Old 08-29-2006, 05:16 PM   #15406
ATLAS COPCO's Avatar
Originally Posted by TheCoolCanFanMan
Yo Simon se you got a pot yesterday you sandbagger
Malc TCCFM
What was the point in going , you must go home with somthing even if it is a cold lol
ATLAS COPCO is offline   Reply With Quote
Old 09-11-2006, 11:26 AM   #15407
MrUnlimited's Avatar
Default HELP PLEAZZZZZE!!!
I have problems with my car: I run standard shocks with white springs and blue front. One way drive with Atomic outdrives front and diff with Excell outdrives on the rear.
Problem is that my car is sliding and not controlable. Ride height is 5mm f&R. In every corner it spins. What can I do this to solve this.
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 09-11-2006, 12:22 PM   #15408
Send a message via AIM to aoizip
check your Diff... sounds like the diff is slipping..
aoizip is offline   Reply With Quote
Old 09-11-2006, 12:42 PM   #15409
chicky03's Avatar
Send a message via AIM to chicky03
Originally Posted by chubbspeterson
I read in one of the British mags a week or two ago that he is still running the yokomo, I also hear that there is a yokomo TKE car going to vegas this year.....could be good!
on that Schumacher pitspace site there is some pic's as well, look under the "Summer Sizzler" race section.
-Jeff Specoli-
as far as more info on the TKE car...contact yokomo
I heard the TKE car was really "Flying" this past weekend at the vegas warmup. Especially after the race was over, lets just say, how does that song go? "She's like the wind"
Paul
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 09-11-2006, 01:34 PM   #15410
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
is that christopher cross?
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 09-11-2006, 02:41 PM   #15411
Tried to lock the diff but it was the same result. My diff has ceramic balls.
Old 09-11-2006, 05:03 PM   #15412
Yokibear's Avatar
Tyres? Had this problem recently-turned out to be 2 front inner hinge pins were bent after a bad knock.
CORALLY RDX
AERCCC Member #18
Yokibear is offline   Reply With Quote
Old 09-11-2006, 10:27 PM   #15413
tom235's Avatar
im with yokibear i had the same thing where over the day of running my car kept spinning every where.took the car apart and i had 3 bent pins two frt one rear put new ones on it was much better
tom235 is offline   Reply With Quote
Old 09-11-2006, 10:30 PM   #15414
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Did he bolt the KD into the TKE Car?
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 09-12-2006, 02:43 AM   #15415
sosidge's Avatar
White and blue springs are VERY soft, if you are running on a surface with average to high grip the car will be leaning right over on itself and losing grip.
I would go up to a stiffer spring, I always found green fronts and yellow rears to be a good starting point.
Old 09-12-2006, 02:51 AM   #15416
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Are you talking Rayspeed springs or Yokomo? Greens are the softest Rayspeeds.. IIRC MrUnlimited runs an LCG and that car comes with Rayspeeds.
How old are the tires on the car? I always replace my tires, at the very least every second meeting. Generally I run CS27's as they're a good all round tire when its not too hot or tire choice is controlled. If your tires are older than a couple of meetings, replace them. Tires are 90% of a cars speed.
Check for tweak.
Check your hingepins, as previously mentioned.
Check your droops f&r.
What is the general setup on the car? Anything signifigantly different to the kit setup?
v0rtex is offline   Reply With Quote
Old 09-12-2006, 06:53 AM   #15417
chubbspeterson's Avatar
No he did not bolt the KD into the TKE car... he did however put the F.O.O.T. into the TKE......It was way faster........
Mike Demone
7-Eleven, National Accounts Manager
Ridgemont, CA, 90026
"I vowed to never let this happen.."
chubbspeterson is offline   Reply With Quote
Old 09-12-2006, 07:53 AM   #15418
sosidge's Avatar
Sorry, I meant Yokomo.
Old 09-12-2006, 12:23 PM   #15419
I use Raypseed springs. Would a change to the SSS shockbodies a good choice instead of the standard?
Old 09-12-2006, 12:25 PM   #15420
The kit comes with SSS bodies. The SS bodies are longer than the kit ones.
Dan Hughes is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
