Old 07-19-2006, 05:44 PM   #15346
housey's Avatar
Originally Posted by tom235
thanks a ton i will try some and let you know how it works
no probs dude
Chris Swallow - Team Yokomo - GM Racing - Ko Propo
Donny Racing - http://donnyracing.yolasite.com/forum.php
Poweeeeerrrrr!
housey is offline   Reply With Quote
Old 07-19-2006, 10:53 PM   #15347
tom235's Avatar
Originally Posted by housey
no probs dude
i have never been to that site its pretty sweet lot of good info do you know of any others
tom235 is offline   Reply With Quote
Old 07-20-2006, 05:37 AM   #15348
housey's Avatar
erm dont really know much else, that is CML's website, they distribute yokomo in the UK, so they have all the best setups for our types of tracks. you could check out yokomo usa if you havent already, im guessing they will have more than a few setups on their site. www.yokomousa.com
Poweeeeerrrrr!
Old 07-20-2006, 10:42 PM   #15349
tom235's Avatar
thanks bud i will try some of these set-ups and sse how it goes i just pulled the car apart into little pieces .have you used any of these set-ups
Old 07-20-2006, 10:57 PM   #15350
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
www.yokomo.tk is another one for older setups
v0rtex is offline   Reply With Quote
Old 07-21-2006, 12:27 AM   #15351
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
been searching a while as well for my LCG. most of the sites have BD or the SD CGM or SSG versions but rarely for the LCG (so far i've only found one and its in japanese so i can't understand anything except for the toe, droop and ride height settings).
anyway, i'm trying to aleviate my LCG's tendency to push out of corners... too much half-throttle understeer. any suggestion would be welcome.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 07-21-2006, 12:31 AM   #15352
I've only raced my LCG once but everything i've so far tried on it worked identical to how it worked on my BD. I think the suspension geometry is identical over the two cars so most setups should directly translate.
But other than that, try a little less droop in the front so it doesnt transfer as much weight to the rear wheels on accelleration.
Old 07-21-2006, 12:33 AM   #15353
Just on reading my post again, should that be more droop? I've got myself confused now Either way, change the droop so that the front of the car is around 1mm closer to the ground than it is now
Old 07-21-2006, 01:34 PM   #15354
You want less suspension travel in the front before the front tires lift off the ground. As you said you want less weight transfer to the rear on acceleration to help reduce understeer. Good starting point for the front droop on asphalt is about 6mm in the front and 4mm in the rear using a droop gauge.
pops is offline   Reply With Quote
Old 07-22-2006, 10:17 AM   #15355
Hey guys, I know I am not supposed to sell things on this thread , but this is for anybody running a Yoke with foams on Carpet. I have 7 sets of foams to get rid of, fronts narrowed to clear Yokomo arms and still meet ROAR spec's.
Foam Tires
1) Parma Cyan and Magenta 58mm width F=27.5mm R=28mm
2) Parma Cyan and Magenta 58mm Width F=27.5mm R=28mm
3) Parma Cyan and Magenta 58mm Width F=27.4mm R=28mm
4) Parma Cyan and Magenta 58mm Width F=27.4mm R=28mm
5) Parma Cyan and Magenta 57.5mm Width F=27.5mm R-28mm
6) Parma Purple and Plaid 57.3mm Width F=27.5mm R=28mm
Small nick in RR
7) Parma Purple and Plaid 56.5mm Width F=27.5mm R=28mm
Want $50 plus shipping.
Let me know.
Old 07-31-2006, 01:27 PM   #15356
chubbspeterson's Avatar
Anyone know the 7and 5 degree castor blocks for the sd? I know yokomo makes some and I think I will have to goto the kingpin to mount my camber link. Anyone know the part #?
Mike Demone
7-Eleven, National Accounts Manager
Ridgemont, CA, 90026
"I vowed to never let this happen.."
chubbspeterson is offline   Reply With Quote
Old 07-31-2006, 01:57 PM   #15357
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
chubbs -
i was looking for those today as well. man, i couldn't find them. ron would know. ron?
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 07-31-2006, 03:04 PM   #15358
ZS4135
ZS4137
you need to dremel them a bit and yes you do need to run the camberlink on the kingpin.
Dan Hughes is offline   Reply With Quote
Old 07-31-2006, 07:48 PM   #15359
Nice work
Sir!
Mike Demone
Old 08-02-2006, 04:55 PM   #15360
pcar951's Avatar
Trader Rating: 19 (100%+)
Default Yokomo newbie!
Hi all. Just ordered the MR4TC SD LCG. New to the brand (in this decade). Does anyone have any info / tip and tricks / setups to offer? I plan on running this shaft car in stock and 19 and keeping the T2 for mod. I guess I'll be frequenting this thread now, to suck up as much info as I can. Any help would be appreciated. Thanks
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
