=1117469059
http://www.rctech.net/forum/attachme...2&d=1117468953
LCG Chassis
http://www.rctech.net/forum/attachme...0&d=1119882444
http://www.rctech.net/forum/attachme...1&d=1136902476
http://www.rctech.net/forum/attachme...9&d=1120324214
lem2 is offline
Old 10-18-2007, 01:52 PM
  #15641
hmm... yokomo shock ends are about the same length as tamiya ones and using different spring retainers wont change the total shock length. It still has to be fully stretched out to meet full droop, no? I think this is all because Im running the rear tower up front. Front tower sits lower and the shocks dont have to be fully stretched. The way I see it, only way to solve it is by longer shock bodies, longer piston rods, or shock ends that are in between long and short length. So I guess it's a bad thing to have the shocks fully stretched. LOL. Sometimes, I need things spelled out for me. Thanks for your help.
slomo is offline
Old 10-23-2007, 12:19 AM
  #15642
Im getting some anormal wear on tires and inconsistent cornering. Right side tires are worn evenly, but the batter side tires are worn on the shoulders, especially the fronts. Whats the remedy? Thanks.
slomo is offline
Old 10-23-2007, 11:10 AM
  #15643
Francis M.'s Avatar
It could be your track lay out, If you want to make sure its not your car just rebuild your shocks make sure your shock lengths are even and camber is even.
Francis M. is offline
Old 11-04-2007, 05:15 AM
  #15644
mac853's Avatar
Originally Posted by MrUnlimited View Post
Here is my SD LCG:
Why pic with Bodyshell on, and not with chassiss only?
mac853 is offline
Old 11-09-2007, 11:23 AM
  #15645
capellone24's Avatar
hi Sd fans....
here is my SDW 4mm carpet spec project chassis.....hope u like it.
if anyone interested in this i can share the drawing....it is designed for SDW , but i think the holes are same to others SD cars
Bye!
capellone24 is offline
